Thanks @Cheese I noticed that they list a hardwire option, but I wasn't clear how it worked. Looking forward to your photos.
Mike just to give you a bit more info...in one area I used the supplied power cord with in-line switch. In the past I've had issues with this type of arrangement as usually the switch contacts are not robust enough and if you actually use the switch for its intended purpose the switch eventually fails completely or you can hear it arcing, not good.
In this particular application, the normal wall switch will do the actual switching and the in-line switch in the cord will always remain closed. Hopefully because of the small current draw this will not fry the in-line switch prematurely...don't know...I'll find out.
![Blink [blink]](https://www.festoolownersgroup.com/Smileys/default/blink.gif)
For the hard wired LED's this is what the options are, either a short 6" wire stub which is pretty useless or taking the 4' connecter pieces and cutting them to length. I cut the 4' connector piece to 2' and used that to attach to the Romex.
This is the photo of the Romex + Molex connector + Barrina light connector. I used electrical tape temporarily but just ordered some 4:1 Shrinkflex heat shrink. I tried using the 2:1 heat shrink I already have but it didn't work very well.
