Author Topic: Need Track Saw TS 75  (Read 655 times)
Offline KevinW
« on: April 14, 2019, 02:03 PM »
I need the TS 75 Track saw.  I have a 55 and multiple rails so I just need the saw.  Are there different models available?  It seems that you may be able to purchase a prior model.  I am in US and would like metric but it appears I am stuck with imperial.  Amazon sells the Festool 575389 Plunge Cut Track for $660.00.  Woodcraft seems to have the same one for the same price.  Is that the one to get?
Online ScotF
Re: Need Track Saw TS 75
« Reply #1 on: April 14, 2019, 02:28 PM »
I think you can get them with or without the 1900mm rail. Unfortunately, only in Imperial in the US unless you can gete a used one or one on recon that comes up in metric.
Offline Blues
« Reply #2 on: April 14, 2019, 04:45 PM »
Its a sticker.. Festool! Give both imerial and metic. Let the user decide.
Offline DrDankDust
  • Throg! Frog of Thunder
« Reply #3 on: April 14, 2019, 07:03 PM »
In no way associated with these guys but ustoolandfastner.com is where I got my last order primarily b/c they were located close enough that their free shipping gets to me next day & as long as you're not located in Mass no tax on your order. I have to pay tax for Amazon in my state that may be different for you.
Festool TS-75 W/75" & 55" Rails, Domino DF-500, Rotex 150, CT-26
Offline ear3
« Reply #4 on: April 14, 2019, 08:07 PM »
Festool prices are fixed in the US, so you can choose on basis of service and philosophy.  It's always good to work through a brick and mortar dealer if you have one in your area, as they will be able to painlessly  hook you up with service and troubleshooting if necessary.
