Author Topic: TID 18 Drill bits  (Read 1071 times)
Offline rajun.services
TID 18 Drill bits
« on: January 28, 2021, 04:50 PM »
Hello,
Recently purchased the TID 18 / PDC 18 set.
Looking for suggestion on best Drill bit set to go with it.
Hex or round, which one is better?
Is there a chuck that can take round heads and quick replace? Kindly suggest.
Festool TS55, Domino XL, OF-1400, Jigsaw, TS-32, Sawstop 3HP, MFT/3, CMS-VL
Offline Alex
Re: TID 18 Drill bits
« Reply #1 on: January 28, 2021, 05:12 PM »
Hex or round .... hmmm, no.
Centrotec.
« Reply #2 on: January 28, 2021, 05:17 PM »
Ok centrotec, is there a good set? How are the Snappy ones?
Offline Imemiter
« Reply #3 on: January 29, 2021, 10:27 AM »
They're good enough, I think. The cabinet makers set and six-bit drill set are a good start. You'll still want to get some Festool bits.
CSX T18+3 TID18 HKC55 OSC18 OS400 OF1010 LR32 DF700 RAS115 DTS400 ETC125 CTSys CTMidi CT-VA
« Reply #4 on: January 29, 2021, 10:37 AM »
I would like to get it once and get it right, so if you suggest any specific ones, I will look into.
Also I was look at Festool Centrotec chuck and we can replace the bits.
Can I use a round bit to go along with the Chuck holder?
https://www.festoolproducts.com/festool-493421-twist-drill-bit-set-d3-0-33.html?utm_source=google&utm_medium=shopping&gclid=CjwKCAiAgc-ABhA7EiwAjev-j9lqwCTwaFZrdjEmZxAx1Dvxop1nGrylpj2C_gpuMiB-HU9clNCLRRoClSUQAvD_BwE
Offline Doug S
« Reply #5 on: January 29, 2021, 10:43 AM »
The thing is the PDC will take Centrotec in the Fast Fix chuck (or anything in the Jacobs chuck) but the TiD takes 1/4" hex bits
Axminster sell bits that work in both which I find useful for use with my Festool drills and Makita impact
https://www.axminstertools.com/fisch-hex-shank-brad-point-twist-drill-4mm-507223
You can grind some hex bits to fit centrotec
Offline Imemiter
« Reply #6 on: January 29, 2021, 11:49 AM »
Then buy once and be done.
https://www.axminstertools.com/us/festool-centrotec-systainer-kit-98-piece-950896?glCountry=US&glCurrency=USD
« Reply #7 on: January 29, 2021, 11:52 AM »
I guess the centrotec drill bit won't work on a TID isn't it?
Offline FestitaMakool
« Reply #8 on: January 29, 2021, 12:01 PM »
I’d suggest you’d not link to festoolproducts or toolnut - the links won’t work for us from Europe [wink] So no help there. Better link to Festool USA at least.
Anyway, the TID can only accept std. hex. Only advise is to go for impact rated bits and bit holders. Festool recently launched impact rated bits to go with the TID.
As mentioned from other members, Centrotec is very good for most other purposes, changes fast and is very stable, but not more than a standard jacobs chuck. When it comes to holding (Centrotec) hex, the Centrotec shines. But, it’s not necessary.
Offline Alex
« Reply #9 on: January 29, 2021, 12:16 PM »
Nope, it won't. The TiD takes standard impact rated hex bits.
The PDC takes centrotec bits. What makes centrotec so good IMHO is that you can change the bits out very quickly.
Offline SRSemenza
« Reply #10 on: January 29, 2021, 02:03 PM »
And is compact compared to adding a quick change holder to a Jacobs chuck.
An additional note ................  the 50mmm Centrotec bits are very short when inserted into the chuck. They only protrude about 20mm from the end of the chuck. And those stubby Centrotec drill bits are handy for tight spots too.
