Author Topic: (UPDATED) Shopmade OF1400 Extension Base..Look out Pat Warner  (Read 11062 times)
Offline lablover27
OK, just kidding about Pat Warner.  I did some searching here and saw that the tippy nature of the OF1400 or any other router for that matter was issue.  PAt Warner does not what to tool up etc to make us Festoolians a base..Hmmm  After reading up on the issues here and the wants of users I think I came up with something.
Mind you, this is a prototype..I made it from 1/2 MDF which seems to work fine.  I also noted that Brice here metioned in the past ould be nice to use dust chute etc.
Here ya go...Feel free to add suggestions etc.  I knocked this out in about 20 min.  I also bought some 3/8 acrylic but have not cut on it yet.  As you can see from the pics, you can use all the goodies with it but the only issue I see is the depth of the Porter Cable guides dont hang down enough..They do hang down but only make partial contact with the workpiece.  This is because the 1/2...Not sure 3/8 would be strong enough?  I also plan on putting on a knob.
All the mounting holes line up real good unless I flip the guide over then not so much...Not sure why that happened?
I really dont see the need to do it in clear either.  I mean, the festool version is not see thru  :)
Scroll down the thread to see Acrylic version 2
Be kind  :)
« Last Edit: December 09, 2009, 07:53 PM by lablover27 »
Offline lablover27
Re: Shopmade OF1400 Extension Base..Look out Pat Warner
« Reply #1 on: December 09, 2009, 05:20 PM »
YIKEs
Let me resize those
Offline sl_1800
« Reply #2 on: December 09, 2009, 05:29 PM »
Looks good to me, now if I only had a 1400 router.  [sad]
Check out my blog at www.woodshopblog.wordpress.com
Offline lablover27
Re: (UPDATED) Shopmade OF1400 Extension Base..Look out Pat Warner
« Reply #3 on: December 09, 2009, 07:55 PM »
OK..got to thinkin at dinner and decided to do the Acrylic version..WOW, real easy
I think is awesome...You tell me
Now takin orders...hehehehehehehhe
Offline Bob Marino
« Reply #4 on: December 09, 2009, 08:29 PM »
 Joe,
 What's to knock? Incredible job. "Look out Pat Warner" is not an unrealistic title.
Bob
Former Festool  Dealer since 2002; user well before that!
Offline sl_1800
« Reply #5 on: December 09, 2009, 09:01 PM »
Fantastic
Offline john ferri
« Reply #6 on: December 10, 2009, 12:30 AM »
Great job.  Where did you get the 3/8 acrylic and how did you machine is so cleanly (what speed on the router).
JF
Offline lablover27
« Reply #7 on: December 10, 2009, 07:42 AM »
Got the plastic at woodcraft, a bit pricy but worth it for this.  Being I wanted to make this a different size, I had no template so I did not use a router to machine it.  All Drill press and band saw..Lot's of sanding on the edge but my vertical belt sander helped with that.  Now that I have this I can use it to make myself a template out of something else so I can use router to machine others if need be.
I can say that the Acrylic is kind of a pain to work with.  When drilling, you have to secure the workpiece very good because when the drill bit goes to go thru it wants to catch the bit.  And I can tell you right now you ain't gonna hold it still by hand  :)  I used the slowest speed on the drill press  250 rpm and worked like a charm, just have fresh scrap under the hole for "EVERY HOLE".
GEttin those holes lined up was my biggest fear, but it's pretty simple.  And, you can not flip the base either..The hole pattern wont allow it.  So, what this means is it goes on one way and one way only.
I have to say I'm pretty happy with it.  3/8 seems more than enough.  I don't think i would want to drop it attached to the router or anything.  I used it without the knob and worked like it was supposed to.
Offline Daviddubya
  • Arizona, USA
« Reply #8 on: December 10, 2009, 09:34 AM »
Nice job.  Does the added thickness of the base cause any issues when used with Porter Cable bushings and accompanying router bits?  I suspect the reason that Pat Warner shies away from it is the setup cost to accurately center and machine the bushing hole vs. market size.  Looks like you have a way to get around those costs.
David W. Falkenstein
in Cave Creek, AZ, USA
Offline lablover27
« Reply #9 on: December 10, 2009, 10:44 AM »
Bushings seem to work great.....SO FAR  :)  I have not found any issues yet.
Offline JerryW
« Reply #10 on: December 10, 2009, 11:09 AM »
Great innovation, lablover27.
Did the added thickness of the base require you to find replacement screws to attach to the router?  If so where did you find them?  I have been looking for some longer M4 x 8 flatheads to use with a thicker pad.  Haven't had much luck locally.
Jerry
Offline Steve-CO
« Reply #11 on: December 10, 2009, 11:19 AM »
McMaster Carr should have whatever you need.
Offline lablover27
« Reply #12 on: December 10, 2009, 11:22 AM »
Jerry, found the longer screws at lowes.  I was shocked
Offline JerryW
« Reply #13 on: December 10, 2009, 12:24 PM »
Thanks for leads, guys.  I've struck out so many times at Lowes that I probably did not try them.  McMaster-Carr is always good.
Jerry
Jerry
Offline Jimhart
« Reply #14 on: December 10, 2009, 12:51 PM »
Very nice. I made a similar base for a PC690 a few years ago. Started with 1/2" Baltic Birch to make a template just the way I wanted it. Then drew the outline on 3/8" acrylic and cut about 1/8" from the line with a bandsaw. Attached the acrylic to the baltic birch template with double-sided tape. flush trimmed on the router table and it was perfect and repeatable.
Used the template to guide a center punch to mark the holes on the acrylic. Then used an acrylic drill bit so it wouldn't grab.
Offline lablover27
« Reply #15 on: December 10, 2009, 01:10 PM »
Good tip on the Bit
Now that I'm done......hehehehehehehe
Good tip to keep upstairs in the brain till next time
Thanks a million
Offline Tom Bellemare
  • Inactive Member
« Reply #16 on: December 10, 2009, 02:46 PM »
Jerry:
There's a place called Alloy and Stainless Fasteners on the northwest side of Houston that is probably the closest to you (if you're in Katy). There's also a place called Bolts and Nuts Plus just south of the Beltway near the airport.
Offline JerryW
« Reply #17 on: December 11, 2009, 11:14 AM »
Thanks, Tom.  Its good to know about those places.
Jerry
Offline woody
  • My greatest creation
« Reply #18 on: December 15, 2009, 07:04 PM »
well here's my base that i made about a year and a half ago.  I got deployed, so i was'nt able to post it sooner.  the base takes benchdog insert plates and the inserts from kreg (they have one that takes a collar).  The chip deflector is attached by magnets that are in the base.  As you can see by the picture, I use the bigger deflector, The one on the left is the one that comes with the router (huge diffrence in performance!)  I made a channel in the base so that I could hook the vac to the base instead of the router (big diffrence in edge routing) then I plug the router collection port. the base is made from phenolic ( a blank benchdog plate) the whole thing took a few nights at work (still had to do my real job) but it was fun,  hope you like!
Offline John Stevens
  • Ardmore, PA
« Reply #19 on: December 15, 2009, 07:46 PM »
Good tip on the Bit
Yeah, McMaster Carr also sells drill bits for plastic, and they're not an arm and a leg.  OTOH, brad-point bits and spade bits also work fairly well, better than regular wood bits.
Very nice job on the base, by the way.
Regards,
John
What this world needs is a good retreat.
--Captain Beefheart
  • Ardmore, PA
« Reply #20 on: December 15, 2009, 07:49 PM »
US Plastics (usplastics.com) has all kinds of stock at prices that are as reasonable as any I've seen.
Regards,
John
--Captain Beefheart
  • Ardmore, PA
« Reply #21 on: December 15, 2009, 07:53 PM »
Incredible!  I've made half a dozen router bases, four for the OF1010 and two for the PC690, but I'd never have dreamed of doing what you did.  Glad you're back home safe and sound, thanks for your service and for sharing your work here.
Regards,
John
--Captain Beefheart
Offline lablover27
« Reply #22 on: December 16, 2009, 07:30 AM »
woody
pretty slick.  Is that aluminum?  I'd love to see the channel underneath as well.  Very cool setup indeed
Offline Martin Johnson
« Reply #23 on: December 16, 2009, 09:24 AM »
Nice projects guys...I like the addition of the knob on the outboard side of the acrylic base.
For those that don't have the time or desire to make an extension base (table widener) for the OF1400...there is a version available in the U.S. catalog (pg.  92 - part # 493233)...it is solid phenolic resin base for rigidity, strength, and reduced marring.  The Festool guide bushing adaptor (pg. 90 - part # 493 566) snaps into the router, and the dust hood is held in place on the table widener by rare earth maginets.
Martin
Offline ForumMFG
    • Forum MFG
« Reply #24 on: December 16, 2009, 09:37 AM »
Can you provide a good side view picture or something that shows the channel for the dust collection you made?
Offline bonesbr549
  • I'd rather be woodworking
« Reply #25 on: December 16, 2009, 10:09 AM »
What did you cut the acrylic with?
Offline lablover27
« Reply #26 on: December 16, 2009, 06:42 PM »
Bandsaw
Worked like a charm
Offline Daviddubya
  • Arizona, USA
« Reply #27 on: December 16, 2009, 09:48 PM »
...I have been looking for some longer M4 x 8 flatheads to use with a thicker pad.  Haven't had much luck locally.
Ace Hardware has a pretty good selection of metric hardware.  I bought some bolts at Ace for my OF1400 router.  Pricey but convenient, especially for small quantities.
« Last Edit: December 16, 2009, 09:49 PM by Daviddubya »
Offline woody
« Reply #28 on: December 18, 2009, 06:59 PM »
Hey guys, sorry it took me a few days to reply, but as requested, here is some pictures of the channel in the plate.  I failed to mention earlier that the top plate is alluminum.  I also cut a draft angle in the channel to help with the air flow.  Does it make a big diffrence? Couldnt tell you, but its there.  Thanks for looking!
Offline DavidWK
« Reply #29 on: February 12, 2020, 11:15 AM »
FWIW, I find that drill bits with a 150 degree point (as opposed to 82 or 135) work well on Acrylic.  The sharper points tend to break through and crack the plastic.  Polycarbonite is much more forgiving, but more expensive.
