For small parts, the track saw is a very good choice, though the technique may need to be a bit different. Think more like "fixturing", where you make some kind of holding device for your parts that has some kind of stop to reference the track against. This is very repeatable and far safer than a table saw.
With the exception of purpose-built sleds, small parts are not exactly table saw safe.
Yhea, that's exactly my experience
not bad, but it takes a little bit more time. Without a good work-area, it's a hassle at the moment, but doable. I want to improve that. But later on that
1) There is the MFT/3 table including the rails and the angle stop. Is this the older version of the newer FS-WA kit (+ extension)?
No
2) On either the MFT/3 & FS-WA angle stops, you can make smaller repeatable cuts, do they hold up their precision against the FS-PA-VL parallel guide?
Sure
3) Am I right to think that the parallel guide is made for wider rips, instead of cross cuts like the angle stops?
What angle stops? The parallel guides are good to cut longer pieces to the same width of a larger sheet.
Thanks for the explanation Coen, wave from the Netherlands back
1) Thanks, how do they differ in purpose? I saw that the old protractor can be a little higher for a bunch of smaller stapled stuff. And th e way it connects to the track saw a bit different. I enjoyed the idea of having some form of mft/side table where I could connect a lift/attachment for the rails and just lift it, and put another thing under. Having it set, it's easier to keep than moving it right now.
The new angle unit is in that sense a little less practical, but it I guess working around it. Not a biggy.
2) Cool, thanks.
3) Cheers... it seems with the extension bar, which is not too expensive, and may just leave the parallel guide for what it is, as I usually don't do large slabs (and just have it cut roughtly at the place where I get my wood)
Before you go MFT/3, I would look at the Ron Paulk system and the Peter Millard MFT series.
Cheers, I have seen the Peter Millard MFT series, as well as the New Brit Workshop and David Stanton's ideas. Like the channels a lot.
The "problem" with these systems is that they are not foldable. I know that's not idea. But I'm not in an ideal situation. I am working on an angled slope where you usually park your car in front of your house.. that's my workspace. And I need something foldable as I don't have the space for a permanent set-up, nor the space for a bigger movable table.
The MFT Kapex, MFT/3 or the Mobile workstation (mw-1000).
Not that they are better than the MFT, but the original Festool MFT is geared heavily to site work which is not always well-aligned with what a hobby user does/needs.
Indeed... I know below here is mentioned a vice, which makes sense. I don't use a vice that much (yet), but I probably will. In one of the videos, one guy that makes a table on a budget, made some specific stuff for a handplaner, which was pretty cool.
Also, before any expensive MFT style thing, I would look heavily to the TSO Parallel guide system (without the GRS). It does not require any serious infrastructure and you can achieve precision -and- repeatability with it which you would be hard-pressed to tune to with an MFT. And all that without needed any serious experience.
This is a great set. Thanks. As I quoted Coen, I think for now, I'll keep it at the protractor, and calibrate it... ill leave the parallel guide for later perhaps
this would be a good option!
Lastly, if you have the FS-WA, do make sure to ged a high-precision reference square for calibrating it (aka DIN class 1 orbetter equiv.). That way it can completely replace a need for the TSO GRS and equivalents.
ADD:
As this is like 10th thread on this topic, I checked and there does not seem to be "normal price" precision squares on the US market beyond the DIN class 00 level Starret pieces which are an overkill here. Probably comes from the fact there seems to be no US standard for precision squares.
As such, here is what I would recommend, they are 1/3 the Starret at a bit less accuracy but still very hard to beat the price/quality here as DIN/0 is vere close to the Starret master square class at 1/3 the price:
https://taytools.com/products/kinex-machinist-square?variant=17828742594611
https://taytools.com/products/kinex-flat-machinist-squares?variant=18077144940595
DIN 875/0 means 10 microns (0.010mm/0.0004") maximum error over the 250mm length. This is like 5x better than the normal "precision squares" I saw on Amazon for $20 or so ...
For squaring cuts, the 250/165 size is just about the right size as has enough reference surface to use directly with wood.
Disclosure:
No affiiliation, is a local company which I know very well. (https://www.kinexmeasuring.com/en/)
Thanks a lot, I've read tons of topics about this on this forum indeed
I don't want to get into it. But you're right. Expensive, even the cheaper ones, but this is one of those tools that better be dead on, as you need a reference point. I saw the Woodpeckers one. They are beautiful. Not out of my reach, but they are just too expensive for my hobby work. The ones you mentioned are great. I can't get all the USA stuff here in the EU, but there are some affordable ones. Like Kemmler Germany, 100,- for a 300mm one. Ill do some more research there on the items you've mentioned.
I would add to Coen here.
He is a pro and as such is right that - if you already have a good way to make shorter cuts - the parallel guides role would be limited to longer cuts.
However, there is nothing preventing you to use the PGs for short cuts even in the 10" cut length category even. It is just that shorter cuts can usually be done via faster means, e.g. using just a one-sided square like the FS-WA or the TSO GRS, or the MFT/s with a stop, or even a compound mitter saw etc.
So usually people with proper shops would not use the PGs for that. But they can definitely be used to make such cuts. It is just a question of speed/convenience.
Cheers
that makes sense indeed.
Although I have 2 MFTs, I recommend looking at the DashBoard table system. They have a small workbench that seems to be a lot more stable than the MFT and has a far better rail/hinge system.
If I were starting out again. I'd buy the MFT top, the DashBoard hinge, and a Festool rail. I'd build a base for the top and (most importantly) include a nice big woodworking vise.
I added an extension to my MFT to accommodate a full size vise that I use all the time. The extension uses steel legs that add a lot on stability to the MFT.
Thanks, I didn't know this system yet. I'll have a better look. Did a fast one, but initially, they are looking big. I mentioned I need to work on a slope, those mft tables, mobile or not, all cannot have adjustable lengths. Obviously, as they will have less sturdyness. I really need to solve some issues regarding this. Perhaps a couple of very study and adjustable sawhorses, and DashBoard system... it's a bit of a differet discussion of this thread I guess
need to read more about this.
I'll just add a little bit to what mino has said. Starrett Master Precision Squares are guaranteed accurate to .0001" for every 6" (.0025 mm for every 150 mm) and are available from Starrett with a SLC, Standard Letter of Certification.
If purchased brand new from a conventional tool house the Starretts are indeed very expensive. However, there are lots of machinists retiring and machine shops are closing their doors everyday so I've found that these can be purchased on the used market for pennies on the dollar. For example, I purchased a Starrett 20-6 that retails for $420 for $70 and a 20-4 1/2 that retails for $315 for $45.
Because these items are used as "Standards" they are usually well taken care of because they don't see daily use. It's not unusual for a used Starrett square to be in like-new condition.
Makes total sense. Every two year, wonder if I am able to do that. Of course, I do not need that form of precision, but it will make things alot easier and dependable. I can recall myself that I just skipped some measuring steps thinking I can sand it later on to make it work. And it was fine...after spending a day on sanding it precisely how it had to be. So.... that's me told there
Thanks all. My questions are answered regarding the repeatable stuff. The next thing, the square and the table... that's a new adventure
