This is really helpful feedback thanks everyone. For some reason I can never get notifications to work on this forum so I missed the responses pouring in :/
I will need to spend some more time at the store to see if I would get used to the handle. My wrist just doesn't like to move that way. I agree it would feel better if the saw were mounted lower to the ground but then I will tend to hunch over the saw which is just trading one problem for another. It is a really good idea to have a saw that works both left and right handed... they could have just put the horizontal handle in the middle the same way they have the vertical handle.
I know I would really miss the shadow line but having a laser on each side seems doable. Then again the shadow line also lights up your work area....
I've never had great luck with long bevel cuts on my DeWalt because of the blade deflection. With good hand discipline it can be done but it doesn't take much for that blade to start wondering off course. Are the Kapex rails just that much more solid that it doesn't have the same issue?
I had 2 Kapex burn up...one lasted 18 months. Only used by me cutting 3/4" material. Capacity of cut is awful compared to current Makita LS 1019. Dust collection and weight were a positive though.
I looked at that Makita a while back and was hesitant because it has a single laser which is isn't very useful. Why does the 40v XGT get the shadow line??? Apparently there are ways to hack something together.
One of the reasons for the Kapex handle design is to help keep the user from exerting side to side and rotational force. The rails seem pretty solid but the handle is a contributing factor to the very true cuts.
I know that some will never get used to or like the handle.
However I find that when I actually use it as opposed to just grabbing it to get a "feel" for it, that I actual grab it differently. I just go ahead and make the cut without putting all that much thought into grabbing onto the handle. This is just one of those things that a person ends up doing with much less consciousness than when trying it out.
This is not to knock the guy in the vid, he was genuinely showing how to hold / grab the handle. But he was really
grabbing the handle with his full hand. It doesn't take that much of a full grasp. I pretty much use my fingers and thumb, but I don't really wrap my full hand around it until I am bringing the head forward and down. Hard to explain.
Another big factor is just that different people have different hand, arm, wrist mechanics.
Like I said I know that some will never like or get used to the handle. And I am not trying to convince everyone to like it. Just giving some (hopefully) useful insight into using the saw.
I don't get not using or liking the lasers (yes, maybe hard to see outside ). I set / adjusted mine so that the blade fills the space between them exactly. In other words if a place the laser line exactly
on top ( overlayed on ) of a pencil line, the cut will leave exactly
just the pencil line. Knowing this I can take the line , leave the line, or split the line. I can see exactly how much wood will be cut (anything showing between the lasers). Which makes it easy to shave 64ths if need be.
And it eliminates a lot of bending down to see where the blade touches the wood. Which largely takes care of the lower saw station height.
@TomK_2 Can you buy it from a nearby store where it is easy to return? You've got 30 days to find out if you hate it.
