Regarding the TPC 18 drill, does anyone know whether the black housing surrounding the gearbox is plastic?
I've got access to all those standards and have had a quick look through. I was quite surprised to see that 62841-2-5-2014 "particular requirements for hand-held circular saws" doesn't actually mandate an anti-kickback device at all. The standard does go into some detail about the safe operation of such a saw which I recognise as the instructions that manufacturers include in their safety booklets.
Annex BB indicates that for saws without a riving knife, there are additional compliance check to ensure that the blade will retract or be fully guarded within 0.3s after the device has been dropped twice as follows:
a) oriented with the lower guard being at bottom, so that the saw will strike the concrete
floor with the base plate parallel to the floor;
b) oriented so that the saw will strike the concrete floor in a hand carrying position.
Noting that the version of the standard above indicates that this is carried out with a 2mm (!) thick steel disc fitted.
It's actually pretty precise on how the saw needs to be build if it doesn't have a riving knife. I was - by now - able to take a look at it - partly at least.
Main take away is, if no riving knife is present, saw needs to be designed in a way that if it jumps out of the cut either a pendulum cover swings over the blade rapidly, or in case of a plung saw, the action is smooth, fast and strong enough for the blade being retracted immediately. (Yeah, I know ...) And in this case, the German DIN got weakened through this harmonizing process.
CE is always a self-declaration of the manufacturer, that he has abided by all rules/standards applicable.
Kind regards,
Oliver
