I'm a novice wood worker. I don't find the LR32 system easy to use, because i don't use it everyday. Please allow me to share some of my learnings.
1) Follow Sedges guide to set up the rods, make sure the block that attaches to the guide rail IS attached to the rail and make sure the locking nut is tightened up. The locking nut doesn't need to be "white knuckle tight" but it does need to hold the block on the rail. Make sure the block is sitting FLAT in all directions, I've found the block doesn't always sit flat on the rail. Make sure the block with the guide pin is pushed down flat on the workpiece and not forced into the cut out on the router base plate. Sedge does SHOW this in the video. The guide pin is spring loaded so if it's pushing DOWN on the bench is cause the rod to lift up.
2) When you're using the system, make sure you set the same number on both rods, e.g. 37mm on BOTH. It's very easy to set them up incorrectly because of the black measurement scale on the moving block with the pin. Put the rods on the guide rail as far apart as you can and make sure they sit FLAT in all directions (see point 1). Make sure the locking nut is tight (see point 1). Make sure the pin is touching the edge of the workpiece, try not to bang the pin against the workpiece, it can make the rod lift up. Watch out for the pin pushing down on the bench below the workpiece.
3) CLAMP THE RAIL TO THE WORKPIECE. This is important!!
4) I then swap the rods around to double check the alignment before I start drilling holes.
5) When you attach the router to the guide plate make sure the attachment screws are tight so the router doesn't move on the plate.
The more you use the system the better your skills become and the faster you get at setting it up.
Regards
Bob
