As a second , third or fourth sander it might be fine. It’s a beast to use and I tend to finesse the work. It’s really a gear driven belt sander?
i should mention i do have a cordless Milwaukee random orbit sander, but its takes a long time to get through epoxy, i would be using (rotex or ets) to clean slab after its flattened with router jig
Cleaning up a slab after flattening with a router is the perfect job for an RO 125 or RO150. They can be very aggressive with the right abrasive, but it is no where near like the RAS 115. The RO sanders sand in an orbit which gives them the aggressiveness without the more grinder-like action of the RAS.
Then it can be shifted to regular random for finer grit paper. Then back to orbital again for polishing to a high gloss if needed. They really are a do-it-all sander.
The RO90 was the first Festool sander I bought, mostly for this versatility and because I already had a pneumatic random orbit sander for bigger surfaces. I use it for solid surface countertops or transaction tops on reception desks, edges mostly. I still depended on pneumatic sanders until a few weeks ago, when I got the RO125. I much prefer the RO to the ETS EC. If I had to give up one of them, it would definitely be the ETS EC. It's a great sander too, but not even close to the same.
As far as extractors, I would say that it depends on what you are using it for. The sanders and saw make fine dust and it takes quite a while to fill the bag, so you can get by with a smaller extractor. If you use it with a router or even a Domino, the chips are a bit bigger and fill one up quicker. How often you are willing to change bags or how much you have to carry it around are the biggest factors. The extractors themselves are not that heavy, but full of chips/dust is a quite different thing.
