Author Topic: MFT Top dimensions from edge to first row of holes  (Read 308 times)
Offline Olive Press
« on: October 18, 2020, 12:57 PM »
Hi FOG,
First question.
Can someone please tell me what the distance is (mm) from the front/side edges of an MFT top to the first row of holes? (see pic)
Thank you so much.
« Last Edit: October 18, 2020, 01:11 PM by Olive Press »
Offline Peter Parfitt
  • Magazine/Blog Author
Re: MFT Top dimensions from edge to first row of holes
« Reply #1 on: October 18, 2020, 01:36 PM »
If I remember rightly the MFT3 top is 1102 mm x 707 mm. There are 11 holes across the width and 7 holes fore and aft. The holes are 96 mm between centres. Therefore the distance between the centre of the first hole in a row to the last hole is 960 mm. The distance between the centre of the top hole in a column to the bottom one is (6 x 96) 576 mm.
The distance from the edge of the top to the centre of the nearest hole along a row is therefore:
   (1102 - 960) / 2  = 71 mm
The distance from the edge of the top to the centre of the nearest hole in a column is:
   (707 - 576) / 2  = 65.5 mm
But you can lay the top out in many different ways but remember that  there is a 15 mm wide flange under the MFT3 top around the edges.
Offline woodferret
« Reply #2 on: October 18, 2020, 01:41 PM »
Quick fix to Peter's post.  The depth is 718mm, which puts it at a 71mm edge there as well.
Offline Grev
« Reply #3 on: October 18, 2020, 01:48 PM »
Here's a pdf drawing with dimensions.
Offline Olive Press
« Reply #4 on: October 18, 2020, 02:07 PM »
Thank you Grev, woodferret and Peter for the prompt responses. (Love your videos Peter and references to Mechano :))
Offline Olive Press
« Reply #5 on: October 18, 2020, 05:16 PM »
After doing the math again and measuring an actual table, the distance from the edge of an MFT to the edge of a hole is 61mm
(And according to Grev's PDF, 60.9mm)
Here's the math: (at least the way I look at it)
Horizontally an MFT = 1102mm
11 holes @ 20mm with 96mm centers.
So that's 10x96mm = 960mm + 10mm +10mm = 980mm
1102mm-980mm=122mm / 2 sides = 61mm from the bottom edge to the bottom of the holes.
And the same vertically = 718mm.
7 holes @ 20mm with 96mm centers.
6x96mm=576mm + 10mm + 10mm = 596mm
718mm-596mm=122mm / 2 sides = 61mm from a side edge to a column of holes.
« Last Edit: October 18, 2020, 05:19 PM by Olive Press »
