Author Topic: An interesting note on Festool TS55 blades  (Read 1357 times)
Offline jcrowe1950
  • Festool Dealer Affiliate
    • Woodcraft Chattanooga, TN
« on: September 09, 2020, 03:28 PM »
Hi Folks,
     I was doing some TS55 blade measurements for an upcoming review an in the process discovered something that I hope somebody can explain. In the picture annotated below, I discovered that on Festool blades, the gullet size is consistent but the size of the metal between the carbide side of the gullet and the "front" of the gullet varies into three sizes. The distribution on the blade seems random to me. Any ideas from any of you geniuses?
Festool Specialist at Woodcraft, Chattanooga, TN
Latest Festool purchase...TID18 T18 set....love them
Offline Svar
Re: An interesting note on Festool TS55 blades
« Reply #1 on: September 09, 2020, 03:32 PM »
This is to prevent resonance and decrease vibration. Randomly spaced teeth hit the material at random time intervals.
« Last Edit: September 09, 2020, 03:42 PM by Svar »
Offline jcrowe1950
« Reply #2 on: September 09, 2020, 03:39 PM »
This is to avoid resonance and decrease vibration. Randomly spaced teeth hit the material at random time intervals.
   I thought that's what the anti-vibration laser cutouts were for.....that's what other vendors use...the variable sized "tooth supports?", seem counterintuitive as an anti resonance mechanism, but I'm not that type of engineer so school me....
Offline Svar
« Reply #3 on: September 09, 2020, 03:47 PM »
Laser cuts are expansion slots to prevent warping and vibration when blade heats up. Slots and teeth spacing are complementary and work in different ways.
PS. Sometime slots are enclosed (don't reach the edge). Those too dampen vibrations. There is more than one way to address this issue.
« Last Edit: September 09, 2020, 03:55 PM by Svar »
Online Cheese
« Reply #4 on: September 09, 2020, 03:55 PM »
As Svar said...similar to a variable tooth band saw blade. Reduction of resonance gives a smoother cut.
Offline jcrowe1950
« Reply #5 on: September 09, 2020, 04:20 PM »
   Thanks so much to Cheese and Svar for the information. I did some searching but could not find the information using the usual sources.
Offline Eric J
« Reply #6 on: September 09, 2020, 04:41 PM »
I think the anti-vibration laser cutouts reduce the vibration of the blade. There is also the workpiece+workbench and TS55 to consider. Each time a blade tip engages the workpiece it's going to apply a force to the workpiece and an opposing force to the TS55. If the impacts occur at a rate near a resonant frequency of the workpiece or TS55, vibrational energy will build up.
Offline Peter Halle
« Reply #7 on: September 09, 2020, 06:50 PM »
Leitz - who I believe manufacturers the blades - is a leading world class manufacturer.  The items you mentioned along with variable spacing in some blades leads to re sharpening issues with some vendors.  For instance, for a period of time Forrest would not sharpen Kapex blades.  That may have changed on their front now.
Online Cheese
« Reply #8 on: September 10, 2020, 11:52 AM »
FWIW...the laser slots that start at the edge of the blade and extend an inch or two into the plate are for thermal expansion. They usually take the form of a “J” or an upside down “?”. They are used to prevent the blade from warping and vibrating as it becomes hot.
On some newer blades there is also a series of laser cut “squiggles” that are cut further into the plate. Those are for sound damping.
On older blades there were sometimes 3/16” diameter brass or copper plugs pressed into holes, those were again for sound damping.
I’ve noticed that recently some 6”-7” Hilti framing blades have some fairly large cut-outs towards the middle of the plate. Those are for cooling.
Reducing the noise and reducing the heat all leads to a smoother cutting blade with a longer life.
Offline jobsworth
  • Festool Baby.....
« Reply #9 on: September 10, 2020, 01:38 PM »
Oh heck I dont know,
I just put the blade in my saw and so far they all been working great
Offline Martin Johnson
« Reply #10 on: September 17, 2020, 10:49 AM »
This is correct...one of our companies does reliability testing, and resonance is one of the factors that causes product failure...I've seen simulations of rocket launches in the lab that completely destroyed welded enclosures due to this effect.  Silly German's think of everything.
