I've been building some frameless cabinets from prefinished plywood over the last year, with the help of my Festool tracksaw, MFT3, domino, and MFK 700 for trimming edge banding. I've been using preglued edge banding on the exposed plywood on the fronts of the cabinets/shelves, and using partial or full overlay doors and drawers. I've completed 2- book cases, 2- credenzas, 2- bathroom vanities, and a full set of upper and lower cabinets including a pantry for a small kitchen in an investment property. I'm honing my skills and refining my build process slowly, and I'm gaining confidence in my abilities. Applying the preglued edge banding with an iron is kind of a drag on the process, and I get loose spots where the glue didn't get heated long enough. I find these in assembly typically, and have to carefully reheat the area to get the glue to stick. I think the Conturo would speed up the process significantly, and I would hope eliminate the loose areas. The price of the Conturo is where I pause. It's just so dang expensive.
It looks like I will be tackling the task of building all new cabinets for my medium sized home kitchen. If this project happens, I see my edge banding options as:
1- keep using the preglued edge banding and iron, work on my technique to eliminate the loose spots, and come to terms with the time it will take to iron all this on.
2- purchase a less expensive edge banding machine. My issue with the others I've looked at, are the floor space they take because it's a dedicated machine that requires floor space (which I don't want to give up). I also have some concerns with the glue clean up/maintenance on this style of machine between uses.
3- purchase the Conturo and hopefully eliminate all my issues while significantly speeding up the application process.
Any advice???
