Author Topic: Making Dominos, fast, easy and accurately  (Read 7676 times)
Offline T. Ernsberger
« on: April 27, 2021, 09:17 PM »
I had knives made from Moulding Knifes Direct to make dominos on the William Hussey moulder. The results are just as good as Festool’s.  Now I can run my scrap to make dominos.  I made $300-400 in dominos in about hour and half.  Just use my name when ordering from Moulding Knifes and they can retrieve my file.  I believe it’s $68 for a set of knives delivered to my door.  I tried uploading the video and the size it to big to post.
https://www.instagram.com/p/COC_z9ujwvm/?igshid=92msekp5ojdw
Offline DynaGlide
Re: Making Dominos, fast, easy and accurately
« Reply #1 on: April 27, 2021, 09:47 PM »
I saw this when you posted on IG. Very cool.
Instagram @matts.garage
« Reply #2 on: April 27, 2021, 09:55 PM »
Thanks Matt,
Offline vkumar
« Reply #3 on: April 27, 2021, 10:21 PM »
Very cool Matt.  Does the lip in the middle interfere with anything? Or does it help in assembly?
Vijay
Vijay Kumar
Offline MikkelF
« Reply #4 on: April 28, 2021, 05:47 AM »
Brilliant idea!
Offline Steve1
« Reply #5 on: April 28, 2021, 07:54 AM »
Cool.
I suppose one could also make them on a router table with a round-over bit.   Anybody try that ?
Offline jeffinsgf
  • Woodpeckers Marketing Department
« Reply #6 on: April 28, 2021, 08:11 AM »
I've done it. I wanted through-mortises in the same species as the project. I made Paduak Dominoes with careful planing and a router table.
Online Cheese
« Reply #7 on: April 28, 2021, 08:52 AM »
FWIW...just to expand the consciousness of this forum, Domino's can be fabricated from various materials. They don't need to be fabricated from wood exclusively.
In this instance, I needed conventional SAE threaded holes in some Domino's and fabricated them from aluminum.
Keep experimenting, it works.
« Reply #8 on: April 28, 2021, 08:55 AM »
Cool.
I tried that.  It will work if you keep the dominos loose.  If you make them tight the glue being a liquid will not compress and will not allow the joint to come together.  I had the knifes made with glue relieves to allow the glue to move
Online Packard
« Reply #9 on: April 28, 2021, 09:50 AM »
These could be made from extruded aluminum or extruded polycarbonate resin.  In either case ribs could be designed in to allow glue to flow, but the glue will not be of much use as most wood glues do not adhere well to aluminum or plastic.
Those boards will join nicely if you can depend on the surface glue to hold things together.  The dominoes would then be working as an alignment aid.
In that case, I think I would prefer to use a biscuit cutter and biscuits.
The wood dominoes add to the glue area and on butt joints and in sheet goods it is a much stronger joint.  But for joining face grain to face grain, the added strength is probably not needed.
Personally I am not convinced that the aluminum dominoes are an advantage over the wood versions.  The wood versions will expand in the slots to add a mechanical aspect to the glue up.
Offline squall_line
« Reply #10 on: April 28, 2021, 09:57 AM »
The aluminum dominoes look like a good compromise between a knock-down connector and a fixed domino; the images above appear that they're being used to mount some sort of sacrificial or replaceable end cap.  Theoretically you could also thread the under-side if you needed to hold the dominos tighter and/or make them replaceable.
In the shower or at some other point this morning I thought about using the domino cutter as a way to create space for safety locks on window sashes or frames (the kind that flip out and allow the window to open 2-3 inches but no wider), and wondered to myself if there was already a lock/latch that would fit.
Offline CeeJay
« Reply #11 on: April 28, 2021, 10:00 AM »
Cool.
I’ve made 8mm dominoes on the router table when I ran out previously.
I made a board a shade under 8mm thick first (about 7.9mm) then scored some very light grooves across it at 45 degrees with the table saw, the grooves were only about 0.5mm deep. These were for glue relief as per above.
Then ripped board to width, then rounded the edges on the router, then cut to length on crosscut box.
Took about 90 minutes to make about 200 dominoes.
Next time I might try a bullnose bit on the router if the dominoes are wide enough, would halve the time of the router operation.
Online ChuckS
« Reply #12 on: April 28, 2021, 10:12 AM »
Cool.
After rounding the tenons, I used a hand saw to make the grooves. I used beech for that batch of dominoes. A v-bit can also be used on the router table, if so desired.
The chair project I'm now working on also happens to need dominoes that are 70 to 80mm long. I have some left-over uncut shop-made dominoes to use.
« Last Edit: April 28, 2021, 10:36 AM by ChuckM »
Online ChuckS
« Reply #13 on: April 28, 2021, 10:17 AM »
Cool.
Another option is to cut grooves on the shop-made tenons with a V-bit...it does require extra work on the router table though.
« Last Edit: April 28, 2021, 10:24 AM by ChuckM »
« Reply #14 on: April 28, 2021, 10:20 AM »
If you want the same tight fit you get with the authentic Dominos you need something like what the op made, or you need to find metric bullnose router bits.
I’ve made very close 8mm Dominos with a 5/16” bullnose bit but wasn’t able to find bits for the other sizes.
Offline jeffinsgf
« Reply #15 on: April 28, 2021, 10:21 AM »
I guess my glue relief effort was pretty low-tech. I used a carving vee tool to carve in some grooves.
Online ChuckS
« Reply #16 on: April 28, 2021, 10:23 AM »
Snip.
The Domino machine can even be used to cut non-wood materials such as granite (?) countertops.
Offline jeffinsgf
« Reply #17 on: April 28, 2021, 10:25 AM »
Mine were 6mm using an 1/8" radius round-over. Perfect fit on the ends.
Online ChuckS
« Reply #18 on: April 28, 2021, 10:44 AM »
Snip.
Agreed.
Before I acquired the DF500, all my boards were edge-joined with nothing but glue. None of them including some close to 20 years old have failed. As long as the edges to be joined are properly trued (or spring-joined) and clamped, no dominoes or dowels or biscuits are needed other than for alignment purposes or for ease of handling/clamping.
Glue is stronger than wood.
« Last Edit: April 28, 2021, 11:04 AM by ChuckM »
Online Cheese
« Reply #19 on: April 28, 2021, 11:03 AM »
I would call these particular Dominos semi-knock-down because they're permanently epoxied into the walnut. That's the reason for the 3 "keys" that are machined into each side. The epoxy flows into the recesses and it's done.
Place the board on it's edge with the Dominos pointing up. Use a syringe to fill each mortise and move on to the next. When finished, the epoxy will have self-leveled and filled in the "keys" so just top off each mortise with a little more epoxy.
Yes, the Dominos retain a replaceable rear edge/cap for a countertop to make the initial fitting task easier. All fitting is done from the front and when completed, then the rear cap is attached.
Front edge:
Rear attached edge on RH side:
The bottom of the walnut countertop with the rear edge attached.
« Last Edit: April 28, 2021, 11:07 AM by Cheese »
Online ChuckS
« Reply #20 on: April 28, 2021, 11:15 AM »
One furniture maker featured in a Fine Woodworking article uses a combination of materials to make tenons for miters (after they're milled with the Domino Joiner).
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
« Reply #21 on: April 28, 2021, 11:30 AM »
Re -
Making Dominoes - Glad that it “works” for you.👏
$68 for the molder knives sounds pretty reasonable.
But... I’m guessing that most of us woodworkers -
Don’t have a $2,795 William Hussey Molder.
Early on - More than once - I bought some 2” Beech wood -
And “sliced” it - And “diced” it into Dominoes -
With my: Table saw, router, and band saw -
With very acceptable resulting Dominoes.
But...
Given the COST per Domino - And the TIME involved - I quickly realized that -
I’d rather just buy ‘em - And spend my time actually WOODWORKING.😋
To each their own.🤷🏻
« Last Edit: April 28, 2021, 11:40 AM by Joe Felchlin »
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: PDC 18/4 Li QuaDrive Cordless Drill Set, C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Online Cheese
« Reply #22 on: April 28, 2021, 11:40 AM »
Interesting Chuck...I've used this method before for both aesthetics and to prevent the miters from opening.
Online ChuckS
« Reply #23 on: April 28, 2021, 12:02 PM »
What was used to cut the slots on the frame?
Offline live4ever
« Reply #24 on: April 28, 2021, 12:06 PM »
I've got a Shopfox 1812 and I often thought about this but didn't NEED the project enough to put the research into getting it done.  Really appreciate the legwork here!
Online Cheese
« Reply #25 on: April 28, 2021, 01:36 PM »
I believe I used a table saw, the most difficult thing was to find a blade kerf that matches the thickness of the legs on the aluminum angle.
The kerf was cut too deep on the RH piece so I’ve just kept it around as a reminder and a sort of no-go gauge.  [smile]
« Last Edit: April 28, 2021, 01:39 PM by Cheese »
Offline Sparktrician
« Reply #26 on: April 28, 2021, 04:36 PM »
@Cheese, have you ever used a lock domino setup to prevent miters from opening up?  It has worked very well for me in cabinet doors as well as in screen doors.
- Willy -
Offline Lincoln
« Reply #27 on: April 28, 2021, 05:20 PM »
Snip.
That would be 'solid surface' bench top material (Corian etc), not granite. There's no way it would cut granite.
Online ChuckS
« Reply #28 on: April 28, 2021, 05:35 PM »
Yes. likely Corian or the like.
Online Cheese
« Reply #29 on: April 28, 2021, 07:08 PM »
Quote from: Sparktrician link=topic=66345.msg641231#msg641231
[member=44099
Cheese[/member], have you ever used a lock domino setup to prevent miters from opening up?  It has worked very well for me in cabinet doors as well as in screen doors.
No Sparky @Sparktrician ...I haven't, but that's a great idea. Any photos for the visually challenged? [smile]
I only edged one floor with the aluminum angle/wood thing and then just changed to countersunk GRK screws with contrasting or same color plugs, it was so much easier and faster, although it doesn't have the same WOW factor. It also seems that people either LOVE or HATE the aluminum angle/wood interface, there's no in-between.
« Last Edit: April 28, 2021, 07:12 PM by Cheese »
