I’m essentially in the same boat with CT36 and Planex 2. I picked up the harness 496911 and that has the old style Systainer. This doesn’t want to stack with any of my gear. I noticed however that there is also a 576802 that comes in a systainer 3 that at least will much more easily stack. Any thoughts from anyone on that one? It looks like the 576802 is an older one that isn’t made anymore but a few stores still carry it, both appear to have very similar contents.
Man. I wish I had seen one with the systainer3. I have the other one with the maxi and I cursed when I got it.
I love the Planex 2. Works great. I very much dislike the containers.
So far a have a love hate relationship with the harness. I like that it sort of works. I obviously have issues with the pay it works with the Planex 2. Pushing the hose to the side sort of works, but after an hour or so the pole has slipped to the side. I'm not convinced this is the best approach. So much so I am thinking of getting an extension and hacking down to 180 the handle.
I want to like how this thing rigs up, but it needs some design changes. It needs some quick adjusts. Like a drop for the cup to get the tool loaded and then pull up into position.
I want a quick release on the handle or a way to adjust it up and down while working. Pain to put the whole thing down and make micro adjustments for comfort over time. I don't like the screw attachment.
There should be a quick release way to slide the pole up and down the Planex to adjust reach. You have to break the whole thing down to move the pole.
For typical US 8' ceilings it's easier to put the handle on without the pole and stick the butt of the handle on your hip. Hurts after while, but its more maneuverable and fluid. With the harness you feel like you are using all of your limbs to move the Planex around. It's both easier on your back, but at time having to dip and pivot is harder on your lower back.
So far I think I like the harness for removing stipple or doing anything that easily forgives some gauges. The risk of divots is 5x with harness because you use some leg movements for pressure and walking and moving perfectly is hard.
I used it on a few walls. If I were going to do more walls I'd want the head to pivot like the Mirka/Hilti. Could be I need to spend more time with it to understand how to get a full ceiling to floor stroke.
