Author Topic: Multi Tools with Festool 36L Vacumn  (Read 866 times)
Offline KenR60
« on: February 07, 2019, 11:21 PM »
Hello Everyone,  I have the 36L Dust Extractor and use it for a 10" Table saw and a Festool Sander.  Gets anoying to continually swap hoses depending on what tool I use. I do have the Y Fitting but find that I loose a lot of suction if I use the Y with both connected.
Is the a method for using the Y and cutting off the suction to the tool not in use?
Offline Don T
  • Phoenix, Az
Re: Multi Tools with Festool 36L Vacumn
« Reply #1 on: February 08, 2019, 01:18 AM »
Festool makes a “Y” fitting 452898 as well as blast gates 497926. Hope this is what you are looking for
Offline TinyShop
« Reply #2 on: February 08, 2019, 01:44 AM »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline SRSemenza
« Reply #3 on: February 08, 2019, 10:15 AM »
   You should be able to find blast gates that fit (maybe with some modification) the Festool 'Y' and hose.   If you add blast gates be sure to put  a jumper wire from the hose to the 'Y' in order to continue the AS unless using the Festool gates.
