Author Topic: OF1400 Depth Scale Replacement  (Read 2102 times)
Offline dlu
« on: October 07, 2018, 05:27 AM »
I got my OF1400 after the switch to imperial depth scales, but fortunately the only difference between the machines in the stick on depth scale and Festool USA can provide you with a metric scale. Before I dive into this a wondered if anyone has experience removing the depth scale. The new scale is adhesive backed and I assume that the old one is as well. How easily does the scale come off? Any tips?
Online deepcreek
    • TimberFire Studio
Re: OF1400 Depth Scale Replacement
« Reply #1 on: October 07, 2018, 05:42 AM »
I just requested an OF1400 Metric scale from Festool USA.
They're currently on backorder but expect to have more soon.
The lady in customer service told me I had to send the router in for conversion and the cost would be $75.
I asked to speak to someone in service and Brett explained it was just a sticker.  Part number is 462622.
For what it's worth, the scale for an OF1010 actually screws on and has to be replaced.
« Last Edit: October 07, 2018, 09:51 AM by deepcreek »
Joe Adams
TimberFire Studio
Houston, Texas
Offline Duck76
« Reply #2 on: October 07, 2018, 10:32 AM »
When I got my replacement scale I simply peeled off the old scale and stuck the new one on. The replacement scale came with a peel and stick back. Super simple.
Offline ADKMedic
« Reply #3 on: October 07, 2018, 11:15 AM »
I fully understand how it can be super easy to peel off one sticker and put on another, but does accuracy suffer?  My thought is that it would be very easy to be "off" by a millimeter or two when you put the new sticker on.  Does anyone have any thoughts or experience with this?
Andy
T-15+, RO150, TS55, CT-36, Pro5, DTS400, OF1400, OF1010, PS-420-EBQ, MFK700, DF-500, VAC-SYS, MFT/3 x2, CMS-GE, LR-32, soon a KS-120REB on a date sometime between now and eternity!
Offline dlu
« Reply #4 on: October 07, 2018, 12:09 PM »
Accuracy won't suffer. There is a "rabbet" where the sticker goes that should index it, and on top of that it is a relative setting. The absolute worst that you might do is get it placed so that you ran out of scale at one end or the other and I don't think that is too likely given the rabbet.
Offline dlu
« Reply #5 on: October 07, 2018, 12:11 PM »
Replacing the OF1010 scale is super easy. Easier than the 1400, I think.
Offline ADKMedic
« Reply #6 on: October 07, 2018, 12:14 PM »
Doug, thank you for the reply!
Andy
Offline dlu
« Reply #7 on: October 07, 2018, 05:21 PM »
Thanks, did the same. It was way easier than I expected – almost no adhesive residue. The new one registers nicely and the adhesive seems to be quite forgiving.
Offline justaguy
« Reply #8 on: October 07, 2018, 05:26 PM »
Andy
When you use a route scale it's typically a relative measurement. You install the bit, plunge until the bit makes contact with the material, zero out the scale, then set your cut depth.
Offline Duck76
« Reply #9 on: October 07, 2018, 05:30 PM »
On top of the registration recess for the new scale you can use the calibration screw on the depth stop flag and get it bang on.  Sedge posted a short video tip on this a while back.
https://www.instagram.com/p/BWh8sIdFGNt/
Offline jeffm13
« Reply #10 on: November 05, 2018, 03:33 PM »
I ordered a replacement scale from Toolnut about a month ago.  They just informed me that the replacement part (462622) has been discontinued...  Apparently, now we're stuck with imperial.
Festool: TS75, DF500, DF700, OF1400, LR32, ETS EC 150/5, DTS400, RS2E, T18, TXS, CT36, PS420, FS1400 (2), FS1400/2-LR 32, FS 2424/2-LR 32, Tradesman/Installer Cleaning Set; TSO: MTR-18, GRS-16 PE, TDS-10, TPG-20/30; UJK: Parf Dogs, Super Dogs, Parf Guide System MkII, Seneca: Parallel Guides, Domiplate, Domishim; Makita: 3000mm Guide Rail; Jessem: Mast-R-Lift w/metric conversion kit, Pow-R-Tec Router, Mast-R-Fence, Mit-R-Slide, ClearCut Stock Guides; Grizzly: G0441 Cyclone, G0691 Table Saw; Laguna: 18BX Bandsaw; Robland: X31 Combination Machine; Incra: MagnaLock Cleansweep; Woodpecker: 1281-300mm, 600mm T-Square, 1200mm Ruler, 1200mm Story Stick Pro; Bosch: GCM12SD Glide Miter Saw
Offline Bob Marino
« Reply #11 on: November 05, 2018, 04:37 PM »
  I have the scales available for sale on my site.
Former Festool  Dealer since 2002; user well before that!
Offline Svar
« Reply #12 on: November 05, 2018, 04:48 PM »
Any chance you have metric sticker for TS55REQ?
Offline Bob Marino
« Reply #13 on: November 05, 2018, 05:04 PM »
 Unfortunately not.
Offline jeffm13
« Reply #14 on: November 05, 2018, 10:43 PM »
@Bob Marino, I can't find it.  Could you send me a link?
Offline justaguy
« Reply #15 on: November 05, 2018, 10:47 PM »
Search for 462622
Offline jeffm13
« Reply #16 on: November 06, 2018, 01:18 AM »
Doh! Thanks @justaguy.  Just ordered it., aong with a pair of qwas fence dogs.
