Author Topic: Sell 2700mm track or keep?  (Read 1669 times)
Offline bwehman
« on: September 18, 2023, 02:35 AM »
I've owned a 2700mm track for a couple years to process sheet goods, and it was the biggest track I could fit in the shop, and even then, I had to go outside anytime I wanted to turn it around. I just moved into a much larger space and now have room for the 3000mm track easily.
I also have the 800 and 1400 tracks and the latest FS kit.
Is it worth going through the hassle and selling the 2700mm track to get the 3000, or is the increased capacity not worth the headache?
The 2700mm track just barely cuts a 4x8 sheet with the TS55. Barely, but it does it and I've cut dozens and dozens of sheets with it.
Thoughts?
Offline luvmytoolz
Re: Sell 2700mm track or keep?
« Reply #1 on: September 18, 2023, 02:59 AM »
Myself, I'd keep both unless finance dictated selling one, or I later found I just never ended up using one!
It's not like they'll decrease in value dramatically any time soon too so selling anytime will likely be good.
Offline bwehman
« Reply #2 on: September 18, 2023, 03:21 AM »
If I had both, a 2700 and 3000, I'd never use the 2700.
Offline Mark Katz
« Reply #3 on: September 18, 2023, 03:38 AM »
I have a 2700 also, and don't have the space for a 3000. I found this TSO product useful for those cases where I need a bit more length. It's also useful for extending my shorter rails for the occasions when I could use something in between sizes
https://tsoproducts.com/jigs-fixtures-guides/gre-13-guide-rail-extension/
Offline Oldwood
  • Alberta, Canada
« Reply #4 on: September 18, 2023, 06:48 AM »
You could cut the 2700 and make a 1900. That would give you an extra 800, and I could use an 800 ;)
You could sell the 800. The 1900 is a good length for cross-cutting 4' sheets.
Confucius
Offline bwehman
« Reply #5 on: September 18, 2023, 10:51 AM »
You’re a genius.
Online squall_line
« Reply #6 on: September 18, 2023, 10:58 AM »
It sounds like you have found peace and understanding with the 2700 rail as far as using it on 8' sheets, even if not 100% convenient.  Even in a larger shop, a 3 meter rail will still be harder to maneuver than the 2.7 meter rail, and the new rail may not be as straight as the one you already have?
That 13" rail extension from TSO also works a treat, and stores perfectly in the TS55 systainer.
Offline rst
« Reply #7 on: September 18, 2023, 01:46 PM »
My most used rails are the 3000 and 1900.  I joined rails for way too long before I bit the bullet and got the 3000.  The 2700 is the only one I do not own.
Offline Oldwood
  • Alberta, Canada
« Reply #8 on: September 18, 2023, 03:46 PM »
You’re a genius.
Like RST the 3000 and 1900 are most used rails, I do have a 1400 that stays on a home built MFT. I have joined the 3000 and 1400 to straight rip long boards.
Confucius
Offline lwoirhaye
« Reply #9 on: September 18, 2023, 03:51 PM »
Back when it was like $180 I bought a 2700mm rail by mistake.  Returning it seemed like a huge hassle and I learned to get by with it.  That extension looks like just the right solution though.
Offline Crazyraceguy
« Reply #10 on: September 18, 2023, 05:45 PM »
The only thing I would say differently is that I didn't put up with it very long.
I got the LR32 version of the 1400, when I bought the saw, added a 1080 very quickly. Not long after that, having joined those two a few times, I jumped straight to the 3000. The "somewhere in between" of 1900 came next. Those 4 served me well for quite a while. I did add a 2424LR32 a year or so ago, because of a specific need. The 800 was actually the last one, and it has proven to be pretty handy too. The 2700 is the only one I don't have, but I have more than plenty of space.
The advantage you do have going for you though is buying it long enough ago to get that price.
To the right buyer, you could probably sell it for a profit...but the 3000 is going to be more costly to cut into that gain.
The TSO extender might be just the solution for a lot of people. The 1400 is barely enough to crosscut 4 x 8 sheets with a TS55 and isn't enough with a TS75. That extension could solve that problem too.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Offline Laminator
« Reply #11 on: September 18, 2023, 06:28 PM »
I bought the 2700 when I got the ATF55 saw. It ripped 8' with no problems. I then purchased the TS55 and because the base is different it was a problem so I got the 3000.  The 2700 now lives in my van.  I very seldom get rid of anything lol....
Offline Coen
« Reply #12 on: September 20, 2023, 12:05 PM »
What is 1400 + 1080 gonna do? It's not cutting 2442 sheetgoods.
« Reply #13 on: September 20, 2023, 05:03 PM »
It's all I had at the time, which was also the motivation to go with longer, and not join them anymore.
Sadly enough though, I have had to add to the 3000....more than once  [blink]
« Last Edit: September 21, 2023, 06:39 PM by Crazyraceguy »
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
Offline PaulMarcel
    • Voilà, my blog
« Reply #14 on: September 21, 2023, 05:18 AM »
My most used tracks are the 3000, 1900, and 800 so the idea of getting the 3000 and cutting the 2700 to make a 1900 and 800 seems like a great idea to me.
Offline Coen
« Reply #15 on: September 21, 2023, 11:56 AM »
Sadly enough though, I have had to add to the 3000....more tan once  [blink]
There is also a FS 5000/2 in Europe. But I have yet to see one in the wild I think. I hear it was discontinued in the USA?
I started with an 800 that came with my OF-1010. Got a 1400 with the TS 55. That was also too short together. I eventually wanted the LR-32 system, so I got the holey 1400 next. Then when I eventually got the LR-32 system and needed longer rows of holes, I got another holey 1400. The third rails also makes it easier to straighten out the two rails that you connect.
Or; 1655 and 1045. The short one to cut short sides of 610mm sheets, the longer one to cut the side of 1220. But for diagonals, the 1900 is better of course.
Offline HighlandMarine
« Reply #16 on: September 21, 2023, 12:57 PM »
Thoughts?
Not sure which saw(s) you’re running, but having some rails designated for the 55 and some for the 75 could be another way to look at it. And with the fast cap rail mounts, there’s always room for more Festool guide rails!
CT26E | CT Boom Arm | CTC SYS | CT MIDI I | DF500 Set | DF700 XL EQ Set | ETS 125 REQ | ETS EC 125-150/3 | FS800/2 | FS1400/2 | FS1400/2KP | FS2700/2 | KA UG Set Metric | KS120EB | LR32 Set | MW1000 | OF1400 | RO150FEQ | TID18 | TS55FEQ | TSC55KEBI | TS75 | DASHBOARD PWS | P1CC | Fein 500MM w/ Vecturo Set
« Reply #17 on: September 21, 2023, 06:52 PM »
Why would you need to do that? All you have to do is adjust them to cut on the same line. I have all 3 of the corded saws and never concern myself over which rail I am using.
My workflow is so variable that I use them all quite a bit. Some projects I don't use the longer ones at all. Other times, they are the most valuable.
That job that I do with the diagonal grain uses most of them, alternating back and forth.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
