Author Topic: Sanding Disk Storage  (Read 915 times)
Offline mhmcgrath
« on: March 05, 2023, 03:31 PM »
Here’s a pic of a little project to store 150mm disks. Dowels and piece of 3:4 plywood to hold down disks. Labels on those ply pieces make rearranging easy. Bolts attach to alum rail at end of Dashboard bench. What do you think?
Offline Coen
Re: Sanding Disk Storage
« Reply #1 on: March 05, 2023, 05:31 PM »
For me it would be too exposed. To much dust, dirt, humidity and sunlight on the discs. Also hard to take with you. Hence I have them in a Systainer.
But if you go through them at a much higher rate in the same workshop; nice!
But you have a bunch with older hole pattern, so I wonder about your volume   [tongue]
Offline mhmcgrath
« Reply #2 on: March 06, 2023, 08:28 AM »
Thx for your observations. Shop is climate controlled and limited sunlight. I also have the Systainer storage for remote use. Some grits less used - old inventory - still work fine for me when needed. Just needed a simple, quick access at my workspace. Looking for ideas on the “net” sheets I’m starting to use. Especially, for delta sheets and the inline (rectangle) sheets.
Offline Packard
« Reply #3 on: March 06, 2023, 08:41 AM »
There was just enough room behind my chop station platform for a shelf to accommodate 5” discs in their original cartons.  I have sanding discs from 40 grit to 600 grit organized in sequence.
The top discs in each carton accumulate saw dust, but that cannot be harmful for a sanding disc.  By the time they are installed, most of the dust has fallen off.  I marked the cartons with bold markers as to the grit number.
It does require I walk about 10 feet from where I usually do my sanding operations, but the unused space is now used.  I’m pleased with it.
I buy my discs from Amazon in boxes of 100 discs.  Very economical, but the 100 discs last a long time.
I cut the lids off of the cartons for easier access.
« Last Edit: March 06, 2023, 08:48 AM by Packard »
Offline mhmcgrath
« Reply #4 on: March 06, 2023, 11:22 AM »
Online Crazyraceguy
« Reply #5 on: March 07, 2023, 06:57 PM »
I keep a small vertical rack for dispensing a few discs at a time on my back bench. The bulk of the stock I keep is stored in the original boxes. They fit behind the Systainers on the pull-out. When the cubbies get low, I pull out a few more.
This is an old pic with no-hole paper for my pneumatic sander. I don't use it much anymore, so the shelves go refilled with the 9 hole variety. I labeled them with a Dymo machine too.
I don't have to be mobile, so that's not a concern, at least now. That may change at some point, then a Systainer will likely be the way to go.
« Last Edit: March 07, 2023, 07:02 PM by Crazyraceguy »
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
