Author Topic: New dust extractor CTM 26 E or 26 AC  (Read 726 times)
Offline Mike35x95x1
« on: October 19, 2021, 07:57 AM »
Hi everyone, I am just before big decision - a new dust extractor. There is wide range of FT dust extractors (I know...  ;) and so I have a dilemma.
This is my old buddy:
336757-0.
My principal interest is to improve the air condition in my workshop (health is on the first place). I am used to the sale-cleaning function (shaking out the dust via vibrations).
My idea is to buy similar size (capacity) dust extractor from FT. I am very into the idea to buy also the pre-separator (bigger capacity, easier empying, possibility to check everything visually, saving the base unit...?). Later I'd consider the extensions such as tool holder or boom arm but it's not something I couldn't live without.
So my questions are:
  • Which base unit to buy?
  • Go or not go for the pre-separator? Are my above expectations in compliance with daily practise?
  • What accessory should I buy from the very beginning?
Thanks a lot
Mike
« Last Edit: October 19, 2021, 08:00 AM by Mike35x95x1 »
Offline notenoughcash
  • to many ideas, not enough cash....
Re: New dust extractor CTM 26 E or 26 AC
« Reply #1 on: October 19, 2021, 08:24 AM »
what leateridge is it?  becase for somethings a midi is better, e.g. i prefer it for site work, but a larger one, would be beneficial if you have it static under a mitre saw or router table. e.g. ct36 or 48
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the bl**dy thing you just put down
Offline woodferret
« Reply #2 on: October 19, 2021, 08:27 AM »
(Attachment Link) .
I have a MIDI (old).  I've learned that the most important thing to optimizing dust collection is the quick ability to change hoses from 27mm to 36mm.  In some ways, this gravitates towards the CT26 and above since their ports are located on the front like your buddy.
That said, if do get a CT-VA20 then it wouldn't matter as much if you just get a MINI/MIDI since you're relocating the port up top.
Whether you want a cyclone, either Festool or other, depends on how often you batch cut with your TS/Miter.  I've taken to destacking my dust deputy from my unit most of the time just because I don't make that many consecutive cuts and I hate having to manually empty a cyclone.
It probably comes down to your portability requirements.  If you drag your unit around, I'd opt for the MIDI/CT-VA combo.  If you're a weekend hobby shop woodworker, probably just the CT26.  Maybe add the cyclone with it (later) if you tire of destacking your boom arm/workstation and are willing to put up with the alternative fuss.
Offline Mike35x95x1
« Reply #3 on: October 19, 2021, 09:28 AM »
I am planning to keep existing Metabo and use it as static under my Kapex. The new FT unit must be easily movable around the workshop. Existing unit is about 25 litres and as only the VAB-20/1 is 20 litres the basic unit capacity is not my biggest concern. The power and efficiency is what I want...
Offline Mike35x95x1
« Reply #4 on: October 19, 2021, 09:39 AM »
I am a weekend hobby shop  [big grin] so CT26 + CT-VA-20 was something what I had in my mind from the very beggining. Should I buy some additional tool or accessory or the set includes everything what I need for my little army: PSC420, T18, RO125, KS60, DF500, OF1010, TS55?
(Attachment Link) .
Offline Peter_C
« Reply #5 on: October 19, 2021, 11:52 AM »
I would recommend a good quality air filter of some kind. http://www.powermatic.com/us/en/p/powermatic-pm1250-micro-dust-afs/1791331
Offline Mike35x95x1
« Reply #6 on: November 20, 2021, 05:01 PM »
Hi, I am still not decided to buy the AC version or not. Esp. regarding accessories like extra bags and filters. Is it worth?
CTM 26 - bag 496187, filter 496170
CTM 26 AC - bag 496216, filter 203759
As I am decided to buy CT-VA-20 which version of CTM 26 is better for wood dust?
Thanks Mike
