Author Topic: Must have Festool kit?  (Read 9754 times)
Offline grobkuschelig
Re: Must have Festool kit?
« Reply #30 on: May 12, 2021, 06:36 AM »
One tool I forgot to mention but is high on my wish list is the ES ETS edge sander (thanks for reminding me Mino!), I just need to decide whether to go corded or cordless... I'm in a workshop so corded makes sense (cheaper and no need for batteries, will be connected to a vac anyway) but cordless is shiny and feels more flexible...
They offer a mains-adapter for the cordless.
I have an RTSC and it runs corded with the adapter most of the time, but it was helpful to be able to run it on battery for the odd task.
I think we who have the CXS love it due to ergonomics and control.
I used the Bosch drivers in the past and a lot of other brands.
The CXS is more like an extension of the hand rather than a tool in your hand, if you ask me.
The Domino has „cousins“ in the Mafell Duo-Doweller and the Lamello Zeta-P, but they all have their niches with different approaches for applications and costs.
Offline Freetime101
« Reply #31 on: May 12, 2021, 07:13 AM »
This is true, making the only real difference the cost... Corded is slightly faster (12,000 vs 10,000 min) but I have no idea what this means in use... (obviously it'll sand faster but would the difference matter...)
Offline mino
« Reply #32 on: May 12, 2021, 09:08 AM »
The corded one is a bit lighter and the handle is a bit smaller without a battery. But for hobby use this is negligible, same as the speed difference. It is a finish sander, so material removal rate is not really important there. I would not buy the power adapter from the get go. For hobby use the battery runtime should be fine on itself.
If you plan on having only one of them, the cordless is IMO the better choice. Coupled with DTSC for the odd corner later on you are pretty much set for sheet goods processing.
These are no replacements for the ETS EC series though when you want to sand raw lumber etc.
The Machine has no brain. Use Yours!
Offline ChuckS
« Reply #33 on: May 12, 2021, 03:40 PM »
There's really no such thing as must-have tool or kit from Festool. Countless woodworkers in the world do great stuff without owning or using any Festool tools, and that supports my first statement.
The only exception is the Kapex...at least according to this fellow who can't sleep without one! [big grin] [tongue] (The guy's look reminds me of the SAW movies.)
« Last Edit: May 12, 2021, 05:05 PM by ChuckM »
Offline Crazyraceguy
« Reply #34 on: May 12, 2021, 06:13 PM »
Unless a guy is willing to take the time required to make Mortice and Tennon joints, in any of the several ways to make them happen, a Domino is pretty much a must have. Of course as a hobbyist, that time may not matter, but if you are making money with your work, it does.
Sure, you could drill holes with a brace & bit, then drive screws by hand, but who wants to do that?
This whole topic is basically, "it depends"......on a number of factors.
I worked in the custom department of a large cabinet shop for about 10 years before ever having/using any Festool equipment. My first was a DF500 and it made a huge change in the way I work. A few months later, I got an RO90. Again, big difference compared to the other sanders I had.
Next was MFK700, for solid wood edges on shelves or countertops. I bought a CXS to replace a 12v Bosch drill/ driver/ and right angle drill. One tool in place of three.
I got along fine with just those 4 for about 5 years, until a fire killed them all.
During the recovery, I got a TS55 as part of a huge bundle. It was very handy while a bunch of new stationary equipment arrived and was set-up. The routers were just added because of the ability to use them with the track, then impressed me in other ways too.
At this point, I wouldn't give up any of them. Absolutely necessary? No, but I wouldn't want to go back to the hard way. When you earn your living with them, time and convenience matter.
On a side-note. Duo-doweler, not even close to as versatile.
Lamello Zeta is a fabulous tool, but it is more of a compliment to the Domino than a substitute for it. It has the same limitations as a standard biscuit joiner as far as width.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Offline ChuckS
« Reply #35 on: May 12, 2021, 06:34 PM »
Unless a guy is willing to take the time required to make Mortice and Tennon joints, in any of the several ways to make them happen, a Domino is pretty much a must have.Snip.
A better machine (or a better way of doing things) doesn't make it a "must-have."
« Reply #36 on: May 12, 2021, 06:49 PM »
If time matters, it does.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
Offline CeeJay
« Reply #37 on: May 13, 2021, 04:59 AM »
Hilti TE-30AVR SDS - 12 years old, it’s been absolutely tortured and looks like junk, but it still works as well as the day I bought it.
Those Hilti TE-series SDS drills are amazing. I worked in heavy tunnel construction for 10 years and we always had 8-10 of these on site. They are so tough and reliable. I’ve never seen tools take such abuse and still keep backing up every day. No other SDS machine comes close in my opinion.
Offline Bob D.
  • Inactive Member
    • My Cordless Workshop
« Reply #38 on: May 13, 2021, 06:06 AM »
I am still using my TE-17 that I bought used 25 years ago. It's still going, can't kill it.
Offline Alex
« Reply #39 on: May 13, 2021, 06:55 AM »
I bet there's tons of people working in the same business as you who don't have a domino and don't miss it at all. Nothing's absolute.
Offline MaineShop
« Reply #40 on: May 13, 2021, 07:36 AM »
I have way too many festool, along with other brands. But if it were one tool, I won't give up my Ets 125, with the CT. I have a bunch of other sanders, including a Rotex and a mirka. But something about the Ets just fits my hand and arm movement best. I prob put in about 6 hours a week on mine and have for at least the past decade or so. For me if and when it finally dies it will be a same day replacement for me. Good news is it is one of the cheaper festool tools.
Worth noting I have at least a dozen other drills and drivers from all the major manufacturers but I do enjoy using the cxs for installer work. Not sure why but the size and balance is just perfect for some reason. I have the Milwaukee knock off that I picked up since I have a mountain of those batteries but there is really no comparison, and I don't think the Milwaukee was much cheaper if at all.
Offline CeeJay
« Reply #41 on: May 13, 2021, 05:33 PM »
Back on topic,
Of my Festools, in order of priority in terms must-have to nice-to-have I’d score:
1. Domino DF500
2. CXS
3. ETS EC 150/3
4. CT MIDI
5. OF 1400
6. DTS 400
7. Rotex 150
8. TS 55
That’s a balanced score of how frequently I use them (I use the CXS the most, followed by the MIDI), combined with how unique the tool is compared to competitor tools. Eg the TS55 is not only the tool I use the least, but also the one with in my opinion the least differentiation from Mafell, Bosch, Makita etc.
My competitor must haves are the Mafell P1CC, the Makita 23ga 18V pin nailer, the Makita 18V trim router and my AEG (Rigid) 16ga 18V bradder.
Finally not a particularly unique tool, but super useful and used more than pretty much any other is the 18V Makita adjustable LED light. This has replaced all the desk/angle poise lamps in my workshop, and is perfect for close up hand work, routing, and supporting all those pesky Festool machines (I’m looking at you OF1400 and DF500) without built-in lights.
I mean even my old school Makita RP2301 router in the router table comes with LEDs.....
Online squall_line
« Reply #42 on: May 13, 2021, 06:27 PM »
Which one specifically of the two dozen or so LED lights that Makita offers is your favorite?
Offline Cypren
« Reply #43 on: May 13, 2021, 06:42 PM »
I'm glad I'm not the only one annoyed by this. The strobe light on the Carvex is one of my favorite features about it and I would really like to see something similar on the routers to help guide their cuts.
« Reply #44 on: May 13, 2021, 07:08 PM »
I'm sure there are, I was one of them for years too. But, you can't miss what you never had.
I never said anything about absolute, just offering my view on the topic of "must have".
I certainly can't speak for everyone, wouldn't even try, but for me and the way I work, some things are essential.
Things were painfully slow in the weeks immediately after the fire. Not only were the tools destroyed, several projects awaiting delivery/install were there too. So, current jobs/upcoming jobs got behind because previously finished things had to be reconstructed first. All of this while moving, re-making work stations and replacing tools. It was quite a challenge and also the point were I really learned to appreciate the TS55, which I didn't have before.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
Offline FestitaMakool
« Reply #45 on: May 13, 2021, 07:28 PM »
I’m looking forward to the tower light, when it eventually shows up here. Hoping before autumn.
I have wanted to buy a couple of the Makita LED lights, but even on the darks side of the world we live in, the importer of Makita doesn’t think much of lights..
Regards to the OP, yes the CXS is something on its own. And an absolute essential Festool tool.
That said, it does cost, and it doesn’t have counterparts to use its batteries. I’ve lately been digging further into Makita 12V Max. I find them handling excellent, with quality electronics and smooth triggers. Being spoiled when doing small and large projects, several drills comes into play each doing one task.. As from today’s work in the photo.
(And when some of these drills I have where available pre-owned, but still as new. There’s a huuuge gap in price if I were to have these numbers in Festool drills) And none of the Festool’s would have done the job any better. 4 drills plus the drill press to work on this one:
Offline CeeJay
« Reply #46 on: May 13, 2021, 07:43 PM »
I like the DML801.
It’s small enough to stand anywhere without getting in the way and is bright enough to supplement whatever ambient light is there.
It sits up high enough to look down on the workpiece and the head has up/down and side/side tilt.
With a 3.0ah cell it is base-heavy enough to be stable and will last 4-6 hours.
Offline CeeJay
« Reply #47 on: May 13, 2021, 07:46 PM »
And agreed the CXS is expensive. But I got mine used for 60% of retail and that makes it great value IMHO.
Also got all my sanders, and the TS55 used for 60ish% of retail and they are as good as new for me.
Offline Freetime101
« Reply #48 on: May 14, 2021, 08:15 AM »
I should add the Bluetooth vac remote to my list...
By no means essential, I've just ordered one as I'm sick of climbing under the bench to turn the vac on for non-Festool/corded tools and general clean up. I could have moved the vac but I have a tiny workshop so it's tucked out of the way.
« Reply #49 on: May 14, 2021, 06:31 PM »
Yes, very handy.  I use mine most for general clean-up and with the Kreg K-5 since most of my stuff is corded, no bluetooth batteries.
Drills, drivers and Makita compact routers are all that I have that are cordless.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
Offline CeeJay
« Reply #50 on: May 14, 2021, 07:49 PM »
Ditto on the Bluetooth remote. I’ve got two.
One on the ‘no plugit’ hose I use with non Festool stuff, and I later put one in the ‘with plugit’ hose I use with my Festools. This is so I can quickly disconnect the hose from the tool for a clean up without having to trigger the tool.
Particularly useful for edge routing which is usually messy, and for cleaning up sandpaper between grit changes.
