Author Topic: MFK700 and Vertical Milling  (Read 1473 times)
Offline thedevme
« on: January 15, 2019, 01:42 PM »
I saw the video below and unfortunately, the poster never put what bit he was using. I wanted to know if anyone using the MFK700 have done this technique and can recommend a bit that they use with it for doing vertical milling.
« Last Edit: January 15, 2019, 02:06 PM by thedevme »
Offline neilc
Re: MFK700 and Vertical Milling
« Reply #1 on: January 15, 2019, 01:58 PM »
It's helpful for trimming dovetails or finger joints that are proud of the casework. Or potentiallybutterflies that are placed in cracked live edge pieces.
I think you could use any relatively short straight cutting bit of a diameter that will fit in the MFK.  I have an 8mm bit straight cutter from Festool that I have used for trimming proud dominos, though a flush cutting saw can be equally useful if you are close to an edge.
Offline thedevme
« Reply #2 on: January 15, 2019, 02:03 PM »
@neilc that is exactly what I am looking for. By any chance do you have a link to the router bit you used for proud dominos?
Offline thedevme
« Reply #4 on: January 15, 2019, 02:11 PM »
thank you @neilc
Offline DynaGlide
« Reply #5 on: January 15, 2019, 02:18 PM »
@thedevme I thought he posted in the video comments the bit he used. Either way it should be this one: https://www.amazon.com/gp/product/B000P4JMLY/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
The problem with trying a different bit is the height in this non-intended use of the MFK using the horizontal base 'vertically'
Instagram @matts.garage
Offline thedevme
« Reply #6 on: January 15, 2019, 02:23 PM »
You are right I missed that - I thought it was someone else commenting and not him lol. Thanks for pointing that out.
Offline DynaGlide
« Reply #7 on: January 15, 2019, 02:29 PM »
He's a member here and a big contributor. @tjbnwi
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #8 on: January 15, 2019, 02:56 PM »
I know that guy.  [big grin]
The CMT 801.128.11B works well, gives you a little more travel adjustment. I also use he Festool bit for edge band trimming, I’ll have to find the number.
« Last Edit: January 15, 2019, 03:01 PM by tjbnwi »
Offline neilc
« Reply #9 on: January 15, 2019, 03:09 PM »
The Festool bit I used clears the base in that configuration.  Could be the one that Tom mentions.
Offline thedevme
« Reply #10 on: January 15, 2019, 03:29 PM »
LOL thanks Tom - buying the CMT I really like how you used it on dominos - I would like to do drawer construction with them and this is perfect.
Offline grobkuschelig
« Reply #11 on: January 16, 2019, 11:59 AM »
Check out the Festool surfacing router bit: 500368.
I think that is what you are looking for. Gives a 28mm cut width.
Offline thedevme
« Reply #12 on: January 19, 2019, 01:57 AM »
Thanks @grobkuschelig
