I was thinking about upgrading my track saw to the new TSC 55 K for a while. Way more power, higher cutting speed, better dust collection... What's not to like? Ah, the absence of the riving knife which was replaced by the electronic gizmo that would stop the blade if the saw comes off the track. I can live with that if my saw has 50% more power.
So right before the January Festool price increase I pulled the trigger. The new saw arrived very quickly and I instantly got it out and compared it to my old TSC 55. To my utter disappointment, it was exactly the same saw! Same base plate, same housing, same motor, same plunge mechanism, same miter settings, same blade arbor flange and bolt. The only difference was the new electronic kick-stop system, thin kerf blades and battery gauges were no longer on the motor housing.
Since the motor is exactly the same, the "twice as fast" feat was only achieved because of thinner blades! The tool itself is identical. I felt ripped off.
What stops me from using that same thin-kerf blade on my old TSC 55 REB? The 2.2 mm riving knife, that's what. But wait a second, isn't a 1.8 mm riving knife available separately as a part?
Of course it is.
It's a part that cost $23 plus shipping.
So I got the part, fitted it to TSC 55 R and compared the speeds. Both saws cut exactly the same. Definitely much more powerful and way smoother than a 2.2 mm blade! Dust generation was reduced by 60-80%, it was mind blowing.
Here is the dilemma... Do I return TSC 55K and spend $30 (part plus shipping) on the new riving knife plus $84 for the fine cut blade or do I sell my current TSC 55 R and keep the TSC 55 K? Monetarily it's a wash. It comes down to riving knife vs electronic kick-back stop + 3 year warranty + nicer sys3 systainer (yeah, it's way better organized inside for the track saw).
What would you do and why?
