Author Topic: The Systainer Cart is a good value.  (Read 3644 times)
Offline Ned
« on: January 30, 2007, 01:09 PM »
I have twofour Systainer Carts
At first glance they seem expensive but a little comparison shows them to be a good value.  (There's a statement that applies to every Festool product.)
The cart is a sturdy plastic platform with indentations so that Systainers interlock with it as they do with each other.  Instead of  latches, four elastic loops secure the bottom Systainer to the cart.  a set of spare loops is included, but none of mine have needed to be replaced.
The casters are 75mm (3").  Two swivel, the two others swivel and double lock, that is, they neither roll nor pivot when locked.  They roll smoothly even when heavily loaded, a sure sign they aren't undersized.  (A year later, and they're still rolling smoothly.)
The cost of similar casters from Woodcraft ranges from 54 to 42 USD, from McMaster-Carr about 54 USD.  The ten dollar difference between the cost of first-rate casters and the total cost of the cart seems reasonable to me.
Offline Peter Teubel
Re: The Systainer Cart is a good value.
« Reply #1 on: January 30, 2007, 08:10 PM »
I have 3 Festool systainer carts and 4 homemade systainer carts. I simply pattern-routed 3/4" ply using the original systainer cart as the pattern. Attached 2" rubber-wheeled swivel casters (no locks) that I got from Harborfreight Tools on sale for $0.99 each (I bought 50 of them  ;D), routed a shallow depression to roughly match the bottom profile of a systainer, and mounted 4 small angle brackets to hold the 1st systainer on. Not as elegant as the original, but for just rolling around the shop they work great. Total cost was something like $6.
- Pete
Offline Corwin
« Reply #2 on: January 30, 2007, 10:56 PM »
Well, I'll have to go along with Ned on this.  The casters that I can find locally would cost close to $50 and are not nearly as nice as those on the Festool cart.  Currently I stack my Systainers on top of the vac and the one cart that I have...  but I'll want another cart with my next order.  I think a couple of carts w/Systainers under each 1080 MFT will be the ticket.
Corwin
