Author Topic: OF1010 EBQ official maximum bit length?  (Read 806 times)
Offline NFL_DK
« on: February 11, 2021, 05:07 AM »
Hi everyone,
I'm new to this forum.
My question is not answered at neither the Festool web page nor the manual for the machine, as I see it.
I can measure the total length from the bottom of the clamping collet to the base, so I guess I can just subtract a millimeter or two to be sure the bit I buy is not too long.
But is there any official max bit length for this model?
Best regards
Nicolaj, Denmark
Offline Alex
Re: OF1010 EBQ official maximum bit length?
« Reply #1 on: February 11, 2021, 05:45 AM »
Hello Nicolaj, there is no official length set for this router. In theory, you can place any 8 mm bit you find in it.
In practice it will be difficult to find 8 mm bits that stick out further than is safe to use, because manufacturers are aware of size limits. Use your common sense, and be aware yourself that really long bits can break due to the forces involved. I would think that as long as you stay under 30 mm depth of cut you're ok. But with deeper cuts it is always best to make multiple passes before reaching the final depth.
Offline Bert Vanderveen
« Reply #2 on: February 11, 2021, 07:48 AM »
Also: most bits have an indication on the shaft for their safe insertion (eg the limit of extension). Never deviate from that.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline mino
« Reply #3 on: February 11, 2021, 09:11 AM »
This.
The max length is a property of the bit, not the router.
A bit from crappy steel may handle 20 mm extension only barely while a quality specialist bit may handle 30 mm extension "with ease".
Always follow the bit manufacturer guidance - including the max rotation speed which may be lower for the bigger bits than the given router max speed.
When the Machine does not have a brain, use Yours.
Protool: AGP 125, VCP 260
My Precious: 2x 376, 376 holy, 632, 1016 holy, 1400 holy, 2400, 2x GRS 16 PE, GECKO-DOSH
« Reply #4 on: February 11, 2021, 10:37 AM »
I've only seen the insertion depth marking on Festool router bits. The other bits I use, Whiteside, Amana & CMT don't provide depth marks.
Offline GoingMyWay
« Reply #5 on: February 11, 2021, 10:47 AM »
Freud router bits have a minimum insertion marking.
Inquiring Minds Want to Know
Offline hdv
« Reply #6 on: February 11, 2021, 11:43 AM »
Are you sure about that? I always interpreted the sideways K-like mark on my CMT bits as the preferred insertion depth.
Offline RustE
« Reply #7 on: February 11, 2021, 12:02 PM »
CMT mentions 75% minimum shank engagement in their safety recommendations. Not sure how that corresponds to markings on the bits.
Offline Crazyraceguy
« Reply #8 on: February 12, 2021, 06:48 PM »
I don't know about "all" of them, but the Amana insert style bits definitely have the insertion marks.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
