Author Topic: New improved TS55  (Read 1777 times)
Offline Troll
New improved TS55
« on: February 20, 2021, 04:48 PM »
Here's a heads-up to a new improved TS55, called the TS55F.  Coming to the UK around April, and presumably coming to the USA at some point.
Troll
Offline Coen
Re: New improved TS55
« Reply #1 on: February 20, 2021, 10:17 PM »
They only switched the blades from 2.2mm to 1.8mm. An improvement to some... a con for others.
Offline unixisgoodforyou
« Reply #2 on: February 21, 2021, 03:02 AM »
Does anyone know if the motor is brushless (EC-TEC) or old style brushed?
 RWW
Offline Alex
« Reply #3 on: February 21, 2021, 03:36 AM »
 RWW
Probably brushed, if they've made it brushless they would have plastered it all over the place. This new saw is just a minor update, nothing special.
Offline PreferrablyWood
« Reply #4 on: February 21, 2021, 04:43 AM »
I just bought a TS55 new, I for one am glad it is 2.2 kerf as my TS75 also is 2.2 so my FS will work for both.
I think they add the F to make clear that it has the anti kickback funktion. So if it was an issue I would have buyers regret now. But kickback is not an issue on the track you can just use the stop provided with the saw.
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
Offline neeleman
« Reply #5 on: February 21, 2021, 08:28 AM »
The TS 55 F has NO anti-Kickback function.
Only the new TSC 55 K does have it.
Both have the Finer 1.8 kerf blades, and the K stands for anti-Kickback
Festoolian since 1998.
FESTOOL:
RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline Bert Vanderveen
« Reply #6 on: February 21, 2021, 08:44 AM »
I think the F stands for Faster — all propaganda is spouting about is "two times faster".
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Coen
« Reply #7 on: February 21, 2021, 09:50 AM »
According to the catalog F stands for 'Werkzeugwechsel'  [wink]
Offline rmhinden
« Reply #8 on: February 21, 2021, 11:25 AM »
Nice to see that Festool is updating their tools.   Many haven't been updated in a long while.
Bob
« Reply #9 on: February 21, 2021, 03:01 PM »
OK jeg understand. Anti kickback is a nice feature if it does not come with any disadvantages.
Offline Coen
« Reply #10 on: February 21, 2021, 06:04 PM »
Bob
As long as there is nothing to add... why would they update.
Offline Wood_Slice
« Reply #11 on: February 21, 2021, 08:36 PM »
I was curious as well but claiming cuts 2 times faster is misleading. I guarantee there will be a ton of people thinking at first glance that its more powerfull than its predecessor. If you put the 1.8mm blade on the current REQ it will most likely also cut 2x faster than 2.2mm blade. Its just missleading and many people wont even unvestigate further and buy it on brand recognition alone.
I have a Kreg track saw bought before i caught the Green bug. Based on description is more powerfull than the TS 55. I didnt even think when i bought it but coming from a circular saw user to the Kregs its an easy transition as opposed to festools opposite blade side. I see the merrit in both types.
Shame they didnt increase the power on the TS 55 or add a anti-kickback on the corded version or a brushless motor, but cheaper to make a brushed motor.
While on the topic can the new 1.8mm blades be used on previous Festool track saws?
DF 500 + Assortments | ETS EC 125/3 EQ | CT MIDI + CT-Fi| MFT3 + Elements|
Offline mrB
« Reply #12 on: February 22, 2021, 04:25 AM »
The riving knife in the previous saws is thicker for the 2.2 blades, so I imagine it will not work well with the 1.8 blades.
Offline mino
« Reply #13 on: February 22, 2021, 05:00 AM »
Correct, the old knife is 2.1mm, so one would need to file it to 1,7mm-ish for it to work well with the new blades.
Well in the realms of a common shop. But not something Festool can do without a re-certification of the tool and/or a liability issue if they made a retrofit kit ..
I personally like the stability of the 2,2 blades and the fact my local blade maker makes them.
But still will probably get a spare knife assembly for my TSC to modify it for some special rip work down the line with the CMT 1.7/1.1
blade line (which has the same disk/kerf difference as the 2.2/1.6 Festool blades).
AGC 18(@AGC 125 flange), BHC 18, C 12, CTM 36, DRC 18/4, PSC 420, RS 200, TSC 55
Narex: EDH 82, EFH 36(fixed@LR32), EVP 13 H-2CA
My Precious FS/2: 376, 376, 376 holy, 632, 1016 holy, 2520
