Author Topic: protecting a new MFT top  (Read 1097 times)
Offline HowardH
« on: November 02, 2022, 08:18 PM »
I just finished creating an oversized MFT top out of MDF.  In the past, I used to apply a coat or two of paste wax as a protector to keep glue from sticking to it.  Is there anything else I should be considering like applying a coat of lacquer sealer first or maybe wipe on poly?  What works best for you?
Howard H
P1cc, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1400 holey, 1900 rails, OF1400, OF1010, CSX, C18, LR32, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, PM 1500, Jet J/P, FS-WA, Shaper Origin. Felder AF-14, TSC 55 KEB, Dash-Board bench system
Offline Adamsse
Re: protecting a new MFT top
« Reply #1 on: November 02, 2022, 09:15 PM »
Based on some suggestions I saw, I applied a couple of coats of dewaxed shellac on my two MFT tops, being careful not to let it get down the holes.  I’ve been happy with that.
Offline HowardH
« Reply #2 on: November 02, 2022, 09:24 PM »
did that prevent glue from sticking to it?
Howard H
Offline Adamsse
« Reply #3 on: November 02, 2022, 09:57 PM »
While I am not in the habit to let glue dry completely on my primary 2-MFT set up, I have been able to scrape it up easily after glue-up is complete. I consider my MFTs a working surface so don’t expect a flawless result. But again, I’ve been happy with what the pre-waxed shellac does.  If I spill something unexpectedly, it’s much better than before I put the shellac on.
If I have a really sloppy glue-up, I place a combination of one to four 2’x4’ 1/2” plywood sections on sawhorses that have 3 coats of dewaxed shellac on each side of them.  I used the LR32 system to drill 20mm holes at 96mm intervals on them so I can use Festool clamps where I need them.  When I’m done, I scrape up the glue, and the sections and sawhorses easily fit in a small corner of my garage.
Offline James Carriere
« Reply #4 on: November 02, 2022, 10:41 PM »
I've done 3 to 4 coats of tung oil and have been happy with that.  Easy to apply and glue pops off easily after it's dry if you missed it previously.
Offline mattgam
« Reply #5 on: November 02, 2022, 11:40 PM »
Being a "if it goes in my shop slap some Osmo on it" guy I've recently discovered it really does a nice job sealing up MDF.  Now with that said shellac+pastewax costs next to nothing and works like a charm as well.
Offline Mini Me
« Reply #6 on: November 03, 2022, 09:25 AM »
I'm a hit it with a hammer and move on type, it is a work surface after all and it will suffer damage so I may as well start with the first damage.
Online TXFIVEO
« Reply #7 on: November 03, 2022, 09:48 AM »
I’ve used Seal Coat and Osmo with excellent results.  While it is a work surface I still like to take care of my stuff.
« Last Edit: November 03, 2022, 09:50 AM by TXFIVEO »
