Author Topic: MFT/3 table track saw  (Read 1851 times)
Offline Johns workshop
« on: June 10, 2022, 05:38 AM »
Any suggestions !  When using MFT/3 no Where to put your track saw except the floor it would be nice to have something to hang track saw  or router. Any suggestion?
Offline ghhsolutions
Re: MFT/3 table track saw
« Reply #1 on: June 10, 2022, 06:18 AM »
Not mine (as it is still on my to-do list) but this is the sort of thing you can make :
Offline twistsol1
    • Sawdustzone
« Reply #2 on: June 10, 2022, 08:33 AM »
The previous post looks awesome, but I just set mine on top of my CT33 dust extractor.
A shop full of tools and no talent
Offline Blues
« Reply #3 on: June 10, 2022, 01:32 PM »
My sys MFT sits on top of my vac with clamps in it. The grip strip prevents it from sliding once placed. The track saw cage attached to the mft in the previous post is nice, but wont work for me as i have another table that i move in and out to butt against my mft. Managing work space is more an art than science. Some have perfected it .. for me its always wip.  May be another thread asking people to share their work spaces would be nice.. 🙂.
Offline SoonerFan
« Reply #4 on: June 10, 2022, 09:38 PM »
Like @twistsol1, I set my TS55 on top of my CT when using my MFT/3.
Offline Ebuwan
« Reply #5 on: June 12, 2022, 02:41 PM »
I just set it in a stack of systainers
Offline gwendal
« Reply #6 on: June 12, 2022, 06:02 PM »
I made a receptacle for the TS55 (and the shaper orgin) that fits on top of systainer. It reduces the risk of the tracksaw failing from the stack.
Offline festal
« Reply #7 on: June 12, 2022, 07:09 PM »
Very nice. Would you share the svg?
Offline gwendal
« Reply #8 on: June 12, 2022, 09:42 PM »
Sure, I uploaded them to Shaperhub.
Offline jobsworth
  • Festool Baby.....
« Reply #9 on: June 12, 2022, 10:16 PM »
Buy another MFT to set it on
 take a piece of ply put it under yer MFT let it rest on te cross members.
 I use my STM for cutting got some MDF I use as a cutting surface plenty of room to set it on
orrrrr
Put a Systainer on top of your CT and set it on there
Offline festal
« Reply #10 on: June 19, 2022, 07:27 AM »
Thank you
Offline Crazyraceguy
« Reply #11 on: June 19, 2022, 08:24 AM »
I put a couple of locating blocks onto the bottom of a piece of MDF, to sit on top of my CT26. That gave me a nice flat surface, which was right behind the cut-off bench. That worked out for me for quite a long time, then when I added a taller cabinet to the end of the run. It now has an opening for the CT at the bottom, but covered that flat top surface when backed into that hole. I made a small pull-out shelf with a short rim around it for the saw to sit in after that. Works essentially the same and pushes away when not in use. Of course this is not a mobile solution, like an actual MFT could be. The flat MDF slab on a CT or stack of Systainers would do though.
« Last Edit: June 19, 2022, 08:26 AM by Crazyraceguy »
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline Coen
« Reply #12 on: June 19, 2022, 10:40 AM »
Dump (I mean: park) unused machine in the hose garage of the vac.
Sadly, the hose garage has gotten worse from that. CT-22 very nice. Newer ones have the handle in the way, but it still holds a bunch.
Oh, CT 22 orginal sold without hose garage. The 22-SG came with detachable hose garage. Later models have a permanently attached hose garage.
