Author Topic: MFK700 and Dados  (Read 1901 times)
Offline thedevme
MFK700 and Dados
« on: March 09, 2019, 07:12 PM »
I have an MFK700 and I am looking to use my mfk700 for routing dados for drawers.  I love the process I saw on this video:
I have tried using some bosch routing straight bits but it makes a loud screeching sound when I tried to use it.  I am looking for a router bit that will let me do both 1/4 and 3/8 dados.  Please recommend the router bits you use with your MFK700. Thank you
Offline jobsworth
  • Festool Baby.....
Re: MFK700 and Dados
« Reply #1 on: March 09, 2019, 08:19 PM »
I use infinity spiral bits
Offline thedevme
« Reply #2 on: March 09, 2019, 08:44 PM »
Thank you
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #3 on: March 09, 2019, 09:23 PM »
Second the Infinity.
Offline Route24Design
    • My Personal Blog
« Reply #4 on: March 10, 2019, 11:29 AM »
I’m looking to get a MFK.  Looking at Infinity website, which one of these sets would be best to use with MFK?
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool CT Sys HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Offline jobsworth
  • Festool Baby.....
« Reply #5 on: March 10, 2019, 12:02 PM »
I like spiral bits.
 But its a personal choice really which on you go with
    • My Personal Blog
« Reply #6 on: March 10, 2019, 12:43 PM »
Ok. Thanks
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline RKA
« Reply #7 on: March 10, 2019, 02:48 PM »
Though I haven’t tried a downcut bit in the MFK, I prefer the upcut spiral bits.  The downcut bits can push the router base up a hair or push the plywood down a little if you’re working off the edge of a table.  Usually I’m going with the grain for cabinet backs and drawer problems so tear out hasn’t been an issue with the upcut bits.
-Raj
Offline thedevme
« Reply #8 on: March 11, 2019, 10:44 AM »
Thats interesting @RKA because I have read the opposite that downcut bits make cleaner dados. Might buy one and try.
Offline RKA
« Reply #9 on: March 11, 2019, 11:26 AM »
The theory is sound, with a down cut, the shearing action pushes the face veneer into the plywood eliminating tearout.  But when you're moving the bit in the direction of the grain, using a sharp upcut bit it doesn't really produce tearout.  Generally I avoid downcut bits unless a specific situation calls for them.  They require a little more care to use.
-Raj
Offline thedevme
« Reply #10 on: March 11, 2019, 11:32 AM »
Good to know thanks - I will pick up a few and see what results I get.
« Reply #11 on: March 11, 2019, 11:41 AM »
Here's an interesting read on CNC router tooling and hand held router tooling in general. This is a short excerpt:
"For one thing, upcut bits are more likely to tear the top surface with the cutting edges because they’re pulling the wood fibers up while cutting. On laminated materials, such as plywood with a thin top veneer, that can matter a lot. It may not matter if you’re ultimately going to round over that top edge and/or apply solid wood edge, but in other situations, it might be a problem."
"With a downcut mill, the advantage is that it’s pushing down on the piece you’re working, plus it cleanly cuts the top surface. The tradeoff is the waste is pushed back into the cut area instead of being ejected."
https://www.popularwoodworking.com/woodworking-blogs/cnc-tooling-basics-for-woodworkers-part-three/
The entire series of tooling articles are here:
https://www.popularwoodworking.com/tag/cnc-tooling-series/
Offline thedevme
« Reply #12 on: March 11, 2019, 11:43 AM »
Saw this exact article - I just ordered 2 upcut from Infinity - Luckily I live 30 mins from them so I will go pick them up today.
Offline Mario Turcot
« Reply #13 on: March 12, 2019, 07:53 AM »
I'm surprised no one mentioned the compression spiral bit. Two flutes for small dados.
I have the Amana Tool bit. Can cut in pretty much any material. It's not cheap but last for ever with little care.
Mario
Offline RKA
« Reply #14 on: March 12, 2019, 11:14 AM »
Typically I use them for edge routing where the center of the compression bit is roughly centered on the material.  I've never used those on dado's and grooves, primarily because only the upcut section would be inside the material.  The downcut section would never make contact with the surface.  I'm not sure if there is even a compression bit that works as designed on a 1/4"- 1/2" groove?
-Raj
« Reply #15 on: March 12, 2019, 11:49 AM »
Take a closer look at the bit Mario linked. It’s a new design with a very short (7/32”) up cut end and a much longer down cut section. Seems ideal for dados and other trenches in veneered material.
Offline RKA
« Reply #16 on: March 12, 2019, 12:17 PM »
Ah hah!  I didn't click the link.  Indeed the CNC bits open up more opportunities than the traditional woodworking bits.
-Raj
« Reply #17 on: March 12, 2019, 12:24 PM »
@RKA
You are right it's not meant for groves and dados but for CNC pockets, which in my opinion is pretty similar to a dado with no exit for the dust.
Mario
