Author Topic: New CT Midi with Blutooth enabled question.  (Read 1560 times)
Online Wood_Slice
« on: January 15, 2021, 09:07 PM »
I purchased the new CT MIDI about a month ago or so. Question is do I buy the 2 part blutooth set or just the part that goes over the end of the hose to turn Vac on/off.
DF 500 + Assortments | ETS EC 125/3 EQ | CT MIDI + CT-Fi| MFT3 + Elements| Installer's Set | TS55-REQ |
Offline Imemiter
Re: New CT Midi with Blutooth enabled question.
« Reply #1 on: January 15, 2021, 09:10 PM »
Just the button should do it.
CSX T18+3 TID18 HKC55 OSC18 OS400 OF1010 LR32 DF700 RAS115 DTS400 ETC125 CTSys CTMidi CT-VA
Offline CeeJay
« Reply #2 on: January 15, 2021, 09:46 PM »
I can confirm just the button is what you need.
Offline threesixright
« Reply #3 on: January 16, 2021, 02:47 AM »
+1 for just the button. Works great!
Offline mrB
« Reply #4 on: January 16, 2021, 01:25 PM »
Yes just the button.
Question: for those with a mini/MIDI and the button. .
Does pairing the button un-pair any previously connected batteries? It can you have both a battery and the button connected at once?
I could be wrong, but I feel like you can only have one paired battery at a time? Haven’t double checked, but from general use I feel like that’s the case?
Offline Jonny14
« Reply #5 on: January 16, 2021, 03:31 PM »
No, you can have batteries paired and still use the remote,  no problem.
Offline Imemiter
« Reply #6 on: January 16, 2021, 05:24 PM »
Connecting the button after a tool doesn't disconnect the tool. But only one tool at a time seems to be the rule. That, or one tool and the button. I haven't tried two tools without the button.
Offline mrB
« Reply #7 on: January 16, 2021, 05:32 PM »
Thanks, that puts the button back on my shopping list.
Offline Bascule
« Reply #8 on: January 18, 2021, 09:18 AM »
Im sure one of the official Festool videos I watched this week (My Midi and button remote are currently in transit) stated you can only have one battery pairing currently 'live' but up to 5 of the buttons can be linked - which seems weird, though you can also remotely trigger a new battery pairing from the button remote (so that up a scaffold you can swap a battery pack out without having to go back down to the Midi to re-trigger a pairing for the new one)..
Did I imagine that?
Offline Imemiter
« Reply #9 on: January 18, 2021, 10:19 AM »
Did I imagine that?
Pairing unconnected batteries from the button works very nicely.
Offline mrB
« Reply #10 on: January 21, 2021, 05:04 AM »
Did I imagine that?
Wow, the button gets better and better. .
Offline CeeJay
« Reply #11 on: January 21, 2021, 06:53 AM »
If you pair it with your coffee maker it will froth the milk from across the room...
