Author Topic: OFK 700 or MFK 700 - that is the question…  (Read 5144 times)
Offline Bert Vanderveen
« on: October 23, 2015, 10:51 AM »
I need some advice. Need to decide which is the better machine for me. I have a fairly large personal project coming up where I need to do quite a lot of edge banding (with unglued veneer), but I also want do do some repeatable profiling on solid wood parts for furniture in the near future.
So what do you think (esp. Fog-ers that use these machine) — which one is the right one for me?
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline TylerC
Re: OFK 700 or MFK 700 - that is the question…
« Reply #1 on: October 23, 2015, 11:47 AM »
Because the OFK 700 isn't available in the U.S., I don't have an opinion on it. However, here's an old thread that might help you a bit: http://festoolownersgroup.com/ask-festool/whats-the-difference-between-ofk700-and-the-mfk700-routers/msg398290/#msg398290
This account is retired. Please address all Festool questions to @festool usa.
Offline Kev
« Reply #2 on: October 23, 2015, 03:28 PM »
The two models have always confused me. I'll be watching this thread to see if I can learn something!
Offline F3STOOLVIKING
« Reply #3 on: October 24, 2015, 05:36 AM »
Hi
I went thru the same dilemma when the choice came between these two. I went for the OFK eventually. A good thing to know is that you can add on accessories to make an OFK out of an MFK and the other way around (Use the EKAT for parts). It is the same motor on both and like stated before the difference is the ski-foot/bearing-guide on the OFK and the "more solid" vertical base with optional parallel edge guide on the MFK.
I have not used the MFK but when using the OFK for vertical routing I sometimes feel a "more solid" base would be good, like on the MFK. When I say solid I mean that the routerbase on the MFK seem to give a better support all around the bit when routing, as on the OFK where the horisontal base used in vertical mode you need to push the base (on the knob) towards the material to prevent the router from tipping over.
The vertical base on the MFK also got the parallel edge guide that will give a better support against the edge than the ski-foot.
I also believe the dust-extraction in vertical mode is better on the MFK.
One of the reasons I went for the OFK was that I have the OF-1010 router that covers most of my vertical work. If I was to make the choice today I would probably go for the MFK, but that is purely based on my personal preferences.
Festoolviking  [smile]
Festoolviking
