Author Topic: How often do y’all replace Sanding Pads?  (Read 1393 times)
Offline Bill Chang
« on: May 10, 2019, 08:53 PM »
I have had two pads fail in the span of 3 days.
RO125 Hard Pad part # 492127
RO90 Hard Pad part # 495623
I was sanding Walnut in Rotex Mode on the RO125 when the pad basically disintegrated and flung foam padding everywhere.
While I was waiting for the delivery of the new pad I started using my RO90 to continue working.  Probably ran it for 30 minutes and the next day came back to discover the foam pad also split.
I understand these are considered “consumables” but to have two failures like this and not even under what I consider hard use is not a good start for my weekend.  [sad]
Offline Alex
Re: How often do y’all replace Sanding Pads?
« Reply #1 on: May 11, 2019, 02:21 AM »
The hard pads don't have foam?
I've had two soft pads disintegrate after I had them for 7 or 8 years. The foam ages and becomes brittle. A hard pad I had broke after 4 because the hook & loop on it was worn.
Offline ear3
« Reply #2 on: May 11, 2019, 07:35 AM »
That's totally not normal.  The only pad I've had to change on any of my festool sanders so far is for the RTS400, where the velcro got partially melted.
Are you using dust collection?  Or perhaps you are preternaturally strong and unknowingly press the sanding pad into the surface with excessive force?  [tongue]
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
Offline PeterK
« Reply #3 on: May 11, 2019, 08:16 AM »
For me, when the base foam of the pad starts turning yellow-ish it will be shortly after that the foam breaks down. When it happens it happens quickly in my experience. Very frustrating to be sure. Also has happened to my older Porter Cable sanders so not just a Festool thing. I used to think it was caused by usage and so I purchased backup pads but they failed quickly when put into use after sitting on a shelf for a few years.
Offline Bill Chang
« Reply #4 on: May 11, 2019, 04:19 PM »
I’m guessing just age of the pads, they are probably 3-4 years old.  I’ll get back to it next week when the new pads come in, keeping my fingers crossed!
Offline Jim_in_PA
« Reply #5 on: May 16, 2019, 10:54 AM »
I generally have gotten a 3-4 years out of mine but expect that interval to decrease a little now that I'm in my shop a lot more post-retirement from full time work and starting a formal business. Usually, the pads "wear out" due to heat from friction which degrades the H&L fingers, etc. If a pad is disintegrating like mentioned...that sounds like something else is amiss, honestly.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
