Author Topic: New Cordless Vecturo officially announced  (Read 10365 times)
Offline grobkuschelig
« on: February 04, 2019, 05:45 AM »
Saw this today on the German Festool webpage:
4 configurations available:
- 574848 OSC 18 Li E-Basic (Vecturo, 1 Blade, SYS2)
- 574849 OSC 18 Li E-Basic Set (Vecturo, 3 blades, DE, PlungeBase, DepthStop, SYS2)
- 574851 OSC 18 Li 3.1 E-Set (Like Basic SET, plus 1 3.1C Battery, plus TCL6)
- 575385 OSC 18 Li 3.1 E-Compact (Like Basic pure, plus 1 3.1C Battery, plus TCL6)
Re: New Cordless Vecturo officially announced
« Reply #1 on: February 04, 2019, 05:55 AM »
Specs are broadly the same as for the FeinSuperCut for:
- Oscillation angle: 2°/2°
- Same position for speed dial
- weight: 1.6 kg (incl. 3.1 battery) / SuperCut states 1.8 kg with 5ah
- 10.000 - 19500 1/min
- Sound power Level: 94 dB
- Sound pressure level: 83 dB
- Vibration Level
New blades from Festool will also be available.
« Reply #2 on: February 04, 2019, 05:59 AM »
Accessoires overview.
Offline Mario Turcot
« Reply #3 on: February 04, 2019, 07:07 AM »
Thank you Grob  [thumbs up]
The plungebase is quite interesting.
Mario
Offline tobiaskurz
« Reply #4 on: February 04, 2019, 07:53 AM »
there is although a video available:
Offline JPCleary
« Reply #5 on: February 04, 2019, 08:14 AM »
Any reason to believe these accessories won’t be compatible with the corded Vecturo? Has anyone seen anything official that addresses backwards compatibility explicitly?
Not a professional, just a DIY festfool with apparently too much money on his hands -- Kapex120 | TS75 | OF1400 | CT26 | ETS EC125 | Carvex PS420 | CXS | Vecturo | MW 1000 | x2 MFT3 | UG Stand w/ wings
« Reply #6 on: February 04, 2019, 08:27 AM »
Good question, however some of those accessories are already available for the corded one. They look identical to me.
Not sure if they share the same part # but i would guess a YES!
Available at L.V.
« Last Edit: February 04, 2019, 08:30 AM by Mario Turcot »
Mario
Online nvalinski
« Reply #7 on: February 04, 2019, 08:28 AM »
For that matter, I don't see why the accessories won't be compatible with any Fein products as well. The head looks exactly the same, they just have that removable accessory ring.
Offline SRSemenza
« Reply #8 on: February 04, 2019, 10:04 AM »
Available at L.V.
The plunge base is different ..................  no dust shroud or depth stop on the old plunge base.
But the attachment portion does look the same.
I hope they are compatible.
« Reply #9 on: February 04, 2019, 10:38 AM »
The attachment portion (labeled B in your pics) will be different.
The new Starlock Plus System has a bigger diameter for the tool holder.
I am using the old Festool parts (old corded Vecturo) on the current Fein SuperCut.
The attachment needed to spend some time on the lathe for a quick “diet”. ;)
Also I think the dust extraction features will be worth the upgrade. Hopefully the mounting holes are still the same.
« Reply #10 on: February 04, 2019, 10:39 AM »
Well I hope they retained the magnet on the front of the base...however that may be the location where the new DC port is.
Offline James Biddle
« Reply #11 on: February 04, 2019, 12:39 PM »
That battery looks different than the other 18 volt.  Are they compatible?
« Reply #12 on: February 04, 2019, 01:31 PM »
Hi James,
It is a normal 3.1 ah battery.
Those are normally packaged with the “compact” versions of drills etc.
You most likely are used to 5.2 ah batteries, which are more of a standard on the tools sets...
The Vecturo runs on the batteries any drill/saw runs on (besides 10.8V, obviously...)
Offline BrianSometimes
« Reply #13 on: February 04, 2019, 03:13 PM »
Additionally, I get the impression from the official specs on festool.de and from previous leaks that it only runs on the compact BP 18 Li 3,1 and not the larger pack (similar to how the circular saw only runs on the 5.2Ah variant, not the compact). Would like to be corrected if that's wrong.
« Reply #14 on: February 04, 2019, 03:33 PM »
Festool reached out and sent me one!
Just kidding.
Offline Otakar Svojše
« Reply #16 on: February 06, 2019, 04:52 PM »
The magnet is preserved and set up  [wink]
« Reply #17 on: February 06, 2019, 04:54 PM »
It is used battery 18V 5.2Ah ;-)
Offline JD2720
« Reply #18 on: February 06, 2019, 06:39 PM »
https://youtu.be/JXGCgoUDico?t=6
That is getting right to the point. Great demonstration, although I have no clue what was said.
« Reply #19 on: February 07, 2019, 02:00 AM »
That's a relief - does the oscillator feel difficult to handle with the larger battery or is it pretty much the same with both sizes? Thanks for the video!
« Reply #20 on: February 07, 2019, 02:21 AM »
Hi Brian,
I can only compare the Fein SuperCut 18V/5ah and 12V/2.5ah.
I assume the Festool 3.1 will be similar to the Fein 18V/2.5 which I don’t have. But it will also most likely be the perfect balance between power and weight.
With the 5ah, the SuperCut is a tad heavy and a little cumbersome to use.
But it is still a nice machine.
For any task where overhead/strange positions/twisted grip are needed, I much prefer the lighter battery with the tool.
And at least in my use, the multitool is then mostly not used for extended periods anyway.
Hope this helps.
« Reply #21 on: February 07, 2019, 11:28 AM »
I look forward to the Vecturo since that 2 degree oscillation makes quite a difference for tougher cuts. Never found my Supercut (corded) lacking. Never had a battery powered non Fein multicutter which has been more than just "ok".
The dealer said that it won't take Supercut blades (of which I have 70+ blades...) but I am wondering if there perhaps exists an adapter or workaround for using Supercut blades on Starlock.
I have the adapter for the other way around (which does not help me in this case of course...) and I would hate having to stock up on Starlock blades when I have a drawer full of Fein Supercut blades...
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Offline JD2720
« Reply #22 on: February 07, 2019, 12:00 PM »
I look forward to the Vecturo since that 2 degree oscillation makes quite a difference for tougher cuts. Never found my Supercut (corded) lacking. Never had a battery powered non Fein multicutter whih has been more than just "ok".
Someone may come up with an adapter, but I do not see how any kind of adapter would allow for quick blade changes. The Starlocks do not have the long blade mounting pin.
« Reply #23 on: February 08, 2019, 01:56 PM »
Yup, it is probably not going to happen - but considering Festool came from the same Supercut mount I was hoping they would come up with something to fit the existing blades.
I don't mind a little hassle changing blades as long as the mount is sturdy.
Offline ScotF
« Reply #24 on: February 08, 2019, 08:02 PM »
Dust collection and a depth stop make the kit more appealing to me. Cordless is also great for a multi-tool. Looking forward to this one coming to the US. It does not seem that we have to wait as long these days for new tools to make it to NA, which is always good!
« Reply #25 on: February 09, 2019, 05:47 AM »
I needed a Multitool last year.
I wanted new technology and did not want to wait.
Since the Festool models are always just re-branded/modified versions of the Fein SuperCut, I just got a SuperCut last year.
I like it very much and hope to be able to use the Festool-only accessories as well.
I adapted the old plungebase, but will most likely get the new one, if there is some more convenience to the ease of use. Same for the dust collection accessories. :)
I think if you need a tool like this, choice is yours.
Obviously, the green looks fantastic as always. ;)
Offline threesixright
« Reply #26 on: February 09, 2019, 06:01 AM »
You have the Fein cordless one? How does it perform (battery wise)?
Yeha, a nice stack of green/white boxes just looks cool. Not a clue what it is about it  [eek]
Offline jobsworth
  • Festool Baby.....
« Reply #27 on: February 09, 2019, 12:15 PM »
Looks like some nice improvements. I have a old fien that does the job so I wont be needing a new one
« Reply #28 on: February 09, 2019, 12:43 PM »
My Fein is so old I have to use an Allen wrench to change the blade. The new Venturi seems to have a few improvements.  [wink]
« Reply #29 on: February 09, 2019, 01:12 PM »
I have the same model as you Michael...you forgot to add that after 20 minutes of use it's too hot to hold without wearing gloves.  [smile]
« Reply #30 on: February 09, 2019, 01:20 PM »
No complaints at all on the performance.
Even on the tiny (and brilliantly light) 12V battery it does a great job.
I think the main advantage is the general 2° oscillating angle. Compared to my previous no-name multitool, the Fein cuts like nothing else.
I have the Systainer Version from Fein, so it is nice to make out in the fitting Orange/Black boxes...
Offline SRSemenza
« Reply #31 on: February 09, 2019, 02:03 PM »
Topic merged.
Offline rst
« Reply #32 on: February 09, 2019, 02:38 PM »
I also have one of the older Feins with the Allen wrench...mine's pneumatic.  That being said I have an older Multimaster with all the accessories stored in two grey Tanos systainers.  I bought a Supercut, not the new quick release, from Toolnut when they sold them in a systainer and then got the 18v cordless from them also in a systainer.  The cordless is great, especially working off a ladder.  The Supercuts both came with the adapter so I can use copious number of MM blades that I have.  I have the Vecturo accessories, the plunge base and the depth adaptor and they fit the Fein Supercuts perfectly.
Offline DashZero
« Last Edit: March 15, 2019, 02:57 AM by DashZero »
Offline TinyShop
« Reply #34 on: March 24, 2019, 03:34 PM »
For anyone in Europe who already owns a cordless Vecturo, are you able to speak to whether the new and improved accessories (now with dust collection!) are a) backwards compatible with the older corded Vecturo and/or 2) compatible with the Fein Multimaster 350QSL? If the OSC ring fits over the head of the current version of the Multimaster and the associated bolt-hole pattern matches same, then this would open up a wonderful opportunity for MM owners to benefit from the dust collection advancements evident in the new OSC Vecturo.
The question of compatibility has been asked multiple times both here and elsewhere but no one has yet responded to it. I, for one, am looking forward to the answer.
« Last Edit: March 24, 2019, 08:33 PM by TinyShop »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline demographic
« Reply #35 on: March 24, 2019, 04:53 PM »
I'm not exactly sure what the appeal of the small batteries on multitools is?
I prefer a bit of weight in the tool as it damps down the pretty severe vibrations.
The allowable usage time on these things is short enough as it is, you have heard of hand arm vibration have you?
Also I often use the blade at 90 degrees from the tool as it  seems to lessen the vibration even more.
« Reply #36 on: March 25, 2019, 06:20 PM »
Offline TinyShop
Offline leakyroof
« Reply #38 on: March 25, 2019, 06:51 PM »
. Don’t feel bad MK, my new 2.0 SuperCut has a bolt as well.  It’s not a deal breaker for me though.
« Reply #39 on: March 29, 2019, 03:30 PM »
Hey guys, the 18V Vecturo hit the stores today in Sweden.
They arrived late yesterday at my local dealership and I did have a quick hands on with them today - unfortunately I got in the store five minutes before closing time so it was a brief stint with them!
http://festoolownersgroup.com/festool-tools-accessories/vecturo-18v-in-stores-now!/
Both machines we looked at were manufactured 2019/02 (February)  8)
Offline Havwoods Accessories Ltd
  • Festool Dealer
  • Havwoods Accessories Ltd - FESTOOL UK DEALER
    • Our Ecommerce website
« Reply #40 on: April 03, 2019, 09:33 AM »
Right here goes...had a bit of a play today... 8) :
You CAN fit the New Starlock Vecturo accessory mount to the Starlock Supercut.
You CANNOT fit the NEW Vecturo accessories to the OLD Vecturo mount.
You CAN actually fit the NEW Vecturo Mount to the OLD vecturo BUT it does not allow correct operation, so do NOT do this, we only performed a test.
We presume the same goes for the old supercut but we do not have a machine to test.
You CAN fit the NEW Vecturo mount to the Starlock Multimaster BUT the Multimaster is only rated to Starlock plus so not recommended.
DISCLAIMER, these tests were just to see if things physically fit we haven't carried out extensive testing , please follow manufacturers instructions at all times to avoid voiding the warranty.
Hope this helps folks! [smile]
Few Pics below.
« Last Edit: April 03, 2019, 09:45 AM by Havwoods Accessories Ltd »
__________________________________________
FESTOOL Dealer, Preston UK
01772 696600
www.havwoodsaccessories.com
« Reply #41 on: April 03, 2019, 09:58 AM »
I'm curious what you mean by that? In what way is the operation impeded?
  • Festool Dealer
« Reply #42 on: April 03, 2019, 10:12 AM »
Little hard to explain..
 But the new collet or adaptor is too deep hence the the blade doesn't seat correctly.
on the new Vecturo the tool holder is deeper.
pics below. Hopefully makes sense.
01772 696600
« Reply #43 on: April 03, 2019, 10:27 AM »
Thanks...so when you put the blade in, the blade probably contacts the new adapter?
  • Festool Dealer
« Reply #44 on: April 03, 2019, 10:46 AM »
you got it. ;)
01772 696600
Offline bwehman
« Reply #45 on: April 03, 2019, 10:53 AM »
Bring to America soon please!
Offline TinyShop
« Reply #46 on: April 03, 2019, 11:18 AM »
@Havwoods Accessories Ltd - Could you please expand on your statement: "You CAN fit the NEW Vecturo mount to the Starlock Multimaster BUT the Multimaster is only rated to Starlock plus so not recommended." I'm not sure what you mean by these machine's respective "ratings" and how this effects their use in conjunction with the new dust collection accessories.
I own a 350QSL and would like to be able to purchase and utilize the OSC accessories since FEIN doesn't currently supply (and has never supplied) 'bladed' dust collection for the MM.
I look forward to your reply. Also, feel free to PM me with your answer if youvre not comfortable sharing it publicly.
  • Festool Dealer
« Reply #47 on: April 03, 2019, 11:24 AM »
PM Sent.
01772 696600
Offline usernumber1
« Reply #48 on: April 12, 2019, 01:51 PM »
is there any official word when this is coming to north america or canada? unofficial word?
Offline Shane Holland
  • Festool Dealer
« Reply #49 on: April 13, 2019, 10:23 AM »
@usernumber1 no official word. Tools are typically introduced in the European market 6-12 months in advance of their debut in the U.S/Canada.
877-866-5688
« Reply #50 on: April 13, 2019, 10:37 AM »
No official word. Tools are typically introduced in the European market 6-12 months in advance of their debut in the U.S/Canada.
I just took a look at the 2019 Festool catalog and the OSC 18 is not listed in there.
Offline Peter Halle
  • Magnum - My new little boy
« Reply #51 on: April 13, 2019, 11:34 AM »
@Cheese , thanks for the heads up on a new catalog being out.  I had no idea.
For those looking for the catalog right now here is a link:  https://www.festoolusa.com/knowledge/catalog-request  Once you get to the interactive catalog you can use the little icons on the screen to download a pdf if you wish.
It isn't populated on the webpage where the other catalogs are / have been.
@Festool USA
« Reply #52 on: April 13, 2019, 11:39 AM »
@Festool USA
I'll add to that Peter that you MUST use the icons on the bottom of the screen/page to save it in .pdf form. I tried saving it as a web file and that completely destroyed its functionality.
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« Reply #53 on: April 15, 2019, 08:45 AM »
We haven't announced a date for the cordless Vecturo in NA yet. The FOG will definitely know once an announcement is made.
Offline bryan1982
« Reply #54 on: April 16, 2019, 07:25 AM »
Does anyone know if it's coming to Australia?
I need one of these
Cheers
Bryan
Offline usernumber1
« Reply #55 on: May 15, 2019, 05:51 PM »
don't see it on the 2019 canadian catalog. do these new tools make it the same year after the catalog is published?
https://www.festoolcanada.com/knowledge/catalog
« Reply #56 on: May 15, 2019, 07:30 PM »
It's also not in the 2019 USA catalog.
My guess is that it will be a late fall introduction. Probably September/October.
For example the ETS EC was a September 2015 introduction. While the HKC was a September 2016 introduction.
« Last Edit: May 16, 2019, 09:03 AM by Cheese »
