Author Topic: OF2200 Question - why get the accessory set ?  (Read 3710 times)
Offline kifi
« on: November 14, 2022, 03:10 PM »
Hi All
I am researching whether or not to invest in an OF2200 after recently trying to edge profile some 45mm solid ash with my OF1010 which didn't go that smoothly.
From researching posts here, it seems that most recommend getting the accessory set with it but I am not sure why this is so. It appears to mostly contain copy rings. My workflow tends to use bearing guided bits.
Does lack of bearing guided 12mm shank cutters influence the decision to buy the accessory systainer too ? Are there other reasons too?
Online luvmytoolz
Re: OF2200 Question - why get the accessory set ?
« Reply #1 on: November 14, 2022, 03:25 PM »
Firstly let me just say the OF2200 is the best router ever made IMHO. You would not regret buying it, it really is just a beautiful piece of engineering and a sheer joy to use! The power, smoothness, and control of it is astounding.
The kit while expensive as all things Festool are, actually has some really useful components. The micro adjustable fence for starters, the large support base, and the base for using with the guiderail are all extremely handy. Plus it does come with a number of template guide rings.
For me the guiderail base and the template rings are something I would use often, and as the individual cost is so high, it made sense to just get the set. A couple of the bases I may never end up using, but they're there if needed, and the set as a whole is very useful.
I guess you'd want to ask yourself if you'd possibly be doing a lot of template work, inlays, etc where the template guide rings would be useful. Or if you'd be using the fence or guiderail to machine dado's, or use ogee cutters to groove panels, make backing boards, etc.
If you're only ever really going to use a narrow selection of bearing cutters, you may not need the set, but once you start branching out a bit it is really handy to have the set on hand.
Offline kifi
« Reply #2 on: November 14, 2022, 03:42 PM »
thanks, I had forgotten about the edge guide and guide rail adaptor. I guess having is better than needing! Might go for the full set. Looking at Festool catalog I wonder why they offer few if any bearing guided cutters? (I know third parties probably offer more than you'd ever want, but Festool doesn't see a 12mm bearing guided bit as a core use for the OF2200 for some reason.)
Offline woodbutcherbower
« Reply #3 on: November 14, 2022, 08:29 PM »
Quarter-inch routers such as the OF1010 are perfectly suited to edge profiling with bearing-guided cutters - it’s probably one of the most everyday, common applications for this size of machine. I can’t figure out what could possibly have gone wrong - other than running the router in the wrong direction and having it grab and bounce off the workpiece.
What kind of profile were you routing, and what was the problem exactly? Could you post a photo?
And btw - being from Ireland, you have access to the range of Trend cutters which is absolutely massive, including a huge array of bearing-guided cutters. The shank sizes aren’t 12mm - they’re 12.7mm and 6.35mm - the metric equivalent of 1/2” and 1/4” which are standard UK collet sizes.
« Last Edit: November 15, 2022, 06:29 AM by woodbutcherbower »
Online luvmytoolz
« Reply #4 on: November 14, 2022, 08:46 PM »
Honestly as much as I love Festool gear, router bits would be the last thing I would be buying off them!
Offline Oilers
« Reply #5 on: November 14, 2022, 09:51 PM »
I bought the set.
When you do, make sure you pick the right package.  I mistakenly ordered imperial when I wanted metric.
The alternate bases are excellent and are so easy to use.
Offline kifi
« Reply #6 on: November 16, 2022, 04:00 PM »
It was just a floating shelf from solid ash. I'll check out the Trend line. Maybe Wealden Tools too.
« Reply #7 on: November 16, 2022, 04:57 PM »
But what was the problem? What went wrong?
Offline kifi
« Reply #8 on: November 16, 2022, 05:55 PM »
It was taking too long
Offline Peter Halle
  • No Power Tools Required
« Reply #9 on: November 16, 2022, 06:28 PM »
Regarding the original question, when I finally get around and buy a 2200 I will by the accessory kit.  Why?  Honestly because at some time the 2200 will go away and then I will find a need for something in that kit and kick myself in the arse time and time again.
Offline Crazyraceguy
« Reply #10 on: November 16, 2022, 06:38 PM »
As dumb as it sounds, I'm thinking the same thing. That is quite an expensive tool to buy "just because", but honestly the thing holding me back is the plug-it cable.....lack of actually.
I really like the simple disconnect feature.
Practicality is also becoming more of a thing too. With retirement coming, my need for heavier-duty may not be there. I have gotten along with the OF1400 and big Triton router in the table, for a long time, and see no reason that they can't continue to do what I need.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Offline Peter Halle
« Reply #11 on: November 16, 2022, 06:44 PM »
@Crazyraceguy , funny that you wrote that.  I haven't really mentioned it but I have now basically retired.  I have been working on and off trying to adjust to working out of space I never had before and consolidating tools all in one place while doing the various honey-dos.
I almost waited too long on the Vac-Sys and the 2200 is one of those legacy tools that rarely do you hear a bad thing about it after the credit card bill comes in.
Just do it!
« Reply #12 on: November 16, 2022, 06:52 PM »
I'm about 8 months from it, if all goes according to plan. Most of the things I will be working on, at least initially, will be the shop furniture. Then the plan is to finally remodel my own kitchen. Over the years, I have updated the rest of the house, saving the kitchen for last.
It would be easier to do it now, but I really want to do it right here at home.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
« Reply #13 on: November 17, 2022, 12:22 PM »
@Peter Halle @Crazyraceguy the OF2200 + accessory kit is the single most expensive power tool I ever bought, even making some of my Hilti equipment look bargain-basement. For the class of tool though, it's also the best - miles ahead of the game in every possible way. Apart from the additional quick-change bases and numerous guide bush (copy) rings, the micro-adjustable parallel fence is superbly well engineered, and this also has a separate clip-in dust port allowing an extractor hose to suck from underneath for edge routing. Those Germans are so, so clever. The guide rail adaptor also works exceptionally well.
I may well be wrong, but I heard (somewhere?) that the current draw of the router at maximum full-bore load exceeds the rated current capacity of a Plug-It connector. The captive power cord's the size of a small fire hose.
HUGELY recommended.
Kevin
« Last Edit: November 17, 2022, 05:21 PM by woodbutcherbower »
Online DynaGlide
« Reply #14 on: November 17, 2022, 12:27 PM »
@Crazyraceguy FWIW I had the 2200 and accessory kit and sold it. It didn't do anything for me that the 1400 couldn't. I think I fell into the trap of "It's Festool so I should probably own it" and also the other trap of "It has superb power and dust collection." While the first trap I'll leave to the collectors the second one just didn't fit for me. I have never found a situation where I thought I needed more power out of my 1400. And I had it in the CMS table for a while doing double duty as my router table motor.
Matt
Instagram @matts.garage
« Reply #15 on: November 17, 2022, 05:23 PM »
I may well be wrong, but I heard (somewhere?) that the current draw of the router at maximum full-bore load exceeds the rated current capacity of a Plug-It connector. The captive cable's the size of a small fire hose.
HUGELY recommended.
Kevin
I have heard that too. It does seem to make sense. Could it also be a side effect of age? How long has the OF2200 been around? Is the design from before the Plug-it existed? That the reason for the lack of Plug-it on the RAS115, from what I have been told anyway.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Online luvmytoolz
« Reply #16 on: November 17, 2022, 05:40 PM »
HUGELY recommended.
Kevin
The 2200 is not that old a router so i don't think it's an age thing although I could be wrong, I think it's just the same as for the planer and belt sander being fairly high powered tools. Having a fixed cord on all three of those tools has never bugged or inconveienced me in the slightest. If I had a need to plug it with multiple other tools into the dusty, I'd just use a powerboard.
« Reply #17 on: November 17, 2022, 05:47 PM »
It's not really about the cord while "in use". As lazy as it sounds, the annoying part of the RAS115 not having a Plug-it, is winding it up when I put it away.
I keep a Plug-it connected to both CTs and disconnect whatever tool was being used, leaving the cord hanging, with the hose.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Offline Peter Halle
« Reply #18 on: November 17, 2022, 05:55 PM »
HUGELY recommended.
Kevin
When the 2200 came out and questions were asked about 1.  It being available without a Systainer, and 2. Not having a plug-it cord, the answer was that Festool thought that it would be mainly used in a shop situation and would be unlikely to be put away.  Thus the permanent cord and just a cardboard box if desired (the setup with a Systainer was also available.)
It came out in the 2008-2009 time period I believe.  Plug-it cords were already in use then.
« Last Edit: November 17, 2022, 05:57 PM by Peter Halle »
« Reply #19 on: November 17, 2022, 06:47 PM »
I'm very much in a shop situation, but I still put things away.
With the minor exceptions of a dead-blow mallet and a narrow-crown stapler, everything has a specific place and goes there every night. I very much appreciate the Systainer concept and wish other tool manufacturers would get it together.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Offline JimH2
« Reply #20 on: November 18, 2022, 12:22 AM »
My 2200 came in a Systainer made for it. Not quite sure what the talk is a obout it not having a Systainer. The lack of a plug-it cord is a non-issue. I have never understood why people get worked up about plug-it. Festool is the only company I know of that using plug-it and it's good, but nothing that stopped me from buying other company's tools.
Online luvmytoolz
« Reply #21 on: November 18, 2022, 01:53 AM »
Mine also came in a systainer as they all do now I believe, it's worth mentioning though that the power cable is far thicker than the plug-it cables, so maybe it's a combination of factors and/or a physical size or strain limitation of a plug-it cable?
« Reply #22 on: November 18, 2022, 09:20 AM »
All this 2200 chatter got me curious, so this is very interesting.
An OF 2000 router in 2007 in a cardboard box was $430.
An OF 2200 router in 2008 in a Systainer cost $800.
Offline squall_line
« Reply #23 on: November 18, 2022, 10:22 AM »
I saw an OF 2000 E come up on eBay recently and did some research to see if it was worth getting for my CMS.
The posts I found here on the FOG (through a Google search) kept me from bothering to bid.
The 2000e and the 2200 are significantly different from each other in features, especially dust collection and through-table adjustment.
The 2000e on clearance was cheaper than both the 1010 and 1400 at the time.  [blink]
The 2000e on Recon was only 200 bucks.  [eek]
The 2000e I found on eBay was listed apparently using the 2200 as a price reference, even though it was never priced in the same category as the 2200.
Online rvieceli
« Reply #24 on: November 18, 2022, 10:59 AM »
I’ve got an OF2000. I believe it was made by Mafell for Festool based (I believe) on the old tried and true ELU design. It is a beast but not as refined as the 2200.  [tongue]
As I recall I picked it up from the recon sale for $200 in its custom cardboard box.  [tongue]
Ron
« Last Edit: November 18, 2022, 01:30 PM by rvieceli »
« Reply #25 on: November 18, 2022, 01:23 PM »
It might have come from Holzer. The MFK 700 is nearly identical to the old Holzer edge trimmer. I think I read somewhere that Holzer made routers for both Festool and Mafell. When Festool bought the Holzer portable power tool factory around 2001 they inherited the belt sanders and who knows what else. Maybe the OF 2000 as well?
Offline mino
« Reply #26 on: November 18, 2022, 03:46 PM »
Matt
IMO your "problem" here was being US-based /limited 8mm cutter availability/ and having the OF1400 which is kinda "duplicit" with the OF2200.
The ideal hobbyist combo - to me - is OF1010 + OF2200 for those 10% tasks where the OF1010 does not cut it.
Offline kifi
« Reply #27 on: November 18, 2022, 03:56 PM »
Not really specific to the OF2200 , but is an accessory to it and the OF1010 / 1400 but has anyone bought the expensive plexiglass OF-FH ? Useful for routing on edge of doors for mortise locks and hinges but cost a lot for what it is
Offline squall_line
« Reply #28 on: November 18, 2022, 05:14 PM »
There are entire threads dedicated to that particular accessory.  I only have one because I found it listed for cheap and it's compatible with all three plunge router models so I figured why not.
« Reply #29 on: November 18, 2022, 06:49 PM »
Most of the talk about that has been about making one rather than buying it.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
« Reply #30 on: November 19, 2022, 12:56 AM »
Why would any sane person try and use a huge OF2200 to rout 75mm x 25mm x 3mm deep hinge slots along the edge of a door which might be only 35mm wide? It’s the very definition of a disaster waiting to happen. A quarter-inch palm router with a 19mm hinge cutter, and a parallel fence is the correct combination. The slot for the mortise lock gets cut with a spade bit and a sharp chisel.
Online luvmytoolz
« Reply #31 on: November 19, 2022, 01:41 AM »
Unless you have a grooving jig that makes routing mortise lock slots ridiculously easy and extremely accurate with the extended reach of the OF2200!
« Reply #32 on: November 19, 2022, 02:25 AM »
A lovely gadget for sure - and yours for only £265 RRP in the UK. But the job’s only half done. It won’t help you to rout the lockbox recess in the door frame - or the rebate for the lockbox faceplate - or the deeper chamfered recess for the angled striker plate ……
« Last Edit: November 19, 2022, 02:28 AM by woodbutcherbower »
Online luvmytoolz
« Reply #33 on: November 19, 2022, 03:49 AM »
Unless you have the lock fitting jigs (some of which are in attached pic)! ;-)
I also made the groove jig myself, it probably cost me around a 1/3rd of the Festool one as I had to use easily available but expensive materials and parts. I ended up selling it shortly after finishing it as I'm now working on a ver 2.0 model. Probably hard to tel from the pic but for better or worse it's all 20mm thick perspex, not 1/2" as is Festool's one.
« Last Edit: November 19, 2022, 04:47 AM by luvmytoolz »
« Reply #34 on: November 19, 2022, 10:38 AM »
@luvmytoolz You made that grooving jig yourself ??  [eek] That’s very, very impressive !!
Offline Coen
« Reply #35 on: November 19, 2022, 02:01 PM »
Huh no? There are four of them, yes, but in value it's only a tiny part. The bases and the parallel guide are most of it's value. Especially the base that is fatter by 5mm for half it's width is usefull when using the 2200 with the guide rail.
Offline Coen
« Reply #36 on: November 19, 2022, 03:04 PM »
There is a lot of work in just replacing doors while keeping the frame intact. Lots of 40mm wooden doors that have rotten from all the condensation running down from the single-pane glazing need replacing with 54mm (insulated) doors with dual pane glazing. Also de-laminating insulating doors from the early 2000s are due replacing. Especially the dark colored onces facing south. The former probably need upgraded lock too, the former can be fitted with the same system requiring no adjustments in the frame.
But I didn't notice it was a DIY jig, I thought it was the Festool one too.
Online luvmytoolz
« Reply #37 on: November 20, 2022, 01:30 AM »
Thanks! It worked a treat, but having said that the price Festool wants for theirs is a bit over the top, even for Festool!
Offline Coen
« Reply #38 on: November 20, 2022, 12:34 PM »
Yeah the 2200 replaced the 2000 and was Festool's newest plunge router untill the 1010 R came out, Plug-It had been around since forever by then.
But basicly everything above 1600W doesn't have Plug-It.
Some old designs pre Plug-It got updated (like the EHL-65, mine didn't have Plug-It when I bought ca. 2009), some (RAS?) didn't.
« Reply #39 on: November 20, 2022, 02:14 PM »
I sure wish the RAS had it, but I'm very glad to have gotten one before they were discontinued. That wasn't even on the horizon at the time, though. I actually bought it as a replacement for the Porter-Cable 371 belt sander, when it was discontinued.
I really don't understand that one either. Seemed like everyone, who ever tried one, loved it. They were somewhat difficult to get belts for. Kind of a chicken vs. egg thing. People wouldn't buy them becaause of the belts, yet none of the aftermarket companies made belts, because there weren't enough of them sold? Self-inflicted problems.
I don't have a clue what to do if the RAS ever quits on me?
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
