Author Topic: Random Orbital Sander ETS EC 125/3 EQ-Plus variable speed?  (Read 786 times)
Offline Scott V
« on: November 18, 2021, 07:56 PM »
Looking at Random Orbital Sander ETS EC 125/3 EQ-Plus on the Festool USA website I see no mention of variable speed capability under either "Functions" or "Technical data".  The Festool UK site says it has "Continuously variable speed" of "6,000-10,000 RPM".  Which is correct?
Offline afish
Re: Random Orbital Sander ETS EC 125/3 EQ-Plus variable speed?
« Reply #1 on: November 18, 2021, 08:03 PM »
I just got an ets ec 125 from Hartville a month or two ago and it is 100% variable speed.  Not sure of the min. max RPM's but there is a small green dial on the US version too.
Offline Scott V
« Reply #2 on: November 18, 2021, 08:05 PM »
Thanks.  Looks like maybe Festool engineering genius didn't infect the web marketing group.
Offline squall_line
« Reply #3 on: November 18, 2021, 08:29 PM »
The ETS EC 125/3, having the exact same internals as the ETS EC 150/3, has the following technical specs (copied from the 150 PDF manual, and reads the same in my 125 manual that I have in my hand):
Eccentric sander ETS EC 150/3 A EQ
Power   400 W
Idle speed 6000 - 10000 min-1
Sanding stroke 3,0 mm (0.12 in.)
I don't think I've seen a Festool sander without a variable speed control.  That said, I haven't seen every single sander they've ever made, but every one I have of theirs is variable speed (RO 90, ETS EC 125, 150, ETS 125, RTSC 400).
Offline Scott V
« Reply #4 on: November 18, 2021, 10:39 PM »
Good info...thank you.
Offline ScotF
« Reply #5 on: November 19, 2021, 12:04 AM »
They all have variable speed.
Offline notenoughcash
  • to many ideas, not enough cash....
« Reply #6 on: November 19, 2021, 02:48 AM »
the only sander i have ever seen without variable speed is a crappy bosch green mouse style sander that cost about 15 quid and vibrates your hand off by looking at it.
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the bl**dy thing you just put down
Offline mrB
« Reply #7 on: November 19, 2021, 08:16 AM »
Just to muddy the waters, I believe festool have made non variable speed sanders until relatively recently. .
I think the DTS/RTS family had a cheaper variant without the variable speed. So be mindful of buying an older second hand variant of the dts/rts/ets sanders. Might be imagining it, but fairly sure that was a thing. .
Offline Alex
« Reply #8 on: November 19, 2021, 03:28 PM »
It sure was. I have one, RS400 Q, without electronics. I like it better than those with electronics. At least now I'm 100% sure it is always at full speed. With the other ones I have, the speed dial has a tendency to dial down because of the vibrations. And accidental touches. Just like with the car, I don't need any speed less than 100%.  [tongue]
