Author Topic: Tenon placement & spacing question  (Read 334 times)
Offline Thompmd
« on: May 18, 2020, 12:15 PM »
Doing glue-up for the back of my Systainer carcass And wondered if there is a size/spacing formula?
7/8” Kiln Dried Walnut
58” wide
Approx 4”-6” wide pieces(7pcs)
I used 8x40 tenons and placed them at 4” from each end a 2 more(4 total ) approx 17”( equidistant) apart.
Is this adequate
Sawstop Industrial Saw, TS75,2 1400 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,
Offline ChuckM
Re: Tenon placement & spacing question
« Reply #1 on: May 18, 2020, 12:22 PM »
I'd set them about 11" to 12" apart. 6" to 12" apart is the general guideline.
My preference: Narrow width setting for one side (the end-grain edge), narrow on the first one (for alignment) and then the rest medium wide setting for the mating side (face grain).
« Last Edit: May 18, 2020, 12:26 PM by ChuckM »
Offline Bert Vanderveen
« Reply #2 on: May 18, 2020, 12:27 PM »
At he ends I tend to use the default distance defined by the pins (or paddles, depending on which Mark DF500 you own). Anything around a foot wide will get one more domino (in the middle). Taller/longer than that, about every 4 or 5 inches (I wanted to say 15 cm… but hey!)
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set (next June!) … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Offline Thompmd
« Reply #3 on: May 18, 2020, 12:40 PM »
Is there a good video detailing this.
There goes my glue first then ask questions theory
I’ve got it glued in 3 sections now( 2pcs, 2pcs & 3pcs) so I’ll add some additional before doing the final glue up.
Offline jeffinsgf
« Reply #4 on: May 18, 2020, 04:48 PM »
If your stock is well machined and well behaved, I think you have plenty. Dominoes do not add strength to an edge-to-edge joint, they just make it a bit easier to align the faces. If the faces are aligned...you've got enough Dominoes.
