Author Topic: TKS80 - Guide Rail Adjustment - Help needed  (Read 1079 times)
Offline The Otters
« on: January 05, 2021, 02:46 PM »
Hi all
I recently purchased a TKS80 as I am replacing many of my older tools and was so excited about buying this system.
Spent the first two lockdowns toying with the idea!
Anyway I note that when I am ripping a piece of timber, it is becoming very tight between the blade and the guide stop.
Forgive me if I am not using the correct name for this as I note it is called several items in the manual.
From Rip Saw Fence to
The part number is LA-TKS 80 Stopper.
It is the fence that runs parallel to the blade on the right hand side.
It would appear that it isn't running truly parallel to the blade, so the riving knife is pushed over.
I was hoping there was some adjustment at the far end of the Stopper however this doesn't seem to be the case.
Has anyone else had any experience of this?
And hopefully a solution.
Online Alex
Re: TKS80 - Guide Rail Adjustment - Help needed
« Reply #1 on: January 05, 2021, 02:59 PM »
ROFL, the notorious LA fence.
You know, I have the same problem with the exact same fence for my CS70, and some other people have said here they don't like it either. Problem is, it is not stiff enough and it runs not true enough on the front rail to also be in the exact same spot on the back rail.
My solution is, I always measure it in the front and the back to make sure it is dead straight. I don't know anything else.
Offline DeformedTree
« Reply #2 on: January 05, 2021, 03:05 PM »
Clamping Piece
Does Festool make items like Mafell has to clamp rails and such down?
It sounds like this is the same case with other saws where the blade is skewed from the fence, and the close point is only at the leading edge of the blade.  I think the CMS insert for the T55 was the same.
If you are getting binding, maybe you need the fence on the other side of the blade.
Offline TinyShop
« Reply #3 on: January 05, 2021, 03:51 PM »
@The Otters - are you making sure to tighten the round knob first then rotate the lever (which locks down the far side)? Doing this sequence out of order is a recipe for disaster.
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline FestitaMakool
« Reply #4 on: January 05, 2021, 06:05 PM »
@The Otters
Be sure to do as Tony Shop says. The large round knob straighten the fence, the lever to the right locks the rear of the fence. It is vital to do in the right sequence. When both are locked it’s dead steady.
Measure after doing it in the right sequence, then check if the fence is parallel to the blade (preferably less than half a Millimeter toe out in the far end)
The TKS 80 also has a non conductive piece glued to the aluminium sliding fence extrusion I’ve seen some with this glued on wrongly from the factory, so that the fence won’t stay square to the table, because the non conductive piece lever the whole fence.  [huh]
After checking this ^ the fence can be calibrated by loosening the (four) Allen bolts under the moulded “square” where the large knob sits. (At least it’s this way on the other LA fences for CS50 and CS70) You may need to loosen the plastic end cap of the fence itself to reach the nuts inside the fence. Loosen all four, then slightly tighten two bolts diagonally, be sure that the fence can be positioned without being too loose when you measure and calibrate. Then tighten the bolts, begin with the two diagonally, then cross tighten all four.
EDIT: Be sure to calibrate without the rear lever lock engaged, lock only the large knob. The rear lock is just a slave and do not correct the fence in any other way than clamping it to the rear. So always lock the large knob with the rear locking lever fully open.
« Last Edit: January 05, 2021, 06:10 PM by FestitaMakool »
Offline The Otters
« Reply #5 on: January 06, 2021, 05:52 AM »
Hi everyone.
Thank you so much for your replies.
I took the say down a few days ago so cannot try the pants that you have mentioned.
I will especially look at the sequence of tightening the LA.
However after getting particularly frustrated that it was not sitting correctly I did what very few men in the world have ever done - I read the instructions and followed them through point by point!
Still to no avail.
I did note that when the pressure was added to bring the back stop into play it made matters worse.
Perhaps the answer is at the handle end rather than the rear grip. I will report back in a couple of days.
Mustard Mitt that I am glad it wasn't just me having these issues!
The fine adjustment system is just garbage! Apart from that I love the saw.
Online Alex
« Reply #6 on: January 06, 2021, 07:29 AM »
Exactly, I took it out of mine. Totally unneeded and it only makes things difficult.
By the way, you have a funny autocorrect thing going on there.  [smile]
« Reply #7 on: January 06, 2021, 11:37 AM »
The fine adjustment is a joy to use  [big grin] ..sneaking up on a line, or with a ruler, instead of constantly knocking? on the fence [wink].
But then, no one forces anyone to use it or like it. I’ve found the LA fence quite good - but Festool can certainly develop it further, very soon! And that with backwards compatibility  [wink]
I can see a turning wheel, also with reduction gears, under the “V” to adjust the fence, for a start.. and a cantilever lock for the rear lock instead of the twist lock..
And yes, don’t turn off autocorrect, a bit of everyday fun that is [big grin]
Offline TinyShop
Re: How to Ajust Rip-Fence/Stopper for TKS80/CMS/CS70/CS50/MFT/3
« Reply #8 on: January 13, 2021, 10:46 PM »
For posterity - I came across the following blog post from 2016 (written in German) which includes photos and brief instructions for how to dial-in (a.k.a. improve the accuracy of) the rip fence (a.k.a. "stopper") for the CS 70 [scroll down the page until you find the section that deals with this topic].
https://www.holzundleim.de/2016/10/hilfreiche-tipps-fuer-die-festool-cs-70/
Here's the English translated version of the above blog post.
Since the design for the CS 70 rip fence hasn't changed (and since it's the still the basis for the rip fence that's currently available for the CMS, for the TKS 80 and for the CS 50 (Note - the CS 70 version is also compatible with the MFT/3) I thought I'd post the link to the blog post to aid folk's understanding of the process.
I also took the liberty of amending the title of this thread to make it easier for inquiring minds to find this guidance in the future.
Enjoy!
« Last Edit: January 13, 2021, 10:51 PM by TinyShop »
