A lot of comment here about dust collection, the big stuff we see is not the problem it is the invisible stuff that is the problem. Has anyone got a dust meter and can run tests using a Kapex for >2.5 micron sized dust particles for say 5 minutes of cutting? let's see how good the Festool system is because I have never seen any proof of the dust extraction performance for invisible dust. I will ask this question elsewhere and see if I can find someone to also do a test. Everyone comments on how the Kapex system picks up the visible stuff but a broom will do the same thing and apart from the mess created the big stuff is not dangerous to our health.
I used the Dylos DC1700 Air Quality Meter in my shop when I had the DWS780 and a Bosch 125mm ROS (before I built out the second shop area). I would take a break from cutting or sanding when the small particulate count (0.5 micron and larger) exceeded about 1,500 over ambient for the day, which was usually less than ten minutes of use for each. I always used the ROS connected to a shop vac, but had a large shroud connected to my large DC system for the DWS780...it was mostly ineffective.
The reason I use the daily ambient as the starting point, is the Dylos does not differentiate between airborne pollen, burning toast, dog farts, or wood dust. A particle is a particle. There were days in the summer when the ambient reading anywhere in my house for the small particulate was over 15,000.
I have a ceiling mounted Record Power AC400 running on medium speed any time I was using the miter saw or Bosch ROS. It would take anywhere between 20 minutes to an hour of inactivity to bring the particulate count down to the daily ambient level. This meant working for a few minutes before taking a long break. That part of my shop did not have windows, so it was not possible to vent to the outside.
After changing to the KS 120, connected to a dedicated CTL 36E and the ETS EC 150 connected to my mobile CTL 26E and Dust Deputy cyclone, I can now complete any of my tasks before the DC1700 reaches my trigger point. I still use the AC400 on low speed anytime I'm using tools in that part of the shop. All of my other work with the powered hand tools is done in a new part of my shop that has a window to the outside. The KS 120 is still a bit messy, but the chips that I can see are not sneaking their way into my lungs to surprise me in ten years with respiratory problems.
