Author Topic: new festool pre separator  (Read 8908 times)
Offline paddee87
« on: July 23, 2018, 02:18 PM »
hi guys,
could anyone give any insight as to why the new pre separator isn't compatible with the ct midi? as i have one i made into a box with a dust commander and seems to work well.
many thanks
Paddee
Offline tallgrass
Re: new festool pre separator
« Reply #1 on: July 23, 2018, 02:42 PM »
I believe it has to do with the distance from the input of the separator and the input of the vacuum. I asked this question and apparently that distance is fixed.
Offline paddee87
« Reply #2 on: July 23, 2018, 02:58 PM »
so if i used my hose i have for my pre separator  have already which is slightly longer it would work? or hole saw a hole through the black plastic at the top back of the extractor it would work? or are you saying the hose needs to be a fixed length?
Offline grainhaus
« Reply #3 on: July 23, 2018, 03:00 PM »
My guess is only because the angled connector on the MIDI is not in the front and is located in the back of the hose garage. The length of the fixed hose from the separator will not reach and also not angled to fit on the MINI/MIDI. To say that it is not compatible however isn't fully accurate(I believe) and can be fixed with a DIY made extension like I have on my MIDI, I created a small extension of 36mm hose with the "Y" adapter for 2 hoses in my shop. This puts the hose connector in the front, the perfect area like the other 26/36/46 Vacs and should work not problem with the separator. Hopefully I am correct, I would love to get one for my midi!
Offline paddee87
« Reply #4 on: July 23, 2018, 03:18 PM »
have you got any pics of your y setup? have you got blast gates on it also?
Offline grainhaus
« Reply #5 on: July 23, 2018, 07:06 PM »
No blast gates just the standard festool Y adapter for 2 hoses. There is a cap included so I just remove the blue hose and cap it, then I add my festool hose to the other side. Easy quick swap since I have my blue 36mm hose connected to a boom arm with the new clean tech braided hose at end. Pics here...
Offline grainhaus
« Reply #6 on: July 23, 2018, 07:07 PM »
Y adapter pic...
Offline Gregor
« Reply #7 on: July 24, 2018, 02:36 PM »
Since blue hoses don't seem to be standard (at least I know them only in green) and you already have the connector sleeve on the short hose (that goes into the vac): why not make that one a bit longer and only use the sleeve (without the Y thing)?
Offline tallgrass
« Reply #8 on: July 24, 2018, 07:49 PM »
I did not mean that it "could not work" , just that it was not compatible out of the box. As any member of the FOG knows, we will make everything work with everything, no matter what the barriers. :)
Offline grainhaus
« Reply #9 on: July 24, 2018, 09:46 PM »
I use the Y adapter to attach another festool hose for dual sanding operation( 2 people) and also since the blue hose (bosch 35mm anti-static) is permanently attached to a boom arm with a new cleantec braided hose on the boom. This gives me roughly 24 ft of hose. This allows me to use this bigger hose diameter for all MFT/3 cutting with my TS75 and router/sanders. I often will attach the old style hose to the Y adapter and plug the boom arm hose connection so I can vacuum and clean up the shop etc.
Online rst
« Reply #10 on: July 24, 2018, 10:00 PM »
I do something similar to Grainhaus.  I too have a 36mm Bosch hose that stays on a boom arm at my large cutting table.  I bought the covered Festool hose with integral plug and replaced the vac end of the hose and installed a tool end to make a double ended hose.  When I need the smaller hose for sanding or more length, i just plug the end into the 36mm tool end.
Offline paddee87
« Reply #11 on: July 25, 2018, 04:23 PM »
Thanks for all your replys. So their not comparable is purely down to the hose connection for the midi being at the back.
Offline Shane Holland
  • Festool Dealer
« Reply #12 on: July 25, 2018, 05:09 PM »
@paddee87 / All,
The information from Festool USA is that it is not compatible with the CT SYS / MINI / MIDI models. So, for now, the official word stands that it's not compatible with the smaller vacs.
Shane
« Last Edit: July 25, 2018, 05:30 PM by Shane Holland »
The Tool Nut
ToolNut.com
877-866-5688
Offline RL
« Reply #13 on: July 26, 2018, 03:10 AM »
Is it compatible with a CT22?
  • Festool Dealer
« Reply #14 on: July 26, 2018, 08:47 AM »
Yes, the new Festool Cyclone is compatible with the CT 22 and CT 33.
The Tool Nut
ToolNut.com
877-866-5688
Offline PeterK
« Reply #15 on: July 26, 2018, 10:02 AM »
Any info on how much height this adds to the dust collector?
  • Festool Dealer
« Reply #16 on: July 26, 2018, 10:09 AM »
@PeterK, those specs are on our website. The height with the container is 20", without the container is 12½".
https://www.festoolproducts.com/festool-204083-ct-cyclone-dust-collection-pre-separator.html
The Tool Nut
ToolNut.com
877-866-5688
Offline PeterK
« Reply #17 on: July 26, 2018, 11:10 AM »
Well duh!  [blink]
I didn’t scroll down and see the specs.
Thanks Shane.  [smile]
Offline guitarchitect
« Reply #18 on: July 26, 2018, 11:23 AM »
Can you go into any detail about how the top is designed?
A proper cyclone has a 3:1 height:diameter ratio which reduces static pressure loss and aids in separation. That's why the DD is so tall. Clearly the CT Separator doesn't have that, so what's in the top of the CT Separator? Is it more like a Thien Baffle design?
  • Festool Dealer
« Reply #19 on: July 26, 2018, 11:25 AM »
@guitarchitect, thanks for the question. We have not received samples or inventory yet since this product doesn't officially launch for another 2+ months. Here's an image showing the inside of the cyclone, which may help answer your question. I know it doesn't show much, but hopefully we'll get more details soon. Based on the photo, it certainly could be a Thien baffle design.
« Last Edit: July 26, 2018, 12:49 PM by Shane Holland »
The Tool Nut
ToolNut.com
877-866-5688
« Reply #20 on: July 26, 2018, 01:31 PM »
(Attachment Link)
thanks for the photo! that's awesome and basically tells the whole story... question is, what's on the bottom!
I'm not going to pull any punches though, that's not even close to a cyclone so they are doing some false advertising by calling it one. If it's not a thien baffle then it's a much more basic tophat separator, and I'm going to guess when people test it out they will find a big static pressure drop at the tool end.
That being said, I love the integrated design - I hate that the oneida unit adds 3' to the top of the vac (and looks horrible) so this is a great inline solution. I really want my CT26 to be my "only" vacuum and this would be a great way to achieve that (I use a big shopvac around the shop and it's love/hate). But I think I'll be better off doing my own baffle inside an existing systainer. The CT Cyclone is currently at $480 CAD for pre-order, which is hard to justify for a hobbiest like myself!
