Author Topic: Sys drawers VS shop made  (Read 8917 times)
Offline Gunder
« on: April 26, 2020, 01:20 PM »
In the process of designing a new mft / Sysport outfeed table for my cabinet saw. Torn between building my own sysport drawers or buying the festool ones. It appears the festool ones require less vertical height. Anyone done it both ways and have thoughts on way way or the other? Thanks!
Offline ryanjg117
Re: Sys drawers VS shop made
« Reply #1 on: April 26, 2020, 04:21 PM »
The SYS-AZ drawers will always require less height as the tub is relatively thin plastic, though still sturdy because of the beefy side walls. The price appears to be on the high side, but keep in mind each SYS-AZ includes not just the drawer, but also high quality full extension drawer slides, a "switch" on the handle for keeping the drawers secure, and the ability to add a lock to each drawer as well (you do have to purchase the lock accessory I believe). They're very well made and I haven't had a failure in the 20 or so drawers I've installed.
I recommend buying them in the five pack (and I think you get one drawer for free). At least that used to be the deal.
Offline rmhinden
« Reply #2 on: April 26, 2020, 05:23 PM »
There are a lot of different ways to make your own systainer drawers.   I have been making them out of 3/4" plywood and routing out holes for the systainer feet.
If you make your own, and the cabinet is deep enough, you have room for two per shelf.
Here are some pictures.
Bob
Offline Gregor
« Reply #3 on: April 27, 2020, 02:31 AM »
The SYS-AZ drawers
Also keep in mind that the (only/lower) drawer of COMBI and SORT/3 systainers will be inaccessible while being in a SYS-AZ. IIRC.
For my self-build (similar to the one of @rmhinden) there is one thing I will definitvely change next time, at least for all the below working-height ones: rotate the drawer layout 90° (resulting in the drawer being deeper but less wide) with a symmetric hole pattern so it can hold a systainer both directions (lid opening to left or right, depending on how the systainer is being put down).
This will have the upside of an open lid effectively blocking the drawer from closing, resulting in less t-loc knobs to pick up over the day. Also space utilization will be way better as the full extension drawer will need to extend the systainer just shy out of the cabinet, not quite a bit more to have room for the lid to open (which results in that additional space sitting empty at the back when the drawer is closed). This also leads to multiple systainers on deep drawers being able to sit right next to each other (instead of needing a some cm gap to be able to open the lid of the front one, or the back one to be more shallow than the front one), which should make it possible to create the hole pattern for the systainer feet in a way to seat a SYS3 XXL (making these an option for me, which currently they are not as they would return me to having to unstack stacks to access things). Also having four columns of drawers is better than three (over basically the same total width of the shelf) when it comes to accessibility.
YMMV, that whole thought may be completely irrelevant to you in case you have a big shop and do not need to care about storage density.
« Reply #4 on: April 27, 2020, 10:25 AM »
@Gregor  good idea!
Offline Jeff Zanin
« Reply #5 on: April 27, 2020, 12:33 PM »
For my first seven Syssport-style cabinets I used shop-made drawers with full extension slides.  For the last two I used SYS-AZ drawers.
If I were starting fresh I would use SYS-AZ for everything that is used for Systainers because they are lighter and provide more capacity for a given cabinet size.
Offline SRSemenza
« Reply #6 on: April 27, 2020, 07:24 PM »
I really like the flat plywood "drawers" !
   I am doing some remodeling in my shop and went with shelves for a Systainer storage unit. No slides or drawers, but shelves designed for the purpose. Drawers would actually be a nuisance due to the height. Lowest are at about 38" from the floor and the top  row is about seven feet. Having to lift them out of shallow drawers at those heights would be harder than just sliding them off the shelf.
    The whole shelf unit is on top of my miter saw bench just behind the fence. I went end wise to get more Systainers into the space. The shelves are adjustable. The cutouts allow easy grabbing to slide the Systainers out and not have to leave and room for hand placement either vertically or horizontally.
Offline Dove_Tail
« Reply #7 on: April 27, 2020, 08:01 PM »
[ Specified attachment is not available ]Gunder - I went for shop-built drawers with Blum Tandem slides.  I looked hard at the Festool SYS-AZ drawers and I elected to go shop-built so that I could have self-closing drawers.  I sacrificed some storage going this way, but I wasn't impressed with the slides and construction of the Festool drawers for the price.
- Attachments and other options
« Last Edit: April 27, 2020, 08:04 PM by Dove_Tail »
Offline JimH2
« Reply #8 on: April 27, 2020, 10:54 PM »
I considered making my own equivalent of the SYS AZ's until I looked at the prices of the drawer slides I use (Blum) and add a small amount for material and my time. For me it does not make sense as I like one drawer per Systainer and single depth is more desirable for me.
However if someone wants to go full custom like double depth or width then it makes sense to make your own. For me buying the SYS AZ drawers made the most sense.
Offline ryanjg117
« Reply #9 on: April 28, 2020, 01:26 AM »
I like Bob's design because one problem with sysports always ends up being their shallow depth. They end up being forward-tippy, especially if your top drawer is something heavy. Obviously a bigger problem if you're making a single-wide cabinet on four casters. Building the cabinet deeper (and also to accommodate two systainers per shelf) is a really practical way to fix that dilemma.
Offline Coen
« Reply #10 on: April 28, 2020, 10:56 AM »
Bob
(Attachment Link) (Attachment Link)
Wow that is super nice. What slides did you use? The ones I find are way less "low profile".
Offline KelleyCrafts
« Reply #11 on: April 28, 2020, 11:02 AM »
I went the route Bob did, two deep with my MFT cart. Works really well and was easy enough to make a template to route the foot indentations.
Turning the Systainers sideways is something I would have maybe done if I could still go two deep in the cart. I didn't think about it at the time unfortunately.
Offline rmhinden
« Reply #12 on: April 28, 2020, 02:03 PM »
@Coen   Thanks!
I have used a mix of slides.  I started with (Woodcraft) High Point 14" full extension slides (heavy duty for the bottoms and regular for the rest of the systainer cart, a mix of 26" High Point models for the deeper ones, and 14" ones I found on Amazon on the Kapex stand.   BTW, I think 28" would be better to hold two Systainers.  I got the 26" ones on sale at some point, should have measured first :-)
@KelleyCrafts
I also used a template to make the drawers.    I should add that the Systainer cart is based on plans I purchased at TSO TSC-90 Systainer Cart Plan Set .  It includes details on on a template for the drawers.  Well worth the $7.
Bob
« Reply #13 on: April 28, 2020, 02:05 PM »
I agree on the 28" slides. I used those for my MFT cart and can open systainers at will without removing them and the lids stay open. Good point to bring up @rmhinden.
Offline Gunder
« Reply #14 on: April 28, 2020, 02:27 PM »
Thanks for all of the great suggestions / ideas so far. Keep them coming!
Offline FestitaMakool
« Reply #15 on: April 28, 2020, 02:28 PM »
That’s a neat and compact set up. Easy reach of MANY  [blink] systainers. Looks very tidy as well.  [smile]
Offline Hiersekorn
« Reply #16 on: April 28, 2020, 02:53 PM »
I keep seeing these amazing walls, filled with systainers. And, I have to wonder -- what exactly is in all those boxes?
Does everyone have $30,000 worth of Festo stuff? Or, are people just buying empty systainers to organize their stuff?
TS-55 | Domino 500 | OF-1400 | Carvex | T 18+3 | TID 18 | CT-15
Offline Coen
« Reply #17 on: April 28, 2020, 03:29 PM »
I don't really want to add it all up  [unsure]
But it's not hard to get a few Systainers. I think I have ~27 if I counted right. Not everyone bought theirs new and in case of a business it can make fiscal sense to keep collecting.
Offline NeoTerror
« Reply #18 on: September 11, 2022, 05:33 AM »
Bob
Is building your own drawers more cost effective than buying the ready made Festool Sys drawers?
Offline Crazyraceguy
« Reply #19 on: September 11, 2022, 06:31 AM »
Cost is a relative term. What is your time worth? Hobbyist or commercial time?
Assuming that you have a cabinet that they fit, the AZs can be installed in a couple of minutes.
Building the drawers takes some time. How much depends on the style.
The 3/4" ply slabs with a front edge (like mine) only take a little bit of time, but it is more than just installing the pre-made units.
Slabs with holes for the feet take time to make a template too, but less material.
If it is purely about cash outlay, making them yourself is cheaper, especially if you have some scrap available. If time matters, the AZ might be a better option.
I went with making my own for a couple of reasons. Mine are 20" deep, which leaves space behind them to store accessories or consumables that don't fit in the Systainers themselves. I also knew that they would be expanding over time and I could keep the cost down by using off-cuts of both the plywood and the oak fronts.
Yes, there are a few of us out there with a lot invested in this stuff. Mine may not be 30k, but it's probably close. I only have 2 Systainers that were purchased empty. One is full of router bits and the other is the one with a drawer in the bottom. I store bags of Dominos in the top and spare bits in the drawer. All of the rest are Festool, WoodPeckers, or Shaper. I haven't counted lately, 25 or so?
« Last Edit: September 11, 2022, 06:47 AM by Crazyraceguy »
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Installers set
Centrotech organizer set
Offline Thompmd
« Reply #20 on: September 11, 2022, 07:11 AM »
I love the Sys-AZ threads/pics. I ran into a guy who was moving a month or so ago and bought 6 more sys-az’s still in their boxes and bought all 6 for $10ea. Unreal!!
I really like seeing what everyone else did and how it fit their circumstances.
Can’t wait to start building mine in November
Sawstop Industrial Saw, TS75,2 800,2 1400 & 2700 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160, TSC 55, T18 E
Offline Ebuwan
« Reply #21 on: September 12, 2022, 01:38 PM »
I went with shop built for two reasons;
I can go double depth
I can make shelves for the L series and XXL series systainers
That always bugged me; they dont make sys-az's for the wider systainers. I understand majority of systainers are the regular width, but I'm going to be using some xxl's, one for Paint stuff, one for Plumbing, one for electrical, stuff like that.
Offline Coen
« Reply #22 on: September 12, 2022, 07:29 PM »
Also go shop made to save space. The Sys-AZ drawers need a 380mm deep cabinet... the systainer itself is only 300
Offline Ebuwan
« Reply #23 on: September 13, 2022, 09:14 AM »
True to that too; i did 400 depth for single and 700 depth for double; this allows me to open both systainers and get to their contents comfortably.
I made a template for the systainer feet, i double stick tape it to a piece of melamine that has the drawer slides attached to the sides, super easy.
I built mine all out of Melamine; i tried 1 cabinet first, and its totally stable and no issues, and its WAY cheaper than any other material. I also am lucky enough to have a conturo and mfk, so edge banding is a breeze. It's about $43 bucks a sheet at the big Orange place. it is HEAVY though, oof, but super flat etc.
Offline Coen
« Reply #24 on: September 13, 2022, 09:20 AM »
The big orange place in the USA or one of the big orange places (which one, lol) in Germany?
Home Depot is orange?
In Germany both Hornbach and Obi are orange.
Offline Sbradley0911
« Reply #25 on: September 13, 2022, 05:26 PM »
Here's how I did my drawers
Offline JimH2
« Reply #26 on: September 14, 2022, 09:34 AM »
When I last looked the cost the drawer slides pushed me towards the Sys slide outs.
Offline deltad
« Reply #27 on: September 18, 2022, 09:51 PM »
what height are those?
