Author Topic: New Cordless Vecturo officially announced  (Read 11038 times)
Online grobkuschelig
« on: February 04, 2019, 05:45 AM »
Saw this today on the German Festool webpage:
4 configurations available:
- 574848 OSC 18 Li E-Basic (Vecturo, 1 Blade, SYS2)
- 574849 OSC 18 Li E-Basic Set (Vecturo, 3 blades, DE, PlungeBase, DepthStop, SYS2)
- 574851 OSC 18 Li 3.1 E-Set (Like Basic SET, plus 1 3.1C Battery, plus TCL6)
- 575385 OSC 18 Li 3.1 E-Compact (Like Basic pure, plus 1 3.1C Battery, plus TCL6)
Re: New Cordless Vecturo officially announced
« Reply #1 on: February 04, 2019, 05:55 AM »
Specs are broadly the same as for the FeinSuperCut for:
- Oscillation angle: 2°/2°
- Same position for speed dial
- weight: 1.6 kg (incl. 3.1 battery) / SuperCut states 1.8 kg with 5ah
- 10.000 - 19500 1/min
- Sound power Level: 94 dB
- Sound pressure level: 83 dB
- Vibration Level
New blades from Festool will also be available.
« Reply #2 on: February 04, 2019, 05:59 AM »
Accessoires overview.
Offline Mario Turcot
« Reply #3 on: February 04, 2019, 07:07 AM »
Thank you Grob  [thumbs up]
The plungebase is quite interesting.
Mario
Offline tobiaskurz
« Reply #4 on: February 04, 2019, 07:53 AM »
there is although a video available:
Offline JPCleary
« Reply #5 on: February 04, 2019, 08:14 AM »
Any reason to believe these accessories won’t be compatible with the corded Vecturo? Has anyone seen anything official that addresses backwards compatibility explicitly?
Not a professional, just a DIY festfool with apparently too much money on his hands -- Kapex120 | TS75 | OF1400 | CT26 | ETS EC125 | Carvex PS420 | CXS | Vecturo | MW 1000 | x2 MFT3 | UG Stand w/ wings
« Reply #6 on: February 04, 2019, 08:27 AM »
Good question, however some of those accessories are already available for the corded one. They look identical to me.
Not sure if they share the same part # but i would guess a YES!
Available at L.V.
« Last Edit: February 04, 2019, 08:30 AM by Mario Turcot »
Mario
Offline nvalinski
« Reply #7 on: February 04, 2019, 08:28 AM »
For that matter, I don't see why the accessories won't be compatible with any Fein products as well. The head looks exactly the same, they just have that removable accessory ring.
Offline SRSemenza
« Reply #8 on: February 04, 2019, 10:04 AM »
Available at L.V.
The plunge base is different ..................  no dust shroud or depth stop on the old plunge base.
But the attachment portion does look the same.
I hope they are compatible.
« Reply #9 on: February 04, 2019, 10:38 AM »
The attachment portion (labeled B in your pics) will be different.
The new Starlock Plus System has a bigger diameter for the tool holder.
I am using the old Festool parts (old corded Vecturo) on the current Fein SuperCut.
The attachment needed to spend some time on the lathe for a quick “diet”. ;)
Also I think the dust extraction features will be worth the upgrade. Hopefully the mounting holes are still the same.
« Reply #10 on: February 04, 2019, 10:39 AM »
Well I hope they retained the magnet on the front of the base...however that may be the location where the new DC port is.
Offline James Biddle
« Reply #11 on: February 04, 2019, 12:39 PM »
That battery looks different than the other 18 volt.  Are they compatible?
« Reply #12 on: February 04, 2019, 01:31 PM »
Hi James,
It is a normal 3.1 ah battery.
Those are normally packaged with the “compact” versions of drills etc.
You most likely are used to 5.2 ah batteries, which are more of a standard on the tools sets...
The Vecturo runs on the batteries any drill/saw runs on (besides 10.8V, obviously...)
Offline BrianSometimes
« Reply #13 on: February 04, 2019, 03:13 PM »
Additionally, I get the impression from the official specs on festool.de and from previous leaks that it only runs on the compact BP 18 Li 3,1 and not the larger pack (similar to how the circular saw only runs on the 5.2Ah variant, not the compact). Would like to be corrected if that's wrong.
« Reply #14 on: February 04, 2019, 03:33 PM »
Festool reached out and sent me one!
Just kidding.
Offline Otakar Svojše
« Reply #16 on: February 06, 2019, 04:52 PM »
The magnet is preserved and set up  [wink]
« Reply #17 on: February 06, 2019, 04:54 PM »
It is used battery 18V 5.2Ah ;-)
Offline JD2720
« Reply #18 on: February 06, 2019, 06:39 PM »
https://youtu.be/JXGCgoUDico?t=6
That is getting right to the point. Great demonstration, although I have no clue what was said.
« Reply #19 on: February 07, 2019, 02:00 AM »
That's a relief - does the oscillator feel difficult to handle with the larger battery or is it pretty much the same with both sizes? Thanks for the video!
« Reply #20 on: February 07, 2019, 02:21 AM »
Hi Brian,
I can only compare the Fein SuperCut 18V/5ah and 12V/2.5ah.
I assume the Festool 3.1 will be similar to the Fein 18V/2.5 which I don’t have. But it will also most likely be the perfect balance between power and weight.
With the 5ah, the SuperCut is a tad heavy and a little cumbersome to use.
But it is still a nice machine.
For any task where overhead/strange positions/twisted grip are needed, I much prefer the lighter battery with the tool.
And at least in my use, the multitool is then mostly not used for extended periods anyway.
Hope this helps.
« Reply #21 on: February 07, 2019, 11:28 AM »
I look forward to the Vecturo since that 2 degree oscillation makes quite a difference for tougher cuts. Never found my Supercut (corded) lacking. Never had a battery powered non Fein multicutter which has been more than just "ok".
The dealer said that it won't take Supercut blades (of which I have 70+ blades...) but I am wondering if there perhaps exists an adapter or workaround for using Supercut blades on Starlock.
I have the adapter for the other way around (which does not help me in this case of course...) and I would hate having to stock up on Starlock blades when I have a drawer full of Fein Supercut blades...
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Offline JD2720
« Reply #22 on: February 07, 2019, 12:00 PM »
I look forward to the Vecturo since that 2 degree oscillation makes quite a difference for tougher cuts. Never found my Supercut (corded) lacking. Never had a battery powered non Fein multicutter whih has been more than just "ok".
Someone may come up with an adapter, but I do not see how any kind of adapter would allow for quick blade changes. The Starlocks do not have the long blade mounting pin.
« Reply #23 on: February 08, 2019, 01:56 PM »
Yup, it is probably not going to happen - but considering Festool came from the same Supercut mount I was hoping they would come up with something to fit the existing blades.
I don't mind a little hassle changing blades as long as the mount is sturdy.
Offline ScotF
« Reply #24 on: February 08, 2019, 08:02 PM »
Dust collection and a depth stop make the kit more appealing to me. Cordless is also great for a multi-tool. Looking forward to this one coming to the US. It does not seem that we have to wait as long these days for new tools to make it to NA, which is always good!
« Reply #25 on: February 09, 2019, 05:47 AM »
I needed a Multitool last year.
I wanted new technology and did not want to wait.
Since the Festool models are always just re-branded/modified versions of the Fein SuperCut, I just got a SuperCut last year.
I like it very much and hope to be able to use the Festool-only accessories as well.
I adapted the old plungebase, but will most likely get the new one, if there is some more convenience to the ease of use. Same for the dust collection accessories. :)
I think if you need a tool like this, choice is yours.
Obviously, the green looks fantastic as always. ;)
Online threesixright
« Reply #26 on: February 09, 2019, 06:01 AM »
You have the Fein cordless one? How does it perform (battery wise)?
Yeha, a nice stack of green/white boxes just looks cool. Not a clue what it is about it  [eek]
Offline jobsworth
  • Festool Baby.....
« Reply #27 on: February 09, 2019, 12:15 PM »
Looks like some nice improvements. I have a old fien that does the job so I wont be needing a new one
« Reply #28 on: February 09, 2019, 12:43 PM »
My Fein is so old I have to use an Allen wrench to change the blade. The new Venturi seems to have a few improvements.  [wink]
« Reply #29 on: February 09, 2019, 01:12 PM »
I have the same model as you Michael...you forgot to add that after 20 minutes of use it's too hot to hold without wearing gloves.  [smile]
