Author Topic: Scribing with rotex  (Read 1483 times)
Offline bwehman
Scribing with rotex
« on: November 07, 2019, 06:27 PM »
Hey all!
Deciding whether or not to buy the RAS but have all the Rotex's already. Has anyone tried occasional scribing with these? I feel like, without having tried it, that the RO90 might do well. But ¯\_(ツ)_/¯
Online SRSemenza
Re: Scribing with rotex
« Reply #1 on: November 07, 2019, 06:57 PM »
Hey all!
Yup. I  have done scribing withe RO90 and RO150.  Hard pad on both with some sort of coarse grit.  RO150 over the 90 for sure. I find the 90 just doesn't have the power that I want for scribing. I also find that the RO90 doesn't like a heavy touch  and can be difficult to keep the pad turning properly for scribing. The 150 works well. You need a stable bench to keep things from vibrating a lot while scribing with the RO150 in Rotex mode.
The RAS  has been shown to be excellent for scribing. I have one but have not had the opportunity to scribe with it yet. But of the three the RAS should be the best.
Since you have a RO150 you should just give a test try.
Offline Naildrivingman
« Reply #2 on: November 07, 2019, 06:58 PM »
I’ve used my 90 to scribe. I feel it works very well. A coworker recently bought a RAS and he says it is also very good for scribing.
Dance with who brung ya...
Offline Sparktrician
« Reply #3 on: November 07, 2019, 07:27 PM »
Concur with your coworker.  The RAS is great for scribing.   [smile]
- Willy -
Offline RJNeal
« Reply #4 on: November 07, 2019, 07:51 PM »
I scribe with the RAS most of the time. If it’s a small amount of scribe and the 90 is out then we use it. If the RO 150 is out then I will also use that.
Rick
Offline Birdhunter
« Reply #5 on: November 07, 2019, 08:44 PM »
What is scribing?
Birdhunter
Offline Lincoln
« Reply #6 on: November 07, 2019, 10:28 PM »
Fitting a panel/door etc. to an uneven wall/floor etc.
Offline waho6o9
    • Garage Door Handyman.com
« Reply #7 on: November 07, 2019, 11:44 PM »
Offline Birdhunter
« Reply #8 on: November 08, 2019, 05:20 AM »
Thanks for the explanation.
Birdhunter
Offline Tik Tok
« Reply #9 on: November 08, 2019, 06:49 AM »
I have used both the RAS and the RO150 recently for this purpose and found the results to be close enough that I would not have a problem reaching for either systainer when in need. I prefer the RAS when given the option as it seemed to get to the result a little quicker but that could be in my head and since speed is not an indicator of quality outcome - you may one that “your mileage may vary.”
Offline Alex
« Reply #10 on: November 08, 2019, 08:00 AM »
I own the RAS, the RO150 and had the RO90.
RO90 works OK on thin stock like 12 mm, 1/2'' and smaller but is bad with thicker wood.
RO150 works fine on most materials and sizes, but you do have to work hard to guide it sometimes.
RAS is a breeze all the time.
Offline GoingMyWay
« Reply #11 on: November 08, 2019, 08:29 AM »
Sedge posted a tip for scribing with the RAS yesterday: https://www.instagram.com/p/B4ibRLmJ1Ja/.
Inquiring Minds Want to Know
Online SRSemenza
« Reply #12 on: November 08, 2019, 10:24 AM »
In Sedge's tip he shows using just the front part of the pad for scribing. That also helps when using the Rotex to scribe.
Drag the the front in sort of a raking motion.
« Reply #13 on: November 08, 2019, 12:21 PM »
Use light pressure when making contact with just a small part of the pad lest you melt the hooks on the pad.
Offline bwehman
« Reply #14 on: November 09, 2019, 11:19 AM »
This was actually the reason for heading down this thought train haha. I’ve gotten rid of all the 125 sixes sanders to streamline the shop to either the RO90 or 150 sized papers, and the thought of adding another for the RAS seemed counterproductive, but would’ve been willing if it was super worth it. Doesn’t sound like it is. Thankfully, ha.
Online SRSemenza
« Reply #15 on: November 09, 2019, 11:56 AM »
It really depends on how fast you want to scribe. I would say the RAS will easily scribe twice as fast as the RO150 and with much less vibration.  Though I haven't used the RAS for that purpose yet myself I have seen full length floor to ceiling scribes done in person. It was waaaay faster than it would have been with the RO150.
« Reply #16 on: November 09, 2019, 01:09 PM »
Scribing with the RAS is very fast, especially with a very coarse grit (way coarser than you can get for the slower sanders). The scribed edge will be smoother than you’d expect but if it is too rough just stay away from the line for the first fast pass then do a final adjustment pass with a finer grit.
The very coarse grits make more sweepable dust but less airborne dust so it’s not crazy to do the scribing inside.
Offline Alex
« Reply #17 on: November 10, 2019, 02:53 AM »
Like others said above, I'll add for emphasis, but the speed difference is huge compared to the Rotex. What Sedge does there with the RAS in a few seconds can easily take 10 times longer with the Rotex 150. And he only does a very thin strip for demonstration purposes, wait till you have to dig deeper and do more complex shapes. The Rotex takes a lot more time.
As a guy who owned 13 Festool sanders at one point I always find the paper size argument odd, because especially for a professional I'd say it is much more important to have the right tool for the job. Your time is more expensive than a few extra boxes of paper.
