Author Topic: Will the WCR 1000 fit with CT26 & CT SYS VA  (Read 860 times)
Offline Rick Herrick
« on: June 06, 2020, 09:47 AM »
I have both the CT26 and the FT cyclone in use.  At this time I don't use the taller, clear section of the cyclone, but may in the future.  I wanted to double check to make sure the "Festool Work Center WCR 1000 (497471)" will work with my current configuration.  Been wanting the work center and now with the price increase, its moving up the priority list.  Thanks for any pointers or tips.
Offline Chris Wong
  • Festool Dealer
  • I make things that challenge me.
    • Flair Woodworks
Re: Will the WCR 1000 fit with CT26 & CT SYS VA
« Reply #1 on: June 13, 2020, 01:54 AM »
If my memory is current, the WCR relies on the Classic clips in the corners to attach and therefore would not secure to the top of the cyclone.
Chris Wong, http://FlairWoodworks.com
First Festool was a free pencil.
Shipping live-edge cribbage boards around the world since 2010.
« Reply #2 on: June 13, 2020, 09:43 AM »
Thanks Chris.  Classic, meaning pre-T-Lock ?
Offline RJNeal
« Reply #3 on: June 13, 2020, 10:51 AM »
Yes. The classic was before the T Loc.
Offline Chris Wong
  • Festool Dealer
    • Flair Woodworks
« Reply #4 on: June 13, 2020, 11:00 AM »
What RJ said :)
« Reply #5 on: June 13, 2020, 11:00 PM »
Thanks guys.  I guess I will get my money's worth out of the 30 day return policy.  Got nothing to lose.
Offline Chris Wong
  • Festool Dealer
    • Flair Woodworks
« Reply #6 on: June 13, 2020, 11:23 PM »
Careful, Rick. The 30-day policy applies to tools, not accessories. I don’t think the WCR qualifies as a tool, but check with your dealer.
Offline PaulMarcel
    • Voilà, my blog
« Reply #7 on: June 14, 2020, 04:24 AM »
Mine's on a CT-22. I mounted a Sortainer on the CT-22 for the common items like calipers, plyers, drill attachments (90º, eccentric, depth-set, and bit adapters). I built a frame around some ply that friction fits over the top of the Sortainer then bolted the WCR-1000 to it. I like that the WCR is now higher up, the Sortainer is infinitely helpful, and I inserted cork-topped ply onto the deck of the WCR-1000 for stowing tools while working. They don't slide and if a sander is winding down, it won't skate. Even if I upgraded to a dust extractor that took the WCR natively, I'd replicate this setup because it is too useful.
It takes making a frame with a bit of ply: 20 minutes to a handier setup.
« Reply #8 on: June 14, 2020, 12:15 PM »
Thanks Chris, that is a good point.
« Reply #9 on: June 14, 2020, 12:15 PM »
Thanks Paul, any chance of a picture of your set up? Thank you.
