I don't think it's intended for finish cuts. Breaking down thicker solid wood can be a bit variable in the first place. You can't really expect it to remain straight. The tension released can move it either way, so a "finish" cut probably isn't needed. Just getting it apart is the goal, let it do it's thing, then hit the jointer. There may be exceptions of course.
Fine teeth when ripping can overload the gullets, because the "sawdust" isn't dust. Some species are more exaggerated than others, but it's normally long curly shavings, even more with true flat-top teeth.
With thin material, it doesn't matter nearly as much. 8 quarter, you'll notice it.
