Author Topic: MFK 700 for trimming edge banding: What are the correct accessories?  (Read 1708 times)
Offline GregorHochschild
My MFK 700 just arrived and I am eager to use it to trim same edge banding. However, I am not sure about the best setup for different types of banding. I see three options:
- Zero Degree Horizontal Base with edge trimming cutter
- 1.5 Degree Horizontal Base with edge trimming cutter
- Vertical base with radius router bit for edge banding
Which option is best for wood veneer edge banding? Which one for laminate edge banding? When do you prefer 0 versus 1.5 degree base?
Thanks!
Offline afish
The 0° is more for wider/thicker edgebanding as the 1.5° will create a gap along the face when you put two pieces together.
Offline scb_yyz
  • Grudge No Toil.
Check out Sedge's videos on the Festool channel. There's a bunch of them but to get started..
DF500  OF1010 TSC55  ETSC125/3  DTSC400 PSC420  TID18 T18 2xFSK/1400-2LR32+TSO TCL-6 SCA-8 Sys-Cart CT36E-HEPA+BT PARF MkII UJK WERA WIHA Bridge City
Offline jobsworth
  • Festool Baby.....
buy the kit and the bit and youll have everything you need
Offline afish
there are 2 different kits and neither include the 0 degree base if I remember correctly.  if you cut your own hardwood strips to glue on for edgebanding you will want the 0.  If its edgebanding tape around 1mm you will want the 1.5 or vertical base.
Offline Crazyraceguy
That's right, at least in the US. The zero degree base is optional and fits either of the sets. I would consider it essential, but that would not necessarily apply to everyone. It is most useful for wider/thicker edges.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline jobsworth
  • Festool Baby.....
One question about the 0 degree base: It costs the same at the 1.5 degree base in the U.S. but seems to exclude the bearing set and dust hood. Is that correct? That makes it really annoying if you have the EQB and want the 0 degree base. Or am I missing something?
Offline afish
I think that you are correct. you would need to buy the bearing assembly from parts if you bought the eqb.  I bought the kit but based on the photos on festool usa I dont see the bearing in the eqb.  I bought the kit and just bought the parts to convert the regular base to the eqb base. The mfk is one of the more confusing kits festool sells.
Offline tjskinny
Yes, I also believe you are correct.
The 1.5 degree base comes with the hood and bear, the 0 degree does not.   You can get the bearing from toolnut, but I don’t see the dust hood sold separately there.
https://www.toolnut.com/festool-495368-feeler-bearing-set.html
One other item I would suggest is doing this mod to the 0 degree base,
http://www.halfinchshy.com/2010/12/extending-capacity-of-mfk-700.html
And getting a 8mm collet, with a 8mm bit.
You can trim 3/4 edge band and use it to trim down dominos on drawers.
347657-0
347659-1
Offline afish
Re: MFK 700 for trimming edge banding: What are the correct accessories?
« Reply #10 on: August 21, 2022, 09:23 PM »
to be fair any router will handle trimming dominos the horz. base is really what makes the mfk special.
« Reply #11 on: August 22, 2022, 05:57 PM »
Mine came with 2 bases .
Looks like they still do
https://beavertools.com/576239-festool-mfk-700-modular-trim-router-sys3.html
Yes, the regular set comes with the vertical base(the one with the round opening) and the 1.5 degree horizontal base(which can also hold the motor vertically)
The zero degree base is an add-on accessory that doesn't come as standard equipment with any of the sets.
It seems that they assume that a person who would buy the zero degree base is coming from the regular set, rather than the EQB? since the dust extraction hood and follower bearing are part of that set.
The EQB base is available separately too. It seems to me that if a guy wants all of the bases, it would be best to get the regular set first, since it has the extra parts.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline afish
« Reply #12 on: August 22, 2022, 06:37 PM »
agreed, better to buy the set with the horz. base and add the zero base if needed and the parts to convert the vertical base to the EQB base which is basically an extra phenolic plate and a bearing brake.  "IF" you need or want it.
