Author Topic: Replacing CT power cord  (Read 601 times)
Offline morts10n
« on: September 08, 2021, 01:45 PM »
Both my CT Midi and CT 26 have lost the ground prong from the power cord. Is replacement by user possible/easy enough?
Offline Alex
Re: Replacing CT power cord
« Reply #1 on: September 08, 2021, 02:50 PM »
I find it easy. You need to know how a screwdriver works. You need to open the shell of the vac. The cord goes in on the backside of the vac and then led to the front where it connects to the circuit board.
Start with the Mini, that one's easiest because it is the smaller of the two. You only need to unscrew 4 screws to take the top apart.
Offline cpw
« Reply #2 on: September 08, 2021, 02:56 PM »
I had the same problem with my CT26.  It's not very hard to replace, the cord gets routed from the back to the front and there is plastic a piece on the side that clamps it in place.
Offline woodbutcherbower
« Reply #3 on: September 08, 2021, 08:26 PM »
This is the FOG. Unless it costs $$$$$$$$$$ and comes in a fancy box, your helpful post will be totally ignored.
There's no such thing as a job which is almost perfect. It either is perfect - or it isn't.
Offline manuc
« Reply #4 on: September 08, 2021, 08:46 PM »
I would just replace the plug itself because it’s just going to happen again. I hadn’t used my CT for all that long and I never pulled on the cord before the ground prong came out. I bought a heavy duty one from Lowe’s.
Offline SRSemenza
« Reply #5 on: September 08, 2021, 11:28 PM »
If you go the plug route ............................
I have found that these Plugs by LeGrand - Pass and Seymour are very nice on heavier gauge power cords. Wire up easily, pretty robust, nice grip. I have seen them in orange, black, yellow and gray. I have used about ten of them over the years with good results.
« Last Edit: September 08, 2021, 11:31 PM by SRSemenza »
« Reply #6 on: September 08, 2021, 11:54 PM »
I'd also just replace the connector on the end of the cord. Stick with an industrial rated connector such as Pass & Seymour, Hubbell or Leviton. They aren't as pretty as the standard Festool over-molded version but they are a lot more durable because they're manufactured from nylon, that's what gives them their strength. Over-molded is pretty, it's just not as durable.
Offline Jim_in_PA
« Reply #7 on: September 09, 2021, 09:24 AM »
Just replace the connector. Easy to do. The single thing that requires extra care when re-terminating a cord like that is when cutting off the cord jacket to not nick the insulation on the individual conductors inside.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
