Author Topic: Sandpaper systainer  (Read 8715 times)
Offline lambeater
Sandpaper systainer
« on: May 22, 2010, 10:52 AM »
I started looking for a systainer to hold my 5" disc,s but can only find the one which holds 5 different sizes flat. Yet When I go up to the systainer for 6" it holds eight different sizes vertical. Is there a tray or systainer for 5" that holds more?
thanks
Lambeater
Offline Alex
Re: Sandpaper systainer
« Reply #1 on: May 22, 2010, 11:55 AM »
Nope.
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #2 on: May 22, 2010, 12:35 PM »
As for the 125 mm abrasive Systainer, I'm not a fan. It's too small for my liking. I made my own by tweaking Seth LS/RTS idea (link to talkFestool) a little. Systainer #2 with 16 slots. I've got seven 125 mm sanding pads for my ETS/RO125 sander and ton of paper. I'd guess I could get nearly twice as many discs in there that I have shown in the picture, if I packed them tight.
« Last Edit: May 22, 2010, 12:36 PM by Brice Burrell »
Offline RL
« Reply #3 on: May 22, 2010, 08:14 PM »
I have a Rotex 125 and I made a conscious decision after looking at both sanding disc systainers to use the 6" systainer. It holds all the 5" discs pretty well and I have a hand sanding block in there too.
I suggest you forget the 5" sys- you will be forever looking for the right pad as only 5 are visible at the same time.
Richard.
Offline lambeater
« Reply #4 on: May 22, 2010, 09:24 PM »
Brice I think you just made it easy for me.
Lambeater
Offline WarnerConstCo.
    • Warner Mill Works
« Reply #5 on: May 23, 2010, 09:41 AM »
I use a sys 3 for my 125 paper.
THey go in in full boxes.
Offline waynelang2001
« Reply #6 on: May 23, 2010, 11:53 AM »
Now that i finally have my sysports up and running i think i need to make a sandpaper systainer to..........CURSE YOU FOG!!!!!!!  I dont have money for systainers now but im sure i can sell some of my organs if need be.
Latest Festool purchase?? The CXS.....Next Festool purchase???? The Domino.....
http://www.facebook.com/pages/Langley-Woodworks/147551115290424
Offline rnt80
    • Agape Wood Design
« Reply #7 on: May 23, 2010, 12:30 PM »
As usual, nice job Brice.  I've got the 6" systainer and don't mind the configuration for the sandpaper but you're set up offers a little more versatility.  I don't have other pads that I need to store but if I pick some up I may reconfigure the systainer to accomodate them.
Russell Tribby
Gilbert AZ
www.agapewooddesign.com
