Those who complain about the Precisio's accuracy compare it to steady cabinet saws where every part weighs 5 times as much. Duh. Some people seem to have a very hard time to understand they are meant to be mobile.
I find my CS 70 Set very accurate. When I got mine used I went over it and found lots of screws in there on many parts that can be adjusted. I tuned it to my satisfaction, and it just works, always. My corners are always 45 degrees exactly.
I like the standard adjustable fence very much, always accurate and can be positioned along all 4 sides of the saw, which comes in very handy. But, like Garry, I don't get along with the LA fence either. I only use it when cutting bigger pieces, and I took out the fine adjustment as it makes the fence hard to move. It is also difficult to align it straight as front and back brackets can be out of line. But if you care to take the time, you can set it dead straight.
