Author Topic: The T18 Bag  (Read 814 times)
Offline Jeff Zanin
The T18 Bag
« on: July 20, 2020, 08:08 PM »
I recently got the TID18 and the T18E, these will be replacing DeWalt 14.4V NiMH tools that are not holding a charge.
318333-0
I weighed them just to see what the difference 15+ years of tool and battery evolution brings:
  • Dewalt 14.4 hammer drill: 2.4kg, T18E 1.9kg
  • DeWalt 14.4 impact 1.9kg, TID18 1.6kg
318325-1 318323-2 318327-3 318329-4
I like Systainers and have adopted them pretty broadly.  However I found the Systainers for the TID18 & T18E to be pretty bulky and not particularly well suited to how I expect to use these tools, based on years of using their predecessors.  I am a hobbiest / handyman type and while I try to stay in the shop it isn't always possible, and a drill + driver are two of the tools I most often need when I am working somewhere else.
Of course drills and drivers need bits, and I also like to have some screws with me, and that is where the Systainers didn't measure up.  So I set aside these particular Systainers and moved the TID18 + T18E into a smaller case that also has room for a selection of bits, some screws and a few other things that always seem to be needed.
The T18 bag is quite a bit smaller than the Systainers supplied with the TID18 & T18E, not quite as well organized but I think it will be much handier.
Offline PreferrablyWood
Re: The T18 Bag
« Reply #1 on: July 23, 2020, 04:02 AM »
Seems like you have got the setup you need there I will think your setup through and may adopt some of the ideas. Nice write up too. Thanks for posting.
« Last Edit: July 24, 2020, 05:57 AM by PreferrablyWood »
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline CBRacerX
Re: The T18 Bag
« Reply #2 on: July 28, 2020, 07:55 AM »
Interesting. I assume none of these are Centronic.  What are the 4 bits below the utility knife?
Offline grobkuschelig
Re: The T18 Bag
« Reply #3 on: July 28, 2020, 08:15 AM »
Looks like long Bosch impact bits to me...
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
Re: The T18 Bag
« Reply #4 on: July 28, 2020, 04:04 PM »
I'm eyeing those long socket adapters, and nut drivers. [drooling]
Offline Jeff Zanin
Re: The T18 Bag
« Reply #5 on: July 28, 2020, 11:06 PM »
Yes, they seem pretty good.  I've mainly used the T15 and T25 with GRX screws.
Offline Jeff Zanin
Re: The T18 Bag
« Reply #6 on: July 28, 2020, 11:08 PM »
I think those were from Princess Auto, kind of a cross between Harbor Freight and Tractor Supply.  The nut drivers are handy when driving Tapcon type screws when there is a bracket or fitting that obstructs access with a shorter bit.
