Author Topic: MFT/3 Extension?  (Read 606 times)
Offline Len R
MFT/3 Extension?
« on: April 20, 2020, 01:08 PM »
Hi all, I have an MFT/3 that I use regularly, but I often find it too short in length.  I would like to extend it by 24".  Any suggestions on how to do that and maintain alignment with the hole grid?  Thanks, Len.
Offline jlcichocki
Re: MFT/3 Extension?
« Reply #1 on: May 23, 2020, 04:09 PM »
Len,
You could buy another MFT table with connector rails.  The hole alignment is pretty good.  Another option that I am actively exploring is purchasing the MFT extension table #203457.  I think it was originally designed to work with the MW 1000 mobile workshop.  But It works with all the MFT table rails.  The rough table dimensions are 40 x 20 inches and weighs 27 pounds.  I like the idea of moving it easily around the basic MFT to support material.  Maybe two would be even better!
Jeff
Offline Joelm
« Reply #2 on: May 23, 2020, 08:56 PM »
I'm using the mw1000 extension table and am mostly happy with it.
To square up the tables I am using 1 connection bar along the front of my mft. The holes are parallel but are not in line with the mft dog holes. At some point i plan on remaking both table tops at the same time so that all the dog holes are lined up.
The price is a lot cheaper than buying another mft and it is almost as wide as a regular mft. I'm debating picking up a second extension table.
Offline bkharman
« Reply #3 on: May 23, 2020, 09:12 PM »
Make a new top. Make it as big as you want. You could also go to a CNC shop to have them make one for you as well.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
