Author Topic: Sanding disks  (Read 684 times)
Offline pantherjoe
Sanding disks
« on: December 31, 2020, 01:52 PM »
Just got my first festool sander and needing info on sanding disks.Have heard a lot of good things about the 3M Cubitron.Any info to steer me in the right direction will be appreciated.
Offline Crazyraceguy
Re: Sanding disks
« Reply #1 on: December 31, 2020, 04:50 PM »
Festool Granat
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
Offline CeeJay
Re: Sanding disks
« Reply #2 on: December 31, 2020, 06:21 PM »
I just finished sanding all the components for a 2m x 1m outdoor dining table made from rosewood. Went through the papers 80/120/150/180/240. Used a single piece of Granat in each grit (except 150 where I have Rubin) they weren’t new when I started, they are still in good condition. No clogging, last pass was as good as the first, great dust extraction. Used an ETS EC 150/3 and a CT Midi.
So I can recommend Granat. Note the Rubin clogged more than the Granat and needed a clean after each pass - that’s the different  hole pattern I reckon.
Offline Thompmd
Re: Sanding disks
« Reply #3 on: December 31, 2020, 06:38 PM »
http://www.festoolusa.com/abrasives
There’s another link called topcoatreviews.com
Both provide a ton of info regarding using the best sander and best abrasive for the job.
I love Granat
Good Luck and Welcome to the Forum
Sawstop Industrial Saw, TS75,2 1400 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160
Offline pantherjoe
Re: Sanding disks
« Reply #4 on: January 01, 2021, 08:36 AM »
Re: Sanding disks
« Reply #5 on: January 01, 2021, 09:10 AM »
Cubitron
I've always wanted to try Cubitron II sand paper because I really like the Cubitron II discs that I use on the RA grinders. Currently I'm strictly Granat with a little Rubin 2 thrown in for good measure.
Here are some part numbers which may make it easier to track individual sanding discs down, this list was circa 2019 so it's still current.
* Cubitron II Part Numbers 2019.pdf (1762.45 kB - downloaded 19 times.)
Offline pantherjoe
Re: Sanding disks
« Reply #6 on: January 01, 2021, 09:21 AM »
